POV-Ray : Newsgroups : povray.binaries.images : Elements of Geology 1 Server Time
22 Dec 2025 05:18:48 EST (-0500)
  Elements of Geology 1 (Message 1 to 10 of 10)
Subject: Elements of Geology 1
Date: 11 Jun 2013 10:15:59
Message: <51b7311f@news.povray.org>
This was the first scene I started on this TC-RTC Challenge. Needless to
say that I am far from happy about it all. Somehow, I feel disappointed
and unenthusiastic about it at this stage.
Download 'elements of geology1_05.jpg' (412 KB)
Preview of image 'elements of geology1_05.jpg'
Subject: Re: Elements of Geology 1
Date: 11 Jun 2013 16:10:00
Message: <web.51b783d290f091b0a07cff350@news.povray.org>
> Thomas
May be you can raise the camera a bit. The figure at the top is very hard to
recognize, even if it will be not at a realistic scale, try to double it's size.
Sometimes such things are working visually. E.g. the flamingoes in my "Rock 'n'
Roll" scene (Sphinx-Round) are some 5 meters high. No one has noticed this so
far and recogniced just flamingoes. I use this very carefully but sometimes it
helps.
Otherwise I cannot see a real flaw with this one. The only idea I came up with
is that you posted an idea to texture the leafs of trees with different colors
some months ago and that this one could be a good test for this idea.
Best regards,
Micheal
Date: 11 Jun 2013 18:25:02
Message: <web.51b7a36b90f091b0e52a27db0@news.povray.org>
> Thomas
Maybe making the rockface darker to give more contrast, I think it is a good
concept and again good use of foliage. It does look a bit like there are plants
growing inside the house though and I think if I lived in a valley like that I
would not bother with houseplants ;-)
Sean
Date: 12 Jun 2013 03:22:42
Message: <51b821c2$1@news.povray.org>
A darker rockface is indeed an interesting idea. I need to work on the
foliage colour a bit more. It is too bright in places.
There are no plants in the house. What you see is the reflection of the
trees in the window panes ;-) I may need to reduce the reflection though.
Thanks for your comments. Gives me some hope again that I am on the
right track. I was rather unsure about this, maybe because I worked a
bit too long on the scene.
Date: 12 Jun 2013 03:33:42
Message: <51b82456$1@news.povray.org>
> helps.
Yes, the camera is a bit too low indeed and needs to clear the grass. I
also have often used that trick with sizes, even to gradually scaling up
objects with distance. The eyes are completely fooled. I may do this
here too, but then I also need to adjust the size of trees up there. On
the other hand, I wanted to give a measure of the sheer size of the
cliff itself...
Thanks for your kind comments. Not too bad then after all. Concerning
the leaves, yes, I might try that although my technique was not as good
as Norbert Kern's. However, excellent suggestion. Some work to do then ;-)
Date: 12 Jun 2013 16:05:01
Message: <web.51b8d35590f091b0d25d21bf0@news.povray.org>
Maybe more relief in the rocks (isosurfface)
Date: 13 Jun 2013 03:09:09
Message: <51b97015$1@news.povray.org>
As is, an isosurface does not make a difference as the rocks are based
on an image map. I can switch between the two. However, I could add some
functions to work on the relief. Again however, I want the rock face to
look eroded, without too much small details sticking out.
Subject: Re: Elements of Geology 1 Take 2
Date: 13 Jun 2013 10:15:39
Message: <51b9d40b@news.povray.org>
Integrating different hints, results in this image.
The rock face could be darker; I first opted to have the relief given a
lighter hue.
Download 'elements of geology1_06.jpg' (408 KB)
Preview of image 'elements of geology1_06.jpg'
Date: 14 Jun 2013 13:46:42
Message: <51bb5702$1@news.povray.org>
> Thomas
Erosion often add details... With small details sticking both in and out.
Date: 15 Jun 2013 02:56:58
Message: <51bc103a$1@news.povray.org>
True, but it also smooths surfaces :-)
The rock face intends to show both: erosion of the incompetent parts as
crevices; smoothing of the competent hard layers.
