POV-Ray : Newsgroups : povray.binaries.images : Bad weather in Gancaloon - wip 5 Server Time
26 Jun 2026 02:18:19 EDT (-0400)
  Bad weather in Gancaloon - wip 5 (Message 31 to 38 of 38)
Subject: Re: Bad weather in Gancaloon - wip 6
Date: 18 Dec 2013 07:13:42
Message: <52b19176$1@news.povray.org>
On 18-12-2013 11:49, Stephen wrote:
> The macro is forming waves in the high spots, though.
> Would it be possible to run the macro with different settings dependent on the
> slope of the ground?
Sorry, there must be a misunderstanding here. There are no waves formed.
The surface of the road with its tracks is a mesh; when the rain falls,
a plane surface is added inside the tracks to simulate water puddles.
>>> I think that if you wrote a tutorial, it would be much appreciated.
>>> In your own time of course. :-)
>> Not a bad suggestion maybe. I guess there are many who do like me: just
>> mess around without reading the available documentation properly ;-)
> I just read enough to get these things to work.  :-)
Yes, I recognize that attitude ;-) but in the end some more serious
study often becomes unavoidable.
I shall seriously think about a tutorial. There are a couple of things I
still do not understand and some that do not really work as I would
expect them to do, so there is still some work to do but in time I shall
note everything down comprehensively (I hope).
Date: 18 Dec 2013 08:15:01
Message: <web.52b19f83dff44c0fe9701c6d0@news.povray.org>
> I went back to the drawing board and took up TomTree more seriously with
> the Docs at hand. The result is here, in a fair weather view of the
> scene, and the stone pines as I intended them.
> My experience now shows that it is better to work first on a TomTree
> file, with a proof render to see how modelling progresses, and only
> after that read it into POV-Tree for a mesh export. Second, only use the
> mesh export for distant views and use the blob version for the foreground.
> Thomas
Nice and luminous landscape, remind me some 1800's painting (can't remember
who).
Goog work. With the same backgound image you can compose two different
ambiences, one dark and sad, the other sunny and happy.
Date: 18 Dec 2013 08:40:00
Message: <web.52b1a523dff44c0f7d8c6e9c0@news.povray.org>
In the wet image, it looks to me as if there are waves where the ruts in the
road are. Where the edge of the road is, a surge of water has formed, following
the mesh's surface.
True, I just keep putting off the day.
Date: 18 Dec 2013 09:57:25
Message: <52b1b7d5@news.povray.org>
> the mesh's surface.
Interesting. The power of illusion :-)
Date: 18 Dec 2013 09:59:33
Message: <52b1b855$1@news.povray.org>
> who).
Yes, it is all a matter of switches. When it rains, extra water bodies
are created and textures turn on their reflections.
Date: 18 Dec 2013 10:30:01
Message: <web.52b1beb3dff44c0f7d8c6e9c0@news.povray.org>
Indeed!
Date: 24 Dec 2013 09:45:00
Message: <web.52b99d5ddff44c0f91114470@news.povray.org>
> Thomas
I'm amazed at how complex Gancaloon has become, this is great! With it's
fantastic backstory you could produce your own high quality graphic novel based
in this place...
After seeing these trees I just downloaded tomtree so I can give it a try
myself, thanks for that.
www.McGregorFineArt.com
Date: 24 Dec 2013 10:09:00
Message: <52b9a38c$1@news.povray.org>
> in this place...
Thanks indeed, Robert. Gancaloon is slowly taking body, yes, while the
story behind it is partly in my head, partly noted down in sketchy bits
of text, and a growing corpus of images of course.
Gently prompted by Stephen :-) I am working on an elaborate extension to
the tomtree documentation. In due time it will appear here.
I have also been looking critically at the code. One of the things that
does not work well as it should are the pseudo random rotations. I would
like them improved but the code is extremely complex :-( and even if
succeeding, there would be the matter of a new POV-Tree version to
consider. Unfortunately Gena disappeared from the POV-Ray world...
