POV-Ray : Newsgroups : povray.binaries.images : The other 13,400 pieces (plus 100,000-or-so you may have seen before) Server Time
26 Jun 2026 03:33:03 EDT (-0400)
  The other 13,400 pieces (plus 100,000-or-so you may have seen before) (Message 20 to 29 of 39)
Subject: Re: The other 13,400 pieces (plus 100,000-or-so you may have seen before)
Date: 19 Aug 2013 15:31:51
Message: <521272a7$1@news.povray.org>
On 17/08/2013 7:39 PM, MichaelJF wrote:
> Stephen <mca### [at] aolcom> wrote:
>> On 17/08/2013 6:32 PM, MichaelJF wrote:
>>> What is the deadline for that? I just started a new rendering of my rubber ducks
>>> with focal blur which will take a bit longer I fear.
>> When would you like it to be? I've set the "End of upload" for the end
>> of this month.
> That should prove no problem.
Good! I see that you have uploaded it and very fine it is too.
Thank you for testing.
Regards
Subject: Re: The other 13,400 pieces (plus 100,000-or-so you may have seenbefore)
Date: 20 Aug 2013 04:20:20
Message: <521326c4$1@news.povray.org>
On 19-8-2013 21:30, Stephen wrote:
> There is no pleasing some folk. I promise that I will give you a bit
> more than 5 for both. Although I'm not sure about "on topic". :-P
Think about the different meanings of /elements/ ....  ;-)
Date: 20 Aug 2013 15:26:12
Message: <5213c2d4$1@news.povray.org>
Do you mean Earth, Water, Air, Fire, and Aether?
Regards
Date: 20 Aug 2013 16:30:41
Message: <5213d1f1$1@news.povray.org>
That's only one meaning, one of the alchemical interpretation.
Alchemical also have:
earth, water, fire, air
earth, water, fire, air, wood
earth, water, fire, air, metal
earth, ooze, water, ice, air, smoke, fire, magma
and probably several others depending on the author and local traditions.
I've seen: wood, lightning/energy, fire, air and water
Then, there are the chemical elements, then the mathematical
definitions, then it's found in legal/legislation context, then...
Date: 20 Aug 2013 17:17:47
Message: <5213dcfb@news.povray.org>
On 20/08/2013 9:30 PM, Alain wrote:
> Then, there are
Element ary.
Regards
Date: 21 Aug 2013 03:33:53
Message: <52146d61$1@news.povray.org>
a metal like copper is an /element/
Date: 21 Aug 2013 06:45:00
Message: <web.521499ee9d8de3c77d8c6e9c0@news.povray.org>
I'll match your metallic copper and raise you Hydrogen plasma. ;-)
Date: 21 Aug 2013 07:24:03
Message: <5214a353@news.povray.org>
Hmm... what to do? what to do...?
Two gold nuggets.
Date: 21 Aug 2013 13:03:47
Message: <5214f2f3$1@news.povray.org>
> Two gold nuggets.
Okay, I fold and in only 3 dimensions.
Regards
Date: 22 Aug 2013 02:54:07
Message: <5215b58f@news.povray.org>
>> Two gold nuggets.
Nah! That's cheap. You can walk out through the fourth.
