POV-Ray : Newsgroups : povray.binaries.images : df3 strangeness Server Time
29 Oct 2025 04:07:37 EDT (-0400)
  df3 strangeness (Message 1 to 10 of 20)
Subject: df3 strangeness
Date: 28 Sep 2013 11:02:39
Message: <5246ef8f@news.povray.org>
Now, how would you explain this?
I turned the models 90 degrees: we are looking along the x-axis of the
object to visualize.
Download 'gt_df3_test.png' (108 KB) Download 'makedf3object_.png' (40 KB)
Preview of image 'gt_df3_test.png'
Preview of image 'makedf3object_.png'
Subject: Re: df3 strangeness
Date: 28 Sep 2013 11:19:14
Message: <5246f372$1@news.povray.org>
Le 28/09/2013 17:02, Thomas de Groot nous fit lire :
> Thomas
what is strange ?
The df3 describes a unit-cube, with distinct resolution along each axis,
but it is only a unit-cube.
So, with such model, you need a scale around 3 or so along the vertical
axis on the field to restore the kind of posture you had on the original.
Or did I missed again some red circle ?
Date: 28 Sep 2013 11:25:01
Message: <web.5246f4546cde29e7f5bef60@news.povray.org>
> Thomas
Hi Thomas,
I can only guess your problem, but I think you are missing some structure (e.g.
the ribs) here.
May be you can try a higher resolution. I use the following ini-file for my
ghost (just running for another pose):
Antialias=Off
;Input_File_Name=ctdress_.pov
Input_File_Name=cteyes_.pov
;Input_File_Name=cthaare_.pov
;Input_File_Name=ctkleid_.pov
Height=512
Width=512
Initial_Frame=1
Final_Frame=512
;Subset_Start_Frame=1
;Subset_End_Frame = 120
Initial_Clock=0
Final_Clock=1
Output_File_Type=T
Best regards,
Michael
Date: 29 Sep 2013 03:01:25
Message: <5247d045@news.povray.org>
On 28-9-2013 17:19, Le_Forgeron wrote:
> what is strange ?
Well, /that/ is exactly what I am wondering. Does the df3 /always/ scale
to the unit-sized box? whatever the bounding box of the object is? I
probably missed something but I do not remember having read this anywhere.
That puts my earlier observation of squeezing into another light...
No, more probably along the z-axis as that is visibly stretched out.
<grin> no.
Date: 29 Sep 2013 03:09:39
Message: <5247d233$1@news.povray.org>
> the ribs) here.
I know. That is a resolution problem most probably. My wondering was
about the stretching along the z-axis of the df3 compared to the
original model. I later guessed (and Le_Forgeron confirmed) that df3
files scale to the unit-sized box which I had not been aware of at all.
By chance my first test was with an almost spherical object ;-)
If so, it makes the use of df3 files from selected objects a bit more
tricky to use, I mean, an extra transformation is needed, back to the
original bounding box size using min_ and max_extent.
Date: 29 Sep 2013 04:12:22
Message: <5247e0e6$1@news.povray.org>
Le 29/09/2013 09:01, Thomas de Groot nous fit lire :
>> what is strange ?
Citing 3.6 documentation, first sentence:
> http://www.povray.org/documentation/view/3.6.1/374/
The density_file pattern is a 3-D bitmap pattern that occupies a unit
cube from location <0,0,0> to <1,1,1>.
The same sentence was already in 3.1 documentation
Date: 29 Sep 2013 04:24:10
Message: <5247e3aa$1@news.povray.org>
Which confirms my diffuse reading.... ;-)
Date: 29 Sep 2013 08:02:15
Message: <524816c7@news.povray.org>
There is still something that I do not understand.
I have now scaled back the df3 files, using for a defined object Obj:
#local Min   = min_extent(Obj);
#local Max   = max_extent(Obj);
#local Size  = Max-Min;
Superposing the object and the df3 files, flipping the df3 files along y
(Gilles Tran), and resizing the df3 files, I note the following:
1) the x-axis needs also to be flipped! Visible especially with
asymmetrical objects (skeleton)
2) the skeleton df3 needs an additional x-axis scale correction: scale
<-3.0,-1,1>*Size
3) the head df3 needs a /different/ x-axis scale correction: scale
<-2.3,-1,1>*Size
The two images show orthographic views.
Question: If the df3 are made to a unit-sized box, why does the x-axis
need a correction different from object to object?
Download 'gt_df3_test_1.jpg' (54 KB) Download 'gt_df3_test_2.jpg' (73 KB)
Preview of image 'gt_df3_test_1.jpg'
Preview of image 'gt_df3_test_2.jpg'
Date: 29 Sep 2013 08:27:15
Message: <52481ca3$1@news.povray.org>
A tentative answer to the question:
Could it be that the image format in which the tga slices are rendered
influences the final result? In other words, should objects be rendered
using a /square/ image format (1:1 ratio) in the first place? I blindly
followed Gilles Tran's advice to use a 1.33 ratio. This might be
irrelevant for clouds but not for other objects...
Date: 29 Sep 2013 08:38:13
Message: <52481f35@news.povray.org>
Le 29/09/2013 14:27, Thomas de Groot nous fit lire :
> Thomas
Do we have the sources of tga2df3 ?
