POV-Ray : Newsgroups : povray.binaries.images : Inner values Server Time
11 Apr 2026 04:13:40 EDT (-0400)
  Inner values (Message 1 to 7 of 7)
Subject: Inner values
Date: 4 Nov 2013 17:32:14
Message: <5278206e@news.povray.org>
I had some CT scans taken this year due to medical issues
and found the data could be provided on DVD on request ;)
Images were in DICOM format and ImageMagick didn't like them,
but they contained uncompressed 16 bit pixel data so conversion
was mostly an issue of discarding the header and guessing width.
This is a stack of 91 horizontal slices that were turned into
a 3d pigment simply as a gradient of image_maps. This allows to
render an arbitrary slice or texture an arbitrary shape, which
is endless fun but doesn't provide too impressive images.
So I turned the pigment into a function and rendered it as
volumetric media, using a density color_map to enhance certain
brightness ranges. This last one looks quite promising.
Download 'inner_values.png' (357 KB)
Preview of image 'inner_values.png'
Subject: Re: Inner values
Date: 5 Nov 2013 04:32:56
Message: <5278bb48$1@news.povray.org>
I see your problem here; your head and arms have fallen off ;-)
Nice work. A brilliant example of putting a positive spin on a possible
problem.
John
Protect the Earth
It was not given to you by your parents
You hold it in trust for your children
Date: 5 Nov 2013 08:07:39
Message: <5278ed9b$1@news.povray.org>
Very nice render.
I suggest you to manage DICOM images with ImageJ instead of ImageMagick,
your next export will be simpler.
Paolo
Date: 5 Nov 2013 14:20:01
Message: <web.52794404c47b0aa3f427f2fd0@news.povray.org>
First, I really hope that the "possible problems" John mentioned are not to
serious. "Some CT" indicates a certain seriousness, I hope the best for you.
My first thought was, if it is more easy to convert the data to df3. I got the
impression that DICOM is not so far away from df3, after ripping off the
metadata. Seems to be big-endian too. May be one can exchange the headers of the
voxel bulk and get a df3 file. I don't know, only an idea.
The picture is fine but hard to interpret in some areas. If I look at the bottom
of the image I think I'm looking at your back in an upward direction. If I look
at the scapula and the clavicula only, I cannot tell apart what is in front and
what is back. Both are dominated by the green lung in large parts.
As you speak from publishing your data I can only remind you that DICOM files
contain medical metadata, which you will strip off first most likely. And
second, even the voxel data itself can reveal your disease to someone who is
able to read and visualise them properly. From your given image I cannot read
your disease but from detailed CT data may be... I only want to remind you of
that... If you will still do so: 1GB df3 files can be compressed to 3MB using
the highest compression rate with WinZip, so a DVD is not needed most likely.
Best regards,
Michael
Date: 5 Nov 2013 15:31:39
Message: <527955ab$1@news.povray.org>
Thanks!
It looked serious for a while but currently everything seems fine.
Yes df3 would have been an option. Using the image stack was simply
the way of least resistance (least work for me at the moment) and it
renders quite fast too.
It is a front view but difficult to tell with this "transparent
data. In fact the back view can be recognized by the scan bed that
is also included in the data.
I think that was a misunderstanding, I did not intend to publish
the DICOM files or derived data sets. I think the render itself is
not so problematic and unsuitable for medical diagnostics. Also it
is a clean scan and should only serve to show off my health ;)
Date: 6 Nov 2013 05:12:51
Message: <527a1623$1@news.povray.org>
> I had some CT scans taken this year due to medical issues and found
Very nice, and a good candidate for a new "ykybrtlw" sentence:
"You know you've been Raytracing too long when... you ask your doctor
for the CT scan data". ;)
Jaime
Date: 6 Nov 2013 13:15:00
Message: <web.527a86ffc47b0aa3dc6d9d530@news.povray.org>
> Thanks!
I really like to read this. If I misunderstood your sentence about a DVD
distribution please forgive me. In a way Jaime is right and not. In Germany a
lot of radiologists are giving away the data together with an application to
view the data to their patients. They ask their patients if they will have it,
you must not ask them to can render the data. I had to judge several scans from
my mother's severe osteoporosis. For some reason she relies more on my amateur
opinion than on the practitioners. I have worked for some 15 years as a male
nurse mainly in oncology so I have the one or other experience with CT data but
I'm far away from being an expert.
Best regards,
Michael
