POV-Ray : Newsgroups : povray.binaries.images : The other 13,400 pieces (plus 100,000-or-so you may have seen before) Server Time
26 Jun 2026 01:41:46 EDT (-0400)
  The other 13,400 pieces (plus 100,000-or-so you may have seen before) (Message 11 to 20 of 39)
Subject: Re: The other 13,400 pieces (plus 100,000-or-so you may have seen before)
Date: 15 Aug 2013 15:10:01
Message: <web.520d270157607c6e6c54ff8e0@news.povray.org>
My comment about hitting the topic was more intended as an observation and not
really as criticism.
As for the "golf" topic, my first thought was a car, and not Tiger Woods;-) But
this may be biased being German.
And for the voting. You have only small influence with your work. People does
not ever look at the pictures and try a fair vote. Sometimes they like you,
sometimes they dislike you and vote you down. My lowest voting for my "Ariadnes
Garden" picture was 5,5,5. I didn't missed the topic but I used an image
designed for an earlier round (and admited that), which seems to be an
unforgivable thing to some persons.
In this case I can accept the artistic and concept vote, but not the technical
one, having used occlusion map baking, splines to create the general shape of
the creatian labyrinth and to have the grass down where the ball was moved. And
a lot of other things. More work in this one than in other ones I did. But
technically only 5 for one voter. One has to accept that.
Best regards,
Michael
Date: 16 Aug 2013 03:21:00
Message: <520dd2dc$1@news.povray.org>
I know but it is one of the things that niggle me. I think that the
voting categories are outdated fine for when the IRTC started but the
technical one does not make sense to me nowadays.
For me golf is a good walk ruined. ;-)
Well you are not alone, I once got 3-3-3.  There is one member, who
entered the IRTC as well. Often gave those sort of scores to images he
found displeasing.
That is what I mean. Other than detailing what you have done and leaving
it up to the voter to understand the difficulty. It won't be credited.
As far as I know, occlusion map baking may be easy to do and a bit of a
cheat. I've never tried to use it. So how can I, or anyone like me, give
an informed vote?
Accept what? That he is an idiot or a spoiler?
Long ago I realised that when someone disagreed with me on artistic
matters. It did not mean that I was wrong and generally meant that they
only had a superficial understanding of the subject or they were just a
blowhard. ;-)
Regards
Date: 16 Aug 2013 13:50:01
Message: <web.520e654e57607c6ebab83e460@news.povray.org>
> found displeasing.
> an informed vote?
> blowhard. ;-)
> Regards
>      Stephen
Yes, I know. We had a discussion about the technical score at the TC forum
resulting in that it should not be deleted. My personal opion has not changed.
With TC RTC all other systems to generate CG are accepted and a comparison of
technical difficulties is not possible. Ives uses Autodesk software, Normand has
it's own Java Open GL software and you cannot judge their technical
difficulties. So the technical score should go IMO.
To address the "not meeting the topic" issuue: my rubber duck image contains a
certain element of geologe called "water" ;-) No, I will not have it into the
contest. But my wife will have a cup with the inscription of "Mom is the best"
or something like that. So I may open an account at Zazzle next days.
Best regards,
Michael
Date: 16 Aug 2013 15:49:18
Message: <520e823e@news.povray.org>
Let's leave that discussion for later. We are testing some changes to
the site, just now. It looks like we will be able to run two Challenges
at the same time. And we will be able to set our own start and end
dates. Nor will we be limited to the list of book titles in the "vote
for the next topic". Once we have the mechanics sorted out we can look
t0wards fixing some other things.
> certain element of geologe called "water";-)  No, I will not have it into the
> contest.
You could upload it to the Animation section to help test. The Animation
section will soon be the new Challenge 2 Stills section.
Be aware that the section is being tested and may close and reopen as
another contest.
It is a great image, a happy image.
Regards
Date: 17 Aug 2013 13:35:02
Message: <web.520fb3bc57607c6e8a7d57520@news.povray.org>
> another contest.
What is the deadline for that? I just started a new rendering of my rubber ducks
with focal blur which will take a bit longer I fear. I noticed that only you has
uploaded a test image so far.
Best regards,
Michael
Date: 17 Aug 2013 14:14:23
Message: <520fbd7f$1@news.povray.org>
When would you like it to be? I've set the "End of upload" for the end
of this month.
>I noticed that only you has uploaded a test image so far.
No one else knows about it, that is why. ;-)
Regards
Date: 17 Aug 2013 14:40:03
Message: <web.520fc36357607c6e8a7d57520@news.povray.org>
> of this month.
That should prove no problem.
Thanks,
Michael
Date: 18 Aug 2013 18:30:02
Message: <web.52114a2c57607c6ed3f534640@news.povray.org>
> found displeasing.
Care to give a hint who that member is?
I went back and looked at the scores of the past few rounds to get a good idea
of an average score (for what it's worth, 12-12.5). The worst I saw was a Topic
score of 2 for Iron Lady in the Woman round. I assume this was a political
remark.
Maybe you should give every voter an average of what he gave the other images.
Might slow some of that down. Heck, you might be better off just giving the win
to whoever posts the most comments.
As far as Technical, you're right, I don't understand what TDG does with his
many programs, and most current POVvers don't understand what goes in to
hand-coding.
Quickie image creators want to see quickie-image posts, masochists want to see
other masochists' posts, and either group will find justifications for
dismissing the other. No changing that. I expect a 5 or worse for Topic and
(even after >100 hours of work) wouldn't be surprised to receive the same for
Technical.
Date: 19 Aug 2013 15:30:30
Message: <52127256@news.povray.org>
>> found displeasing.
No, not really. ;-)
It is not, IMO, the right thing to do.
> remark.
Well, I started to mirror his scoring to me, to him and I think that
worked. Especially after I became Admin of the site. :-)
Now that is a very good idea but would be hard to implement, fairly.
> hand-coding.
Yeah, both Thomas and I agree that a "one score for all" would be
better. That, I hope, will come soon. First we want to get the second
Challenge up and running then we can fine tune everything.
How true but when we get a second Challenge up and running (which should
be very soon) we can cater for both.
> Technical.
There is no pleasing some folk. I promise that I will give you a bit
more than 5 for both. Although I'm not sure about "on topic". :-P
Regards
Date: 19 Aug 2013 15:31:51
Message: <521272a7$1@news.povray.org>
>> of this month.
Good! I see that you have uploaded it and very fine it is too.
Thank you for testing.
Regards
