POV-Ray : Newsgroups : povray.binaries.images : CSG Challenge Server Time
28 May 2026 02:48:35 EDT (-0400)
  CSG Challenge (Message 19 to 28 of 58)
Subject: Re: CSG Challenge
Date: 25 Jul 2013 03:14:46
Message: <51f0d066$1@news.povray.org>
Very good indeed, except - as Shay mentioned - the tori in the holes.
They should be curved too. That was one of my main puzzles about Shay's
image.
Date: 25 Jul 2013 03:20:21
Message: <51f0d1b5$1@news.povray.org>
>> No, no non-Euclidian math is needed here. One can solve the puzzle only with
>> Euclid and Pythagoras but one has to think in polar coordinates instead of
>> Euclidian ones and heavily use rotate.
> Isn't that non-Euclidian?
Seems like a confusion between the terms "cartesian" and "Euclidean".
Cartesian is just a coordinate system (xyz), along with polar,
spherical, intrinsic etc, all can be (and usually are) used with
Euclidean geometry.
In non-Euclidean geometry essentially it it not guaranteed that two
straight parallel lines in a plane never cross (which it is in Euclidean
no matter what coordinate system you use to describe the lines). POV-ray
is in no way set up to handle non-Euclidean geometry!
Date: 25 Jul 2013 15:09:23
Message: <51f177e3$1@news.povray.org>
"clipka"  wrote in message news:51f0ca6b@news.povray.org...
> You'd actually have to ask Chris Cason whether that Wishlist still exists;
> I /think/ the books and hardware that were on that list have all been
> donated by now.
I think I found the list. You're right: empty. Every programmer I know is
constantly reading books. Someone should put something up there.
> So what you are saying is that you also beveled the transition between the
> "petals" and the tori forming the end of the small-hole extrusions; is
> that the essence of it?
I /think/ so. For each small hole, I used 1 object for the hole, 1 object to
bound, and 16 objects to build the extrusion, though the 16 could be
optimized to 14. That's probably where the majority of the object count
difference can be found.
> Sounds like you used clipping as a substitute for intersection, is that
> what you're saying?
Correct. I didn't sit down and count intersection tests to make sure that
was the most efficient way. Maybe it isn't.
> Okay, okay - I'll try to come up with formulae for all those parameters...
As far as I'm concerned, hand-coding is hand-coding, by hook or by crook
(though my way seems a lot more fun).
Priggish professional programmers are the reason I don't post code in these
forums. One told me that I shouldn't be coding algorithms if I don't know
what a stack is. That's like my saying he shouldn't be writing newsgroup
posts if he doesn't know what a chiasmus is.
-Shay
Date: 25 Jul 2013 17:15:02
Message: <web.51f194e13a6d0c04eb1d220f0@news.povray.org>
Cool CSG work, Shay!
For some reason I knew clipka would be the winner (that train he was working on
a while back was a clue).
The attached image shows how far I got yesterday before quitting. Two features
are missing, AFAIK: the lobe tips aren't rounded; the lobe holes are
nonexistent. But at least it's all wrapped up in a (somewhat) tidy macro :)
Sam
Download 'shaycsgchallengeb.png' (381 KB)
Preview of image 'shaycsgchallengeb.png'
Date: 25 Jul 2013 18:01:11
Message: <51f1a027@news.povray.org>
LOL ... my money was on you ;-) Nice job!
Date: 25 Jul 2013 18:28:54
Message: <51f1a6a6$1@news.povray.org>
Clipka posted the CSG first. You posted the math first. Can we call it a
tie?
That train was impressive. Used prisms*, so, imo, a whole other animal.
A CSG (primitive primitives) sub-round of the tcrtc might draw some
interesting entries.
-Shay
* if you count prisms (and sweep approximations), you have to (?) count
triangles, and is it really CSG at that point? It's a somewhat arbitrary
distinction, but "real" CSG makes for a better game, imo.
"Samuel Benge" <stb### [at] hotmailcom> wrote in message
news:web.51f194e13a6d0c04eb1d220f0@news.povray.org...
> working on
> features
> Sam
Date: 25 Jul 2013 21:30:05
Message: <web.51f1d0413a6d0c04ae2c701b0@news.povray.org>
It took me too long to figure out what was needed to produce the basic shape: 1)
a latitudinal torus macro (was easy to make); 2) a proper method for smoothly
joining torii together on a sphere (VAngle() was used for measuring distances
spherically between torus centers).
Who, me?
> Can we call it a tie?
If I were to claim a(ny) prize, I'd have sky_sphere-based textured fog make its
debut in the next version of POV-Ray :D (although I do realize it's not that
sort of wishlist :P)
Well if I remember correctly his train also used torii, cylinders and spheres to
smoothly join various types of surfaces with one another, and the kind of
thinking required to do that would go a long way toward meeting your challenge
advantageously ;)
I vote for a CSG sub-round!
Sam
Download 'shaycsgchallengec.jpg' (351 KB)
Preview of image 'shaycsgchallengec.jpg'
Date: 25 Jul 2013 22:55:19
Message: <51f1e517$1@news.povray.org>
Am 25.07.2013 21:09, schrieb Shay:
>> the "petals" and the tori forming the end of the small-hole
>> extrusions; is that the essence of it?
> object to bound, and 16 objects to build the extrusion, though the 16
> could be optimized to 14. That's probably where the majority of the
> object count difference can be found.
Did you consider punching the hole through the petal /after/ adding the
extrusion? That might allow for a simpler extrusion, as you won't need
to punch a separate hole through it.
>> that what you're saying?
> that was the most efficient way. Maybe it isn't.
Thinking about it, I come to suspect that clipping is actually less
computationally intensive; after all, intersection testing is only
performed on the clipped object, while the clipping object is only
tested for insideness once an intersection has been found.
>> parameters...
I've got all the math sorted out by now (except for the more complex
hole extrusion stuff), so modifying the thing for e.g. 7-fold instead of
8-fold symmetry, changing the petals' size and other some such would now
be a piece of cake; no manual tweaking anymore.
> these forums. One told me that I shouldn't be coding algorithms if I
> don't know what a stack is. That's like my saying he shouldn't be
> writing newsgroup posts if he doesn't know what a chiasmus is.
:-D
It's also like saying that a child shouldn't be playing with any toy if
it doesn't know how to play with it the way the designer intended.
Which is rubbish even if there is solid reason to play according to the
designer's rules (unless of course violation of those rules is seriously
dangerous); science has found out that children actually learn faster
how to use something properly if they've already spent some time toying
around with it as they seem fit, and there is plenty of reason to
suspect that this is the case for every learning process in every age.
As long as you code just for the fun of it, my stance is that coding is
fair game for everyone in every way they like.
(And no, I have not the slightest idea what a chiasmus is - I'd have to
google that ;-))
Date: 25 Jul 2013 23:00:40
Message: <51f1e658$1@news.povray.org>
Am 25.07.2013 23:13, schrieb Samuel Benge:
Hey, the (intended) winner was the POV-Ray wishlist :-)
Looks really great!
Asthetically I do favor this one a lot over my own.
Date: 25 Jul 2013 23:37:31
Message: <51f1eefb@news.povray.org>
Am 26.07.2013 00:28, schrieb Shay:
> tie?
No, not really. There, too, it was all about cutting stuff away and
adding stuff back in.
The fun part is where you begin to round off the prisms. If you want to
both bevel the edges of the front and back sides as well as round off
the extruded shape itself (which is what I did for the train engine),
spine-based prisms won't get you anywhere, because (or so I believe for
certain reasons) if you widen or tighten a 3rd-order spline loop its new
path will generally not have a constant distance to the original path,
no matter how hard you try. So it's back to cylinders, tori and spheres
again.
The only places where I "cheated" were the smokestack, the sand boxes,
and the thick pipes leading from the boiler to the cylinders; these
elements were modeled using blobs.
Oh, and the person I placed on the engine wasn't CSG either of course :-).
