POV-Ray : Newsgroups : povray.binaries.images : Aftermath revisited Server Time
27 May 2026 23:49:59 EDT (-0400)
  Aftermath revisited (Message 31 to 40 of 50)
Subject: Re: Aftermath revisited: proof of concept
Date: 28 Aug 2013 03:05:07
Message: <521da123$1@news.povray.org>
On 28-8-2013 1:06, s.day wrote:
> Nice image, for me I think the sky is the biggest problem, while very dramatic
> looking the shape of the clouds seems a bit odd. Then again I have often looked
> at a great real sky and thought to myself if I were to render that exactly as it
> is people would say it looked fake, and who can imagine what the sky would look
> like after such an event..
Who knows? I think that realism is not really an issue here. Personally,
it does not strike me as too odd.
> I am interested in your texturing issue but have no experience with proximity
> patterns. I do wonder though if something like below would work..
> [snip]
> #declare TMGrad = texture
>    gradient y
>    texture_map {
>    [ 0.35 TMSlime ]
>    [ 0.45 TMProx ]
> As I say I have never used proximity patterns so I may be way off ;-)
That might work indeed. I am almost sure it would. I shall test that
asap and let you know. Thanks!
Date: 28 Aug 2013 03:58:14
Message: <521dad96$1@news.povray.org>
Alas! Doesn't work. Result in weird interference patterns.
Date: 28 Aug 2013 04:20:01
Message: <web.521db256cf332d2844d5ed0a0@news.povray.org>
> Thomas
Shame, it would certainly add something to the image if you can find a way of
doing it. Still it is a great scene even without the stain/slime addition.
Sean
Date: 28 Aug 2013 10:40:01
Message: <web.521e0b13cf332d28dd2ebc560@news.povray.org>
Very nice.
I think the clouds look fine.
_If_ you wanted to play with them, I might add some of the reddish smog colors,
and / or perhaps "flatten" the nearer clouds so they don't look quite so
shell/sphere-like.
To be honest, I had to search for the girl in the render. (Hey, I'm getting
older...)  Perhaps consider extending a shaft of light down to point at, but not
touch her, or just highlight a portion of her leg, or the ledge to the side of
her - to direct the eye of the viewer to the solitary figure in the scene.
Maybe change the angle slightly or increase the radius of the crash grid to open
up a little space behind her and increase her silhouette.
Increasing the radius of the cage would be good - perhaps you could add a
dent/deformation or two to give the impression that it fell from the sky and
bounced once or twice before coming to rest?  The sphere itself looks great -
maybe the cage could benefit from some more "crust" or clumps, or dangling bits
of slime / algae / plant matter adhering from the impact - settling over time
and drooping down from one of the aforementioned dents...
I like the mist in the distance - do you think some mist or small curls of
denser mist in the foreground would add anything?
I think the lightning has a place - but farther in the distance.  Maybe with a
bit more yellow coloration?
Not sure what your thoughts are about the skeleton - too red?  Go with more
white and that sort of surface cracking/pitting?  Maybe a bit or two of crud /
slime on that too, and perhaps a little light filtering in from an opening in
the clouds?
I like the tree remnant in front of the sphere.  Maybe move it away a bit and
have its geometry and condition reflect its fate as the shattered victim of the
impacting sphere?
Great work - well beyond my current skill level!
I always enjoy seeing the amazing results and creative ideas that get
implemented here.  Thanks for the inspiration and sharing goals to work towards!
Date: 29 Aug 2013 03:15:57
Message: <521ef52d@news.povray.org>
Sean, putting my admin's cap on: May I remind you that you need to vote
for *ALL* the TC-RTC entries? I see that you have not yet done so
presently. If you don't, you know the consequences ;-)
Date: 29 Aug 2013 08:30:00
Message: <web.521f3e1ecf332d2844d5ed0a0@news.povray.org>
> Thomas
Thanks Thomas,
Don't worry, I intend to do this before end of month, I always like to push a
deadline to the last minute.
Seab
Date: 1 Sep 2013 07:35:33
Message: <52232685$1@news.povray.org>
On 28-8-2013 16:37, Bald Eagle wrote:
> Very nice.
> shell/sphere-like.
Controlling the colours is rather tricky in a multi media environment. I
am still trying to get the white over-exposed part a bit darker, so I
shall do my best with some reddish hues. The shell-like aspect is indeed
something to look into. Not too extreme as it might suggest some kind of
vertical whorls, but then again...
In following versions she will be better visible mainly because of a
better flash control and behind camera reflection (just a dull screen
but effective for filling in a bit the darker parts).
Hmm, no. In my mind time travelling is not equivalent to a cross country
race :-) It has its own problems though like falling from the sky (the
Roswell incident) or the equivalent of coinciding surfaces: coinciding
objects (the Tunguska explosion) ;-)
Hmm, yes, that might be an interesting addition.
Maybe. In any case it is already yellow but could be more. Tests needed.
> the clouds?
Just the image_maps of the models used here. Not really natural perhaps
and could gain from some more texturing.
> impacting sphere?
No. The stumps are the result of the wild fires following the Chixulub
impact.
Thank you indeed. Glad to inspire others in turn. I am indebted myself
to a large number of people here over the years and still, I have not
yet reached their level of mastery.
Date: 1 Sep 2013 18:15:08
Message: <5223bc6c@news.povray.org>
Am 01.09.2013 13:35, schrieb Thomas de Groot:
>> Maybe with a
Don't.
Lightning bolts are exactly /how/ hot? Some 20-30 kK, right? Color
temperature (i.e. the visible portion of the corresponding blackbody
radiation) doesn't get any more blue than that. And with the air being
turned into a plasma, emission from electron energy state changes within
individual atoms plays only a minor role compared to the thermal
emissions from free electrons and ions.
Date: 2 Sep 2013 12:46:30
Message: <5224c0e6$1@news.povray.org>
>>> Maybe with a
> Don't.
Add to that that nitrogen, the most abundent gaz, tend to produce blue
and UVs when exited. Next is oxygen whitch tend to glow red.
Date: 3 Sep 2013 03:03:33
Message: <522589c5$1@news.povray.org>
On 2-9-2013 0:15, clipka wrote:
> Don't.
Indeed. However, I read somewhere that with distance from the viewer the
colour becomes more yellowish
http://www.ccmr.cornell.edu/education/ask/?quid=1271
In the image, I think I am going to use a more bluish hue.
