POV-Ray : Newsgroups : povray.binaries.images : Sky simulation Server Time
28 May 2026 00:56:26 EDT (-0400)
  Sky simulation (Message 21 to 30 of 58)
Subject: Re: Sky simulation
Date: 17 Jun 2013 10:41:30
Message: <51bf201a$1@news.povray.org>
> I added radiosity, and they seem to come from that. Without radiosity
> the landscape remains totally dark whatever the value for EXP and the
> hour of the day.
Thinking about, you can have light_sources and still use radiosity can't
you? In that case I don't see any benefit to using a sphere for the sun
over using a light_source (even an area_light if you want realistic soft
shadows).
The only reason I left the sphere object in there is because in mcpov
you can't use light_sources, you are forced to model a sun as a very
bright sphere.
Date: 17 Jun 2013 10:45:07
Message: <51bf20f3@news.povray.org>
>> That shouldn't make a difference, because the sun radius is determined
>> from the distance. The reason I did that is because SunPos.inc returns a
>> massive distance for the sun vector which causes problems in some
>> scenes, in reality it only needs to be a few orders of magnitude further
>> away than everything else in your scene.
> And yet, *that* is exactly the trouble maker. Without, the scene renders
> perfectly, like the example (with radiosity added again) shows. Also in
> any other of my scenes the results are correct. Exp at 4e-5 again here.
If you want to post your two scene files (the one that renders correctly
and the one that has the bright blobs) then I'll take a look and see if
I can figure out what's going on.
Date: 17 Jun 2013 11:06:05
Message: <51bf25dd$1@news.povray.org>
It is very simple: the only thing to do is to comment out the /1000 at
the end of the SunPos() declaration in your scene file. You may want to
add the radiosity code (below).
As radiosity I use:
   radiosity {
     pretrace_start 0.08
     pretrace_end   0.004
     count 50, 1000
     nearest_count 10, 5
     error_bound 1
     recursion_limit 2
     low_error_factor .3
     gray_threshold 0.0
     minimum_reuse 0.015
     maximum_reuse 0.1
     brightness 1
     adc_bailout 0.01/2
     normal off
     media off
     always_sample off
     //max_sample 1.0
Note that without the divisor, the sun sphere (when switched on) becomes
invisible somehow.
Date: 17 Jun 2013 11:10:43
Message: <51bf26f3$1@news.povray.org>
> shadows).
Your scene uses a light_source, therefore the visibility switch should
switch on the looks_like code there.
Date: 17 Jun 2013 13:20:57
Message: <51bf4579@news.povray.org>
> invisible somehow.
It also becomes invisible to the whole radiosity algorithm... Try it
with the sphere commented out - I get exactly the same image with and
without the sphere when the /1000 divisor is deleted.
If you look at sunpos.inc near the bottom you see this line:
    #declare SolarPosition=vrotate(<0,0,1000000000>,<-Al,Az,0>);
That 1000000000 is simply too big - accuracy errors prevent an object at
that distance rendering properly, even directly or from the radiosity code.
Anyway, the splotchiness is because the sun is too small, so the
radiosity algorithm doesn't always pick it up. By taking out the /1000
you are effectively removing the sun sphere from the scene so the
splotchiness goes away (along with any radiosity effect from the sun).
To test this simply make your sun sphere much bigger (and reduce the
emission so the amount of light stays constant), here I made it 50x bigger:
#local SunRadius = vlength(sp)/214.8 * 50;
sphere{ sp,SunRadius pigment{color rgb 1} finish{emission 1.6e9 * EXP /
50/50 }}
That makes it 50 times bigger and it renders fine (no bright splotches)
with your radiosity settings - see attached.
Without upping the count to silly levels I don't know how else to get an
emissive sun of a realistic size to show up with radiosity. You'd be
better off sticking with an area_light IMHO.
Download 'bigsun.png' (145 KB)
Preview of image 'bigsun.png'
Date: 18 Jun 2013 03:01:49
Message: <51c005dd$1@news.povray.org>
Re-reading my own post, I find it totally confusing :-)
What I mean is that instead of a sphere, you could add the looks_like
code to the light_source.
Date: 18 Jun 2013 04:05:39
Message: <51c014d3@news.povray.org>
There is a much better solution.
//start code
#local sp = SunPos(2013, 6, 6, 17, 0, 0, 52.206507, 0.12165);
light_source {
   sp
   color rgb <1,1,0.9>*(17334 * EXP)
#local SunRadius = vlength(sp/1000)/214.8;
sphere {sp/1000, SunRadius pigment{color rgb 1} finish{emission 1}
no_shadow}
//end code
The scene does not need the *emission* of the *visible* sphere as a
light source. It only needs the light source itself. So, the solution is
to put the sunlight at the standard SunPos position, and the *visible*
sphere and its radius at sp/1000. In addition, just make emission of the
sphere equal to 1.
See attached image.
Download 'skysimtestground.png' (207 KB)
Preview of image 'skysimtestground.png'
Date: 18 Jun 2013 04:52:13
Message: <51c01fbd$1@news.povray.org>
> light source.
As I said before, there isn't any need to try this for radiosity, it
will just cause problems like you experienced. It's only in the code as
it is needed for mcpov (where is works fine).
I don't know if there are any accuracy issues related to having a
light_source a very large distance away, I expect it may cause some
shadow artifacts? The length of the vector from SunPos is quite
arbitrary, so in every scene you just need to find the max distance it
works at, then I'd probably divide by 10 or 100 just to be sure you're
not near the accuracy limit.
> sphere equal to 1.
The problem with that is the sun will look unrealistically dim compared
to the sky when visible in any reflections, especially darker low-level
reflections (eg a black car). You could set emission to 0 and ambient to
the original physically correct 1.6e9 * EXP, but I think that would
still influence the radiosity algorithm and give you back the bright
splotches again.
At this point I usually fire up mcpov :-)
Date: 18 Jun 2013 05:30:40
Message: <51c028c0$1@news.povray.org>
>> light source.
But mcpov has other problems of its own, as Clipka explained some time ago.
I have never met any problems or artefacts when using SunPos so, imho,
there is no need to divide.
>> sphere equal to 1.
> splotches again.
Maybe, but those are special cases needing special solutions.
<grin>
Date: 19 Jun 2013 10:24:56
Message: <51c1bf38$1@news.povray.org>
The only major one is the diffuse values are out by a factor of 2, I
usually use a macro for setting the finish which outputs either the
vanilla POV syntax (for testing the scene) or the mcpov syntax (for
final render). Incorporating the factor of 2 correction is easy in the
macro.
That's just because you never tried to put a sphere at that position
before :-) Also I haven't done a thorough investigation, but the
accuracy issues you run into seem to depend on the size of other objects
in your scene (and maybe the camera setup?). Whilst the /1000 factor for
placing the sphere might work in this particular scene, it may become
invisible again in a different scene (or work fine without the /1000).
I suppose the ultimate solution would be to incorporate the sun in the
sky_sphere pigment at the physically correct brightness (which would
save having to use any arbitrary values for "very far away"), and for
the POV team to implement something similar to the sky importance
sampling in mcpov for the radiosity algorithm (so you don't need a
really high count to reliably pick up the bright sun).
I never thought I'd hear a glossy reflective surface being called a
"special case" in a raytracing forum - what next, a checkered plane is
also a special case? :-O
> <grin>
Bring on mcpov merged into POV 3.7 !! If I had the time I'd definitely
give it a shot.
