POV-Ray : Newsgroups : povray.binaries.images : Glass Jar Server Time
27 May 2026 22:18:15 EDT (-0400)
  Glass Jar (Message 11 to 20 of 35)
Subject: Re: Glass Jar
Date: 3 Jul 2013 07:53:17
Message: <51d410ad@news.povray.org>
On 07/02/2013 05:11 PM, MichaelJF wrote:
> James Holsenback <nom### [at] nonecom> wrote:
>> On 07/02/2013 06:52 AM, Paolo Gibellini wrote:
>>>   >James Holsenback  on date 01/07/2013 20.33 wrote:
>>>> I'm testing a user contributed fix related to
>>>> http://bugs.povray.org/task/287 and thought the image was cool enough to
>>>> share. It's a work in progress so I'm not entirely sure where it will
>>>> end up.
>>> Surely the jar is very good, it seems /real/ (and thanks to the +C
>>> option!).
>>> Paolo
>> Well I can't take credit for the jar:
http://www.blender-models.com/model-downloads/objects/id/decorative-oct-glass-jar-ver-3/
>> I think I'm going to try to separate the lid from the rest of the jar,
>> and place it on the ground plane, with a few other objects
> That may improve your still fine image. I would like to see the result.
> Best regards,
> Michael
I'd like to work something in that I can use SSLT ... something organic
like a fruit, vegetable, flower to offset the symmetry and hard angles
of the jar and ground plane.
Date: 3 Jul 2013 18:40:02
Message: <web.51d4a7166fab5b2d6454fc670@news.povray.org>
Nice image, James!
Just in case you didn't already know, in Blender it is easy to separate
disconnected geometry from meshes:
1) In edit mode, select one vertex of the jar's lid and press Ctrl+L to
automatically select all connected vertices.
2) Press P to separate it from the mesh. This will create a new object.
Of course, this will only work if the lid is truly a separate object...
otherwise you have quite the job ahead of you :)
Sam
Date: 3 Jul 2013 19:35:37
Message: <51d4b549$1@news.povray.org>
On 07/03/2013 06:35 PM, Samuel Benge wrote:
> Nice image, James!
> Sam
Thanks twice ... I successfully separated the object into container,
lid, and top decoration.
Date: 3 Jul 2013 20:05:01
Message: <web.51d4bbf06fab5b2da79a3c300@news.povray.org>
NP. Are you planning to make a boolean union of the lid and top decoration? I've
found that Blender's boolean modifier can be dodgy at times, especially if the
base mesh hasn't been triangulated.
Date: 4 Jul 2013 02:15:01
Message: <web.51d512d36fab5b2dc2d178100@news.povray.org>
> It's been in my toolbox for sometime now..
Thanks for providing the code/image. That was the only way I could think of
making such an object but did not think it would work as well as your example
does. The raising it slightly to produce the shadow works really well as I would
never have guessed it was an image map.
Sean
Date: 4 Jul 2013 06:53:12
Message: <51d55418$1@news.povray.org>
Haven't even noticed the union modifier ... I /was/ going to just use
Join in object mode. I'll have a look!
Date: 4 Jul 2013 13:00:01
Message: <web.51d5a8e46fab5b2d4f79afa40@news.povray.org>
Blender's funny like that: certain things are only available as modifiers. I was
scratching my head for the longest time one day trying to figure out how to find
a happy medium between flat shading and smooth... you know, to break the smooth
shading along only the sharp edges of a mesh. The one solution was found where?
The modifiers tab, of course (Add Modifier->Generate->Edge Split) ;P
It's a very confusing program when just jumping in, but it's really not as
poorly designed as it seems at first glance. I've been especially impressed by
its modeling capabilities. And by using modifiers, you can keep your mesh design
as simple as possible until it's time to export it.
Date: 20 Jul 2013 08:48:11
Message: <51ea870b@news.povray.org>
>>> end up.
>> option!).
>> Paolo
well i managed to get the lid separated from the jar ... and the
additional objects started out as jelly beans, but traditional jb colors
just didn't seem to go with the rest of the objects, i went to pastels
colors. now i think they look like jordan almonds. i like the
subsurface, so i think i'll probably end up making the candies more
almond shaped.
Download 'work.png' (841 KB)
Preview of image 'work.png'
Date: 20 Jul 2013 12:44:45
Message: <51eabe7d$1@news.povray.org>
>>>> enough to
>>>> end up.
>>> option!).
>>> Paolo
> almond shaped.
I'd like to see the gelly beans version.
A question:
Why does the grout between the tiles protude above them?
Date: 20 Jul 2013 13:19:04
Message: <51eac688$1@news.povray.org>
Am 20.07.2013 14:47, schrieb James Holsenback:
> almond shaped.
Nice one; but it looks quite artificially placed; maybe move the doily a
deal to the top left, to make it look more like the jar had toppled over?
And then, of course, the candies call for the Bullet Physics Playground...
