POV-Ray : Newsgroups : povray.binaries.images : A method creat uniform thick shell Server Time
18 May 2024 23:24:03 EDT (-0400)
  A method creat uniform thick shell (Message 1 to 10 of 45)
Subject: A method creat uniform thick shell
Date: 21 Oct 2013 03:05:06
Message: <web.5264d1b954cff585cc1fd1150@news.povray.org>
I have a method using isosurface render spheroid shell below.
use this two function
#declare f_spheroid=function(var1,var2,var3, a,b){
var1*var1/a/a+var2*var2/a/a+var3*var3/b/b-1
#declare f_spheroid_normalized=function(var1,var2,var3, a,b){
f_spheroid(var1,var2,var3, a,b)
/sqrt(4*(var1*var1+var2*var2)/pow(a,4)+4*var3*var3/pow(b,4))
//than difference these two isosurfaces
difference{
isosurface{
function{f_spheroid(x,y,z,1,3)}
isosurface{
function{f_spheroid_normalized(x,y,z,1,3)+thickness}
Download 'spheroid shell diffuse .jpg' (28 KB)
Preview of image 'spheroid shell diffuse .jpg'
Subject: Re: A method creat uniform thick shell
Date: 21 Oct 2013 03:30:01
Message: <web.5264d704dce0719acc1fd1150@news.povray.org>
And the transparency version below:
this method just modify mathematic function f by divide a factor
sqrt((∂f/∂x)^2+(∂f/∂y)^2+(∂f/∂z)^2)
It can be used in many well-behaved mathematic function(differentiable and
continue function and no singularity I think...)
Download 'spheroid shell transparency.jpg' (28 KB)
Preview of image 'spheroid shell transparency.jpg'
Date: 21 Oct 2013 03:45:00
Message: <web.5264daf0dce0719acc1fd1150@news.povray.org>
It can't show the symbol...
....I mean
f_normalized(x,y,z)=
f(x,y,z)
/sqrt(
(partial derivative of f(x,y,z) in x)^2
+(partial derivative of f(x,y,z) in y)^2
+(partial derivative of f(x,y,z) in z)^2
then set a threshold to displacement it by a (not too large) thickness.
Date: 21 Oct 2013 06:50:01
Message: <web.5265061bdce0719acc1fd1150@news.povray.org>
This is another function and picture:
#declare CSG_OVERLAP=0.000001;
#declare f_quartic=function(var1,var2){
pow(var1,4)+2*var1*var1*var2*var2+var1*var1-1
#declare f_quartic_normalized=function(var1,var2){
f_quartic(var1,var2)
/sqrt(16*pow(var1,6)+(48*var2*var2+16)*pow(var1,4)+(16*pow(var2,4)+16*var2*var2+4)*var1*var1)
difference{
isosurface{
function{f_quartic(y,x)}
max_gradient 10
contained_by{box{<-3,0,-1><3,1.3,3>}}
all_intersections
isosurface{
function{f_quartic_normalized(y,x)+0.04}
max_gradient 10
contained_by{box{<-3,0-CSG_OVERLAP,-1-CSG_OVERLAP><3,1.3,3+CSG_OVERLAP>}}
all_intersections
Download 'isosurface shell.jpg' (28 KB)
Preview of image 'isosurface shell.jpg'
Date: 24 Oct 2013 08:30:01
Message: <web.5269119cdce0719aa8e6d28b0@news.povray.org>
> difference{
> isosurface{
> max_gradient 10
> all_intersections
> isosurface{
> max_gradient 10
> all_intersections
I've tried to use yours functions but I have an error message:
Parse Error: Floating-point exception detected in function
'f_quartic_normalized'. Your function either attempted a division by zero, used
a function outside its domain or called an internal function with invalid
parameters.
I don't know what happens...
Date: 24 Oct 2013 08:30:02
Message: <web.5269127edce0719aa8e6d28b0@news.povray.org>
> difference{
> isosurface{
> max_gradient 10
> all_intersections
> isosurface{
> max_gradient 10
> all_intersections
Ooops! I don't know why but with pov 3.7 it works! Not with 3.6!
Date: 26 Oct 2013 03:45:00
Message: <web.526b72eddce0719a965ff2ad0@news.povray.org>
> parameters.
Hum...
I just tried and this have parse error in pov-ray 3.6 truly.
Or you can use below function instead:
select(
abs(var1)-0.01,
-1,
Date: 26 Oct 2013 11:35:01
Message: <web.526bdfe2dce0719a84f168e50@news.povray.org>
I explain this method. The basic concept is just that specifying different
threshold values to a function will produce different but similar isosurfaces.
For instance, in the right picture, upper surface of the shell is
y-sin(2.5*x)= 0.08 , lower surface is
y-sin(2.5*x)=-0.08
Use csg difference in pov-ray between these two isosurface objects can produce a
shell.
//---------------------code----------------------------
#declare f_sin=function(var1,var2,k){
var2-sin(k*var1)
difference{
isosurface{
function{f_sin(x,z,2.5)-0.08}
max_gradient 2
contained_by{box{<-5,-1,-1.5><5,2,1.5>}}
all_intersections
isosurface{
function{f_sin(x,z,2.5)+0.08}
max_gradient 2
contained_by{box{<-5,-1-CSG_OVERLAP,-1.5-CSG_OVERLAP><5,2+CSG_OVERLAP,1.5>}}
all_intersections
//-----------------------end of code-----------------------
But the shell's thickness is not a canstant. I found a method modifying the
function to let it have uniform thickness at least in a small range.
Download 'sin.jpg' (130 KB)
Preview of image 'sin.jpg'
Date: 26 Oct 2013 11:55:00
Message: <web.526be5c5dce0719a84f168e50@news.povray.org>
The method had been represented the other day. The modified function for sin
function is
(y-sin(2.5*x))/sqrt(2.5^2*cos(2.5*x)^2+1)= 0.08 ,
(y-sin(2.5*x))/sqrt(2.5^2*cos(2.5*x)^2+1)=-0.08
                                           0.08 represent the thickness/2
Then use pov-ray's csg difference:
//---------------------------code---------------------------
var2-sin(k*var1)
#declare f_sin_normalized=function(var1,var2,k){
f_sin(var1,var2,k)
/sqrt(k*k*pow(cos(k*var1),2)+1)
difference{
isosurface{
function{f_sin_normalized(x,z,2.5)-0.08}
max_gradient 2
all_intersections
isosurface{
function{f_sin_normalized(x,z,2.5)+0.08}
max_gradient 2
all_intersections
//--------------------------end of code--------------------------
Drew the picture!!
Download 'sin_normalized.jpg' (117 KB)
Preview of image 'sin_normalized.jpg'
Date: 26 Oct 2013 12:10:00
Message: <web.526be845dce0719a306548240@news.povray.org>
Nice!
