POV-Ray : Newsgroups : povray.binaries.images : Sky simulation Server Time
28 May 2026 00:56:26 EDT (-0400)
  Sky simulation (Message 39 to 48 of 58)
Subject: Re: Sky simulation: what is wrong with this particular code?
Date: 10 Jul 2013 12:13:34
Message: <51dd882e$1@news.povray.org>
> This is a known problem, although I do not know that the POV Team perceives it
> as a problem.  When I brought it up 5 years ago, I was quoted documentation of
> macro names being global in scope, which was just a red herring.
The documentation also states that "[#local] temporarily override any
identifiers with the same name." IMO a bit more clarification should be
added there, something along the lines of "...unless the identifier name
is already in use as a macro name, or the #local statement is in a macro
definition and the identifier name matches one of the macro parameter
names.".
> This behavior
> breaks the very concept of local variables and makes "black box" modularization
> impossible.
Exactly, in my relatively simple macro which I doubt very many people
have tried out yet, two people got different namespace clash related
errors with #local's I'd used inside the macro. In future I'll make sure
to make all variable names and parameter names unique (by prefixing with
my name and/or the macro name etc), at which point I might just as well
use #declare!
I can't believe more people haven't come across this "feature" in the
last 5 years.
Date: 16 Jul 2013 22:27:52
Message: <51e60128$1@news.povray.org>
Am 09.06.2013 15:12, schrieb Christian Froeschlin:
>> (In fact, why aren't coders posting more patches? Is everyone waiting
>> till 3.7 Final or something?)
> actually I seem to recall the license / source code comments did not
> allow the publishing of modified sources for beta versions. Not sure if
> that also holds for release candidates.
The corresponding text is still in all the file headers, so technically
speaking I guess it does.
And yes, I can name at least one person who is holding back various
patches for just that very reason.
Date: 16 Jul 2013 22:33:49
Message: <51e6028d$1@news.povray.org>
Am 17.07.2013 04:27, schrieb clipka:
(of RC7, that is)
Date: 16 Jul 2013 22:50:34
Message: <51e6067a@news.povray.org>
Am 19.06.2013 16:49, schrieb Thomas de Groot:
>> Bring on mcpov merged into POV 3.7 !! If I had the time I'd definitely
>> give it a shot.
> I am too happy with 3.7 for the things I do. ;-)
Believe me, once you get to toy around with blurred reflections you
/will/ want them integrated in 3.7 :-) It's amazing how much more
credibility it brings to textures midway between between dull and shiny
(non-polished metallic surfaces are just the tip of the iceberg in this
regard).
(You /will/ also want a faster computer of course :-P)
Date: 16 Jul 2013 22:52:11
Message: <51e606db$1@news.povray.org>
Am 17.06.2013 16:41, schrieb scott:
> The only reason I left the sphere object in there is because in mcpov
> you can't use light_sources, you are forced to model a sun as a very
> bright sphere.
... which is a huge drawback of MCPOV, if I'm asked. The ideal solution
would be to have the best of both worlds.
Date: 16 Jul 2013 23:03:31
Message: <51e60983$1@news.povray.org>
Am 10.07.2013 16:43, schrieb Cousin Ricky:
> scott <sco### [at] scottcom> wrote:
>> While we're at it this also causes an error (even if the definition for
>> A is in a different file):
>> #macro A()
>> #end
>> #macro B()
>> #local A=1;
>> #end
>> B()
>> This one is a bit more serious as it means if any macro in your scene
>> uses a local variable with the same name as another macro you'll get an
>> error.
> macro names being global in scope, which was just a red herring.  This behavior
> impossible.
The current POV-Ray development team (*) does perceive the whole 3.x
generation SDL parser as one big monolithic problem :-P
(* or "dev team" for short; I guess that's what you mean. There did
exist some group of people called the "POV Team", but they were focused
on user support rather than development.)
Date: 17 Jul 2013 03:09:52
Message: <51e64340$1@news.povray.org>
> regard).
Oh, I do understand that indeed. Let's say that I am not too
demanding... ;-)
Yeah...
Date: 17 Jul 2013 03:52:52
Message: <51e64d54$1@news.povray.org>
>> bright sphere.
Indeed - bring it on! :-)
The other obvious drawback is that you need to run multiple instances of
MCPOV (all started at least 1 second apart as I found out...) to make
good use of modern CPUs, then merge the images afterwards. I've
automated this process but it's still not as good as being able to do it
all in one program and see the results in real time.
Date: 17 Jul 2013 06:38:06
Message: <51e6740e$1@news.povray.org>
Am 17.07.2013 09:52, schrieb scott:
>>> bright sphere.
Guess what: I probably will :-D
Date: 8 Sep 2016 03:00:00
Message: <web.57d10baf59bb6361b05bf450@news.povray.org>
> I think I found the culprit: Your original SunPos() is divided by 1000!
> Thomas
What line number is that at? I am having the same issue.
Mike
