POV-Ray : Newsgroups : povray.binaries.images : Sky simulation Server Time
28 May 2026 02:24:42 EDT (-0400)
  Sky simulation (Message 31 to 40 of 58)
Subject: Re: Sky simulation
Date: 19 Jun 2013 10:49:40
Message: <51c1c504$1@news.povray.org>
On 19-6-2013 16:24, scott wrote:
>> I have never met any problems or artefacts when using SunPos so, imho,
>> there is no need to divide.
> That's just because you never tried to put a sphere at that position
> before :-) Also I haven't done a thorough investigation, but the
> accuracy issues you run into seem to depend on the size of other objects
> in your scene (and maybe the camera setup?). Whilst the /1000 factor for
> placing the sphere might work in this particular scene, it may become
> invisible again in a different scene (or work fine without the /1000).
Oh yes, I did! ;-) However, I only use SunPos for my main light source.
I hardly use a visible sun.
> I suppose the ultimate solution would be to incorporate the sun in the
> sky_sphere pigment at the physically correct brightness (which would
> save having to use any arbitrary values for "very far away"), and for
> the POV team to implement something similar to the sky importance
> sampling in mcpov for the radiosity algorithm (so you don't need a
> really high count to reliably pick up the bright sun).
That would be a good idea.
>> Maybe, but those are special cases needing special solutions.
> I never thought I'd hear a glossy reflective surface being called a
> "special case" in a raytracing forum - what next, a checkered plane is
> also a special case? :-O
LOL good point. I admit that I was talking from a strictly personal
point of view...
> Bring on mcpov merged into POV 3.7 !! If I had the time I'd definitely
> give it a shot.
I am too happy with 3.7 for the things I do. ;-)
Subject: Re: Sky simulation: what is wrong with this particular code?
Date: 5 Jul 2013 08:36:04
Message: <51d6bdb4@news.povray.org>
Consider the following scene code:
//start code
#version 3.7;
global_settings {assumed_gamma 1.0}
   location  <0, 5, -40>
   sky       y
   up        y
   direction z*1.7
   angle     70
   look_at   <0, 5, 100>
#include "sunpos.inc"
#declare MySun  = SunPos(2012, 3, 5, 13, 10, 0, 31.7625, 25.0888);
#declare EXP = 8e-5;
// SkySim
#include "SkySim.inc"
SkySim( SolarPosition,
      y,
      5,
      EXP
#declare SunColor = rgb 1;
light_source {
   MySun
   color    SunColor*(17334 * EXP)
   //parallel
   //point_at <0, 5, 100>
plane {y, -5 pigment {rgb 1}}
cylinder {<0,-5,10>, <0,6,10>, 1 pigment {rgb <1,0,0>}}
//end code
It renders well (see image: SkySim_SolarPosition) also with parallel and
point_at in the light_source uncommented.
Now, switch SolarPosition in the SkySim macro call, by MySun. I get
image SkySim_MySun.
Now, uncomment parrale and point_at in the light_source. I get image
SkySim_MySun parallel.
So, what is wrong here? All goes well in the original test scene.
Download 'skysim_solarposition.png' (15 KB) Download 'skysim_mysun.png' (24 KB) Download 'skysim_mysun parallel.png' (15 KB)
Preview of image 'skysim_solarposition.png'
Preview of image 'skysim_mysun.png'
Preview of image 'skysim_mysun parallel.png'
Date: 5 Jul 2013 09:38:01
Message: <51d6cc39$1@news.povray.org>
> //start code
> #version 3.7;
> camera {
>    sky       y
>    up        y
>    direction z*1.7
>    angle     70
>    look_at   <0, 5, 100>
> // SkySim
>       y,
>       5,
>       EXP
> light_source {
>    MySun
>    //parallel
> //end code
> image SkySim_MySun.
Hmmm ok, so apparently I misunderstood the POV syntax, this short piece
of code prints X=9 whereas I assumed it would print X=10. Not sure if
this is intended behaviour or not.
// start code
#macro A(B)
#local B = B - 1;
#declare X = 10;
A(X)
#warning concat("X = ",str(X,0,0))
// end code
Will fix the macro and post and update... (it's essentially normalizing
your sun position, which you're then using the place the light source).
Date: 5 Jul 2013 10:07:42
Message: <51d6d32e$1@news.povray.org>
Thanks! Glad to be of help (by chance) :-)
Date: 5 Jul 2013 20:17:30
Message: <51d7621a$1@news.povray.org>
> // start code
> #macro A(B)
> #local B = B - 1;
> #end
> #declare X = 10;
> A(X)
> // end code
Your code develop as:
#declare X = 10;
#local X = X - 1;
In this contex, #local and #declare are synonims.
So, yes, it works as expected.
There is a difference when #local is used in an include file. In an
include, any #local variables only exist within the include.
Date: 8 Jul 2013 03:54:52
Message: <51da704c$1@news.povray.org>
> #declare X = 10;
> #local X = X - 1;
It is in an include, sorry in the above example the macro is in another
file. Try this (two files):
// file1.inc
#macro A(B)
#local B = 5;
// file2.pov
#include "file1.inc"
#declare X = 10;
A(X)
X comes out as 5, but I would have expected 10.
Date: 8 Jul 2013 08:18:23
Message: <51daae0f@news.povray.org>
While we're at it this also causes an error (even if the definition for
A is in a different file):
#macro A()
#macro B()
#local A=1;
B()
This one is a bit more serious as it means if any macro in your scene
uses a local variable with the same name as another macro you'll get an
error.
Date: 10 Jul 2013 10:45:00
Message: <web.51dd73032dc5ff1278641e0c0@news.povray.org>
> #macro A()
> #end
> #macro B()
> #local A=1;
> #end
> B()
> error.
This is a known problem, although I do not know that the POV Team perceives it
as a problem.  When I brought it up 5 years ago, I was quoted documentation of
macro names being global in scope, which was just a red herring.  This behavior
breaks the very concept of local variables and makes "black box" modularization
impossible.
You also get an error if you declare a function with an argument that has the
same name as a previously declared variable.
I hope that these (and ALL other cases of scope leakage in POV-Ray) will be
eliminated by version 4.0.
Date: 10 Jul 2013 12:13:34
Message: <51dd882e$1@news.povray.org>
The documentation also states that "[#local] temporarily override any
identifiers with the same name." IMO a bit more clarification should be
added there, something along the lines of "...unless the identifier name
is already in use as a macro name, or the #local statement is in a macro
definition and the identifier name matches one of the macro parameter
names.".
> This behavior
> impossible.
Exactly, in my relatively simple macro which I doubt very many people
have tried out yet, two people got different namespace clash related
errors with #local's I'd used inside the macro. In future I'll make sure
to make all variable names and parameter names unique (by prefixing with
my name and/or the macro name etc), at which point I might just as well
use #declare!
I can't believe more people haven't come across this "feature" in the
last 5 years.
Date: 16 Jul 2013 22:27:52
Message: <51e60128$1@news.povray.org>
Am 09.06.2013 15:12, schrieb Christian Froeschlin:
>> (In fact, why aren't coders posting more patches? Is everyone waiting
>> till 3.7 Final or something?)
> actually I seem to recall the license / source code comments did not
> allow the publishing of modified sources for beta versions. Not sure if
> that also holds for release candidates.
The corresponding text is still in all the file headers, so technically
speaking I guess it does.
And yes, I can name at least one person who is holding back various
patches for just that very reason.
