POV-Ray : Newsgroups : povray.binaries.images : POVEarth: Tristan da Cunha: gaps between mesh2 triangles Server Time
27 May 2026 22:18:15 EDT (-0400)
  POVEarth: Tristan da Cunha: gaps between mesh2 triangles (Message 3 to 12 of 12)
<<< Previous 2 Messages Goto Initial 10 Messages
Subject: Re: POVEarth: Tristan da Cunha: gaps between mesh2 triangles
Date: 30 Jun 2013 16:09:10
Message: <51d09066@news.povray.org>
Hi(gh)!
On 30.06.2013 21:28, Stephen wrote:
> Just a short in the dark, Jorg.
> Blender has the functionality to fill a hole in a mesh with faces.
> http://wiki.blender.org/index.php/Doc:2.4/Tutorials/Modeling/Meshes/Fill_Faces
> It might help and it is free. ;-)
Yes, I heard of Blender (and sometimes even used it) - but this is
probably not the solution, as "technically", the mesh is complete, i. e.
no triangles are missing. It must be an accuracy or epsilon problem...
See you in Khyberspace!
Yadgar
Date: 30 Jun 2013 16:25:10
Message: <51d09426@news.povray.org>
> Hi(gh)!
> Yadgar
As I said. It was a shot in the dark.
Regards
Date: 1 Jul 2013 03:03:12
Message: <51d129b0@news.povray.org>
It seems to me that the triangle are floating, the vertices not being
joint properly together. If that is true, the solution is simple: load
the mesh2 into Poseray, go to Groups, push the button labelled Weld
vertices, save as mesh2 again.
Additionally, beware indeed of epsilon issues. Put the camera a little
bit higher from the ground.
Date: 1 Jul 2013 04:56:21
Message: <51d14435$1@news.povray.org>
Hi(gh)!
I think they should, as this is the code for the mesh2:
#declare Earth_Slice=
mesh2
   vertex_vectors
     xdim*ydim
     #declare row=0;
     #while (row<ydim)
       #declare col=0;
       #while (col<xdim)
         #declare clrvect=eval_pigment(map, <1/(xdim*2)+col/xdim,
1-(1/(ydim*2)+row/ydim), 1>);
         // #warning concat("<",vstr(3, clrvect, ",",7,2),">")
         // #warning concat(str(col,2,0)," ",str(row,2,0))
         #declare hval=clrvect.red*65280+clrvect.green*255;
         #declare hval=-deadsea+rng/65535*hval;
         // #warning str(hval, 1, 2)
(rd+hval)*<sin(radians(-longstart-col/xdim))*cos(radians(latstart-row/ydim)),
                  sin(radians(latstart-row/ydim)),
cos(radians(-longstart-col/xdim))*cos(radians(latstart-row/ydim))>*sf
         #if (!(row=ydim-1 & col=xdim-1)) // no comma after last vector
         #declare col=col+1;
       #declare row=row+1;
   face_indices
     (xdim-1)*(ydim-1)*2
     #declare r=0;
     #while (r<ydim-1)
       #declare c=0;
       #while (c<xdim-1)
         <r*xdim+c, r*xdim+c+1, (r+1)*xdim+c>,
         <r*xdim+c+1, (r+1)*xdim+c+1, (r+1)*xdim+c>
         #if (!(r=ydim-2 & c=xdim-2)) // no comma after last vector
         #declare c=c+1;
       #declare r=r+1;
   texture
     pigment { color rgb <0, 0.8, 0> }
     finish { ambient 0.1 diffuse 1 brilliance 0.4 }
   double_illuminate
   translate ApproxLook*sf
Poseray? Is it free?
In my current scene, the camera is placed at "pedestrian eye's height",
i. e. 1.7 metres above ground. But the problem remains with any camera
height - the gaps then show up as black dots on the terrain!
Yadgar
Now playing: Master of Sensation (Eloy)
Date: 1 Jul 2013 05:57:56
Message: <51d152a4$1@news.povray.org>
Yes, it is an excellent program
https://sites.google.com/site/poseray/
Regards
Date: 1 Jul 2013 07:19:33
Message: <51d165c5$1@news.povray.org>
> mesh2
>    vertex_vectors
>      xdim*ydim
>      #declare row=0;
>      #while (row<ydim)
>        #declare col=0;
>        #while (col<xdim)
I cannot read that ;-)
Thinking a bit more about this, meshes with loose triangles at least
have their vertices at the /same/ locations; here there seems to be a
gap. Either, this is already present in the original DEMs, or the math
above for the conversion has some errors... Difficult to say.
Poseray is free indeed and it is worth a try. If it does not solve the
issue, then other solutions have to be found. In Poseray, the tolerance
for welding vertices can be adapted. Start with the default; if
necessary increase the value gradually.
Date: 1 Jul 2013 08:05:27
Message: <51d17087@news.povray.org>
> mesh2
>    vertex_vectors
>      xdim*ydim
>      #declare row=0;
>      #while (row<ydim)
>        #declare col=0;
>        #while (col<xdim)
I would put something very simple like this for debug purposes:
<row,col,hval>
>    face_indices
>      (xdim-1)*(ydim-1)*2
>      #declare r=0;
>      #while (r<ydim-1)
>        #declare c=0;
>        #while (c<xdim-1)
That looks fine to me.
Put your camera in a suitable location for the above debug mesh to show
up, and put a constant coloured background so that you can see the
difference between shadowed areas and areas not rendered properly.
Assuming the above test works then I would gradually build back up to
your equations (maybe first changing the scale to match, then
introducing the trig) to see what causes the problems.
My guess is accuracy because you are dealing with a huge dynamic range
of dimensions.
Date: 1 Jul 2013 08:20:39
Message: <51d17417$1@news.povray.org>
>>    vertex_vectors
>>      xdim*ydim
>>      #declare row=0;
>>      #while (row<ydim)
>>        #declare col=0;
>>        #while (col<xdim)
Even if it has errors it shouldn't introduce gaps as he is using
face_indices to reference the vertices (all 6 triangles using that
vertex will have exactly the same value, even if it is an incorrect value).
Date: 1 Jul 2013 15:40:03
Message: <op.wzj58xdxufxv4h@xena>
I would love to visit Tristan da Cunha one day :)
There are so many beautiful and interesting features on this island. My
first impression on Google Earth was "dead, dry and boring" until I took a
closer look.
-Nekar Xenos-
Date: 2 Jul 2013 01:39:32
Message: <51d26794@news.povray.org>
Hi(gh)!
Same with me... but it is, at least from Europe, even further away and
more difficult to reach than Afghanistan! And there are many more
interesting islands in the southern temperate and subantarctic zone...
ever heard of Amsterdam Island? It's somehow Tristan da Cunha's
counterpart in the Indian Ocean!
All these islands appear interesting to render within my megalomaniac
POVEarth project... especially when it comes to vegetation and fauna
(any albatross model ready?)!
Yadgar
