A quick test of UberPov's blurred reflections, not really sure it suits
the lantern which is why I only used a low setting for the roughness.
Probably need to add some surface normals to the paint texture to make
it look more like it should be blurred.
Of course the un-blurred version is also shown for comparison, I added
some SSLT settings to the blurred render for the marble plinth, probably
nowhere near the correct settings for marble but as I was experimenting..
I have to say though this is a great new feature and really easy to
use/control plus with a relatively low level of blurring the performance
is still pretty good (it does slow down though as you increase the
roughness).
Sean
Download 'lantern.png' (731 KB)
Download 'lanternblur.png' (775 KB)
Preview of image 'lantern.png'
Preview of image 'lanternblur.png'
> roughness).
> Sean
Isn't it great? I believe you got the blurring just right.
> Thomas
Especially if you are using HDR lighting as specular and roughness have no
effect on the surface so this will help a lot with those scenes.
Sean
> roughness).
> Sean
WOnderful work, seems so real. UberPov make life easy.
