POV-Ray : Newsgroups : povray.binaries.images : Sky simulation Server Time
28 May 2026 03:58:41 EDT (-0400)
  Sky simulation (Message 19 to 28 of 58)
Subject: Re: Sky simulation
Date: 17 Jun 2013 10:21:15
Message: <51bf1b5b$1@news.povray.org>
>> You can adjust the EXP variable in the test scene to control the
>> brightness of the sky (it controls how the physical brightness values
>> calculated are converted to POV units). Try increasing it from 4e-5 to
>> 6e-5 or even higher.
> Yes I did that indeed, but somehow the scene never comes close to the
> aspect of a regular light and sky_sphere.
It looks like it's because the sun is so bright and so small, the
radiosity algorithm won't pick it up very often. This would explain the
bright yellow patches, they're radiosity samples that just happened to
pick up the sun - most of the samples didn't. I'm not experienced enough
with radiosity to know a way around this (I use mcpov for most renders,
which allows for such small very bright objects ok).
Could you ever get a similar scene with a realistically sized and bright
sun to render with radiosity corerctly? The pigment of the sky_sphere
should only make a very minor difference when a bright sun is in the sky.
> I added radiosity, and they seem to come from that. Without radiosity
> the landscape remains totally dark whatever the value for EXP and the
> hour of the day.
There was a light_source in my demo scene file I posted, that should
illuminate the ground - unless you've uncommented the sun sphere that
happens to be in exactly the same place :-)
 > I think I found the culprit: Your original SunPos() is divided by 1000!
That shouldn't make a difference, because the sun radius is determined
from the distance. The reason I did that is because SunPos.inc returns a
massive distance for the sun vector which causes problems in some
scenes, in reality it only needs to be a few orders of magnitude further
away than everything else in your scene.
Date: 17 Jun 2013 10:39:03
Message: <51bf1f87@news.povray.org>
And yet, *that* is exactly the trouble maker. Without, the scene renders
perfectly, like the example (with radiosity added again) shows. Also in
any other of my scenes the results are correct. Exp at 4e-5 again here.
Download 'skysimtestground.png' (160 KB)
Preview of image 'skysimtestground.png'
Date: 17 Jun 2013 10:41:30
Message: <51bf201a$1@news.povray.org>
> hour of the day.
Thinking about, you can have light_sources and still use radiosity can't
you? In that case I don't see any benefit to using a sphere for the sun
over using a light_source (even an area_light if you want realistic soft
shadows).
The only reason I left the sphere object in there is because in mcpov
you can't use light_sources, you are forced to model a sun as a very
bright sphere.
Date: 17 Jun 2013 10:45:07
Message: <51bf20f3@news.povray.org>
If you want to post your two scene files (the one that renders correctly
and the one that has the bright blobs) then I'll take a look and see if
I can figure out what's going on.
Date: 17 Jun 2013 11:06:05
Message: <51bf25dd$1@news.povray.org>
It is very simple: the only thing to do is to comment out the /1000 at
the end of the SunPos() declaration in your scene file. You may want to
add the radiosity code (below).
As radiosity I use:
   radiosity {
     pretrace_start 0.08
     pretrace_end   0.004
     count 50, 1000
     nearest_count 10, 5
     error_bound 1
     recursion_limit 2
     low_error_factor .3
     gray_threshold 0.0
     minimum_reuse 0.015
     maximum_reuse 0.1
     brightness 1
     adc_bailout 0.01/2
     normal off
     media off
     always_sample off
     //max_sample 1.0
Note that without the divisor, the sun sphere (when switched on) becomes
invisible somehow.
Date: 17 Jun 2013 11:10:43
Message: <51bf26f3$1@news.povray.org>
> shadows).
Your scene uses a light_source, therefore the visibility switch should
switch on the looks_like code there.
Date: 17 Jun 2013 13:20:57
Message: <51bf4579@news.povray.org>
> invisible somehow.
It also becomes invisible to the whole radiosity algorithm... Try it
with the sphere commented out - I get exactly the same image with and
without the sphere when the /1000 divisor is deleted.
If you look at sunpos.inc near the bottom you see this line:
    #declare SolarPosition=vrotate(<0,0,1000000000>,<-Al,Az,0>);
That 1000000000 is simply too big - accuracy errors prevent an object at
that distance rendering properly, even directly or from the radiosity code.
Anyway, the splotchiness is because the sun is too small, so the
radiosity algorithm doesn't always pick it up. By taking out the /1000
you are effectively removing the sun sphere from the scene so the
splotchiness goes away (along with any radiosity effect from the sun).
To test this simply make your sun sphere much bigger (and reduce the
emission so the amount of light stays constant), here I made it 50x bigger:
#local SunRadius = vlength(sp)/214.8 * 50;
sphere{ sp,SunRadius pigment{color rgb 1} finish{emission 1.6e9 * EXP /
50/50 }}
That makes it 50 times bigger and it renders fine (no bright splotches)
with your radiosity settings - see attached.
Without upping the count to silly levels I don't know how else to get an
emissive sun of a realistic size to show up with radiosity. You'd be
better off sticking with an area_light IMHO.
Download 'bigsun.png' (145 KB)
Preview of image 'bigsun.png'
Date: 18 Jun 2013 03:01:49
Message: <51c005dd$1@news.povray.org>
Re-reading my own post, I find it totally confusing :-)
What I mean is that instead of a sphere, you could add the looks_like
code to the light_source.
Date: 18 Jun 2013 04:05:39
Message: <51c014d3@news.povray.org>
There is a much better solution.
//start code
#local sp = SunPos(2013, 6, 6, 17, 0, 0, 52.206507, 0.12165);
light_source {
   sp
   color rgb <1,1,0.9>*(17334 * EXP)
#local SunRadius = vlength(sp/1000)/214.8;
sphere {sp/1000, SunRadius pigment{color rgb 1} finish{emission 1}
no_shadow}
//end code
The scene does not need the *emission* of the *visible* sphere as a
light source. It only needs the light source itself. So, the solution is
to put the sunlight at the standard SunPos position, and the *visible*
sphere and its radius at sp/1000. In addition, just make emission of the
sphere equal to 1.
See attached image.
Download 'skysimtestground.png' (207 KB)
Date: 18 Jun 2013 04:52:13
Message: <51c01fbd$1@news.povray.org>
> light source.
As I said before, there isn't any need to try this for radiosity, it
will just cause problems like you experienced. It's only in the code as
it is needed for mcpov (where is works fine).
I don't know if there are any accuracy issues related to having a
light_source a very large distance away, I expect it may cause some
shadow artifacts? The length of the vector from SunPos is quite
arbitrary, so in every scene you just need to find the max distance it
works at, then I'd probably divide by 10 or 100 just to be sure you're
not near the accuracy limit.
> sphere equal to 1.
The problem with that is the sun will look unrealistically dim compared
to the sky when visible in any reflections, especially darker low-level
reflections (eg a black car). You could set emission to 0 and ambient to
the original physically correct 1.6e9 * EXP, but I think that would
still influence the radiosity algorithm and give you back the bright
splotches again.
At this point I usually fire up mcpov :-)
