POV-Ray : Newsgroups : povray.binaries.images : All chopped up Server Time
25 Jun 2026 22:15:47 EDT (-0400)
  All chopped up (Message 1 to 10 of 10)
Subject: All chopped up
Date: 4 Aug 2013 10:14:31
Message: <51fe61c7@news.povray.org>
I have tried this several times, but this is the furthest I've gone ;-)
The original object has a glass texture.
testjunk_ab_0011, 30 slices, sphere with a smaller radius
testjunk_ab_0010, 80 slices, sphere
testjunk_ab_0009, 80 slices, blob
Create array +2, empty outside grid
Scan the object, initialize array element
Scan array, place object if at least 1 of 6 faces not defined (not inside)
Comments welcome:
Stephen S
Download 'testjunk_ab_0011.png' (258 KB) Download 'testjunk_ab_0010.png' (334 KB) Download 'testjunk_ab_0009.png' (102 KB)
Preview of image 'testjunk_ab_0011.png'
Preview of image 'testjunk_ab_0010.png'
Preview of image 'testjunk_ab_0009.png'
Subject: Re: All chopped up
Date: 4 Aug 2013 14:15:01
Message: <web.51fe9947f383f82d593920760@news.povray.org>
The blob version looks good... whatever it is ;) Now, should you choose to do
so, use a pattern to scale &/| displace the spheres comprising the object. You
can make rust or some other type of surface damage that way. Might be difficult
hiding the underlying matrix, though.
Sam
Date: 4 Aug 2013 15:43:04
Message: <51feaec8$1@news.povray.org>
> Might be difficult
> Sam
Currently the blob sphere component is not scaled to match the non square
grid. I would also like to add a slight randomnes. Higher counts get
smoother, but longer parse times.
First on the todo list might be:
save to .inc file
use different x,y,z steps, for non square scans
have a mesh type output
Stephen S
Date: 4 Aug 2013 20:35:01
Message: <web.51fef2b8f383f82d540235480@news.povray.org>
Is there going to be an anaglyph version?
(I didn't see one for last month.)
Date: 4 Aug 2013 20:40:01
Message: <web.51fef403f383f82d791465610@news.povray.org>
Yes :-)
On something with more detail.
Stephen S
Date: 5 Aug 2013 03:10:54
Message: <51ff4ffe$1@news.povray.org>
What if the spheres were placed randomly?
Date: 5 Aug 2013 08:18:25
Message: <51ff9811$1@news.povray.org>
Or what if the sphere were placed in the more compact packing scheme ?
(of spheres around a sphere)
(instead of cube / square, use shifted planes of hexagons)
(There is two variants: ABA and ABCA)
Just because nobody complains does not mean all parachutes are perfect.
Date: 11 Aug 2013 19:40:01
Message: <web.52082003f383f82da1dd42dc0@news.povray.org>
> Comments welcome:
> Stephen S
I have added some randomness to the placement and strength of the blob
component. Next is to add some kind of save to file.
Stephen S
Download 'testjunk_ad_a.png' (108 KB)
Preview of image 'testjunk_ad_a.png'
Date: 13 Aug 2013 15:30:59
Message: <520a8973$1@news.povray.org>
> "StephenS"  wrote in message news:51fe61c7@news.povray.org...
Some anti-aliasing would be interesting: smaller spheres where the sampled
object only partially intersects your grid.
Date: 15 Aug 2013 20:40:01
Message: <web.520d7410f383f82d16a700210@news.povray.org>
I can now save the result to a file.
I like the result on the text.
Comments welcome:
Stephen S
Download 'cut_up.png' (288 KB)
Preview of image 'cut_up.png'
