POV-Ray : Newsgroups : povray.binaries.images : Elements of Geology 3 Server Time
26 Jun 2026 05:03:31 EDT (-0400)
  Elements of Geology 3 (Message 21 to 27 of 27)
Subject: Re: Elements of Geology 3
Date: 5 Jun 2013 03:13:05
Message: <51aee501$1@news.povray.org>
On 4-6-2013 20:07, Samuel Benge wrote:
> Fortunately there is a creek below the area in question; unfortunately the creek
> receives poor sunlight in the afternoons, and is possessed with killer
> mosquitoes. Which of course won't be stopping me >:)
I am sure you won't :-)
I need to take a screen box
> and gold pan down there and go collecting. Even though panning for quartz is
> pretty much pointless, there might be other minerals of higher mass which can be
> separated in that manner. The presence of granite pegmatite, gneiss, and mica
> schist gives me hope :)
Wish you luck.
Date: 5 Jun 2013 13:53:57
Message: <51af7b35$1@news.povray.org>
Nicely done. Techniques?
-Shay
Date: 7 Jun 2013 03:57:33
Message: <51b1926d$1@news.povray.org>
Thanks. Some explanation is indeed in order.
Height_fields:
The landscape is a GeoControl tga export, rendered as a function
height_field. To fill the gaps towards the horizon (and extend the
landscape) the height_field is mirrored and copied to right, back and left.
The foreground rock is a tiny part of another height_field that lies
hidden behind the camera.
Landscape textures:
A greyish gradient y pigment (limestone and shale) and a reddish
gradient y pigment (sandstone) are combined in a slope/altitude texture,
together with a couple of bluish green pigments to simulate vegetation
on the flatter (and lower) parts of the landscape. Not visible on this
version of the image (see coming up one) is a gradient y slope_map
normal added to the rocks, in order to simulate some additional rock
layering (as suggested by Sam). The foreground rock uses Sean Day's rock
texture with a green one for the base vegetation.
Vegetation:
200,000 trees are planted  on the landscape using a macro that I adapted
from one by Kirk Andrews. It makes use of a virtual object (a flat
boxlike object in this instance, rotated with one edge towards the
camera) over the landscape. Random points ( VRand_In_Obj() ) in this
object are traced down towards the landscape and written to file after a
couple of tests, for instance the steepness of the slope, but also an
additional visibility test, using the Visibility Test macro by Gilles
Tran. The written location point are subsequently read for planting the
instances of one (1) tree (POV-Tree) which harbours a macro giving a
slight foliage texture variation for each tree.
The foreground trees are free ones made with Xfrog. The grass patches
(4000) are planted using the same technique as the landscape trees.
Eight different patches are randomly used. The patches came with Poser
7, iirc. As suggested by Sam, I added a background diffuse to the grass
(not in this image) but as the light comes from behind this is not going
to be too visible.
Haze and mist:
A general haze is obtained by the combination of two ground fogs, one
for near distance, the other for the far distance.
The ground mist is obtained by a media with boxed density_map using a
granite pattern.
Clouds:
Thanks to Zeger Knaepen's FastCloud macro.
Sky and Sun:
I used sunpos.inc for the Sun's position and CIE.inc for the Sun's
light. The sky_sphere makes use of the Sun's position too adapt the
horizon's color.
Victorian gentleman:
This is a simple Poser figure for which I made a frock coat and a top
hat in Silo 2. Gave him a cane too. Posed in Poser 8.
In order to find rapidly a correct position on the foreground rock, I
made use of Norbert Kern's Position Finder macro.
Birds:
Poser crows were randomly posed within a virtual object (VRand_In_Obj
once more) and translated to the correct position over the landscape.
I think I got everything.
Date: 7 Jun 2013 15:47:59
Message: <51B238EF.8090908@gmail.com>
The backgroud is really nice but the front need some improvements (grass
is dizzy...)
Good work tough :-)
Lightbeam
> This one is about Deep Time, i.e. the ages needed for sedimentation -
> uplift - erosion.
> The Victorian gentleman, obviously is Charles Lyell.
> Thomas
Date: 7 Jun 2013 18:02:42
Message: <51b25882$1@news.povray.org>
"Thomas de Groot" <tho### [at] degrootorg> wrote in message
news:51b1926d$1@news.povray.org...
Whoa. You weren't kidding when you said you've picked up a few things along
the way.
The picture looks good. I know you prefer to be left to your own creative
devices, but I'll offer that this might benefit from some more color.
 -Shay
Date: 8 Jun 2013 03:18:11
Message: <51b2dab3$1@news.povray.org>
> along the way.
<grin> Most things just gather dust in a remote corner of the HD. I have
an ambivalent feeling about this. On the one hand, they are tools,
nicely developed by others, more often than not in ways I am unable to
do but which fit well in work I undertake. In that sense they enhance my
creativity and help to achieve my goals without hampering the process.
On the other hand, I feel much indebted to all the people who, over the
years, came up with smart ideas and were willing to share them. My work
is as much the result of their contributions as to my own doings,
sometimes maybe more so. Well, that is of course all right. When you
paint, you also use the canvas, the paint, and the brushes made by
others ;-) At least, I try as much as possible to give credit to
everybody who contributed one way or another to the process.
> creative devices, but I'll offer that this might benefit from some more
> color.
I always accept hints ;-) What I do with them is another story.
I think you are right and I have had that same feeling for a couple of
days now. I believe this mostly has to do with the vegetation in the
valley which is a too uniform green soup. A bit boring indeed. I made
rocks peek through a bit more but that is clearly not enough. What is
needed is a wider range of greens in the trees and in the understory.
Spectacular would be an autumn scene, but that is not my intention here,
so I shall investigate more in the direction of pale yellow green and
darker shades.
As far as the rocks are concerned, I think they should remain as they
are, subdued shades of grey and browns.
Date: 8 Jun 2013 03:21:28
Message: <51b2db78@news.povray.org>
> is dizzy...)
> Good work tough :-)
Hey thanks, and good to see you here again. You commented on the very
first version; later in the thread, I posted a better image...
