I guess this image doesn't need too much explanation. Another feature to
be included in that branch of mine.
Download 'read_text.png' (170 KB)
Preview of image 'read_text.png'
Reading and rendering a text document could generate some interesting
things.
Am 28.07.2013 14:04, schrieb clipka:
Spiced it up a bit.
Download 'read_text.png' (419 KB)
At the price of placing an extra parsing burden on the artist, data files can
have more flexible formats, and the scene file can recover from data format
errors. The parsing burden can be considerable, but the difficult is usually
preferable to the impossible; plus, the burden may be offset by not having to
massage the data files in advance.
More power to the POVver!
So now file-format converters can be written in POV SDL?
This should get at least fairly close. I don't remember what all POV can do
with strings once it reads them.
I remember trying to use POV with no idea how to even _run_ someone's
C-language file converter, much less adapt that file converter to my needs.
-Shay
"clipka" <ano### [at] anonymous org> wrote in message
news:51f508d5@news.povray.org...
Nice feature.
Is it possible to read pdf text files to render wordle clouds?
Up to now I've converted pdf to large imagemaps, but even at large scale you can
see artefacts like in the image attached.
Norbert Kern
Download 'wordle3.jpg' (419 KB)
Preview of image 'wordle3.jpg'
Le 28/07/2013 20:06, Cousin Ricky nous fit lire :
Is it me, or was it just the capability to read a single line of text ?
(overloading the old read(file_handle, variable...) )
I do not know what Cousin Ricky saw.
Am 28.07.2013 23:13, schrieb Le_Forgeron:
What he saw was the /potential/ that is in such a seemingly trivial
feature: It enables you to read not just POV-Ray's quirky version of CSV
data files, but any text-based format you like - .obj files, XML files,
plain old text, whatever you like. You "only" need to write SDL code to
parse the text you read.
Am 28.07.2013 21:11, schrieb Shay:
Exactly :-)
> do with strings once it reads them.
Its string manipulation arsenal is actually painfully poor (as I noticed
when writing the syntax-highlighted version of the scene) - it doesn't
even have a "find in string" function, and the substr() function is a
PITA to use; but if you are willing to accept long parsing times the
built-in functions are sufficient to get you wherever you want to go.
Am 28.07.2013 21:28, schrieb Norbert Kern:
> Nice feature.
PDF files are binary files, so you'll have to convert them to plaintext
first. (In many cases selecting the whole text and cut-and-pasting it
into notepad should do the job.)
