POV-Ray : Newsgroups : povray.binaries.images : More Lego Star Wars Minifigures Server Time
28 Sep 2024 22:18:52 EDT (-0400)
  More Lego Star Wars Minifigures (Message 1 to 7 of 7)
Subject: More Lego Star Wars Minifigures
Date: 30 May 2013 16:42:42
Message: <51a7b9c2@news.povray.org>
Hi everyone,
I finally got around to finishing my next set of Lego Star Wars Minifigures:
- Princess Leia
- Qui-gon Jinn,
- Han Solo
- Yoda
- Chewbacca
Figures are modeled in LDraw, converted to DXF using LdrDat2Dxf, imported
into PoseRay (where I do some object smoothing), exported as mesh2 and then
rendered in POV-Ray. I use the Lego Color Reference guide here
http://guide.lugnet.com/color/ to setup the materials in POV-Ray.
Bye for now
Reuben
Download 3D Lego models and other resources from:
http://www.pearse.co.uk/lego
Download 'lego_minifigures_3d.png' (344 KB)
Preview of image 'lego_minifigures_3d.png'
Subject: Re: More Lego Star Wars Minifigures
Date: 31 May 2013 15:05:00
Message: <web.51a8f3885cd1e997d670fe1e0@news.povray.org>
"Reuben Pearse" <reu### [at] pearsecouk> wrote:
> Hi everyone,
They look good, Reuben! Render settings are nice too, though some SSS may be
needed ;)
So, certain details like Yoda's head were modeled in LDraw? Or was the model
already available?
Handy guide, although I wish they provided additional color info, such as RGB or
hex values. Would make things a bit easier.
Are you planning to provide other complete Lego sets in the future? I snagged
your cop car and helicopter (again), and was pleased to find out that they are
actually composed of separate Lego pieces. For some reason I thought they would
all be merged or something :P
Sam
Date: 1 Jun 2013 03:20:29
Message: <51a9a0bd$1@news.povray.org>
Le 31/05/2013 21:01, Samuel Benge nous fit lire :
Dive deeper: there is povray-include for the colors (one per color)
Date: 2 Jun 2013 13:01:12
Message: <51ab7a58@news.povray.org>
Hi Sam,
Thanks for the comments. I think the Lego models are *too* shiny. I started
investigating sub-surface scattering, but didn't really get very far. I
tried adding a finish that uses a subsurface setting, but it didn't seem to
make any difference. I've probably got the settings wrong. Does SSS work
when using HDR lighting?
I've uploaded the original version of a render of Qui-Gon Jinn to my
website - I'm using POV-Ray v3.7 RC7
http://www.pearse.co.uk/lego/models/qui-gonjinn/
Perhaps you could take a look at how SSS could be applied?
Thanks in advance
Reuben
"Samuel Benge" <stb### [at] hotmailcom> wrote in message
news:web.51a8f3885cd1e997d670fe1e0@news.povray.org...
>> Hi everyone,
>> Minifigures:
> be
> needed ;)
> model
> already available?
> RGB or
> snagged
> are
> would
> Sam
Date: 2 Jun 2013 21:50:03
Message: <web.51abf52f5cd1e99711b13fda0@news.povray.org>
> Hi Sam,
> Thanks in advance
> Reuben
Not sure if SSS is really needed, LEGO figures are pretty hard, solid plastic.
That said, I agree that they may be a little too shiny, I would approach this by
toning down the reflectivity.  If you are using Fresnel with ior (which I would
recommend if you are not), try keeping your ior in the range between 2.0 and
3.0.
Yoda, or at least the ones I have seen, have a rubber head.  So this would need
to be quite a bit less shiny and reflective (maybe SSS could help a ltille on
this one)
-tgq
Date: 3 Jun 2013 16:21:06
Message: <51acfab2$1@news.povray.org>
>> Hi Sam,
>> Thanks in advance
>> Reuben
> 3.0.
> this one)
> -tgq
Subsurface scattering is always present for plastics if it's not covered
by some metallic coating, like chroming.
Here, it should be keep to a low translucency level. Interior with an
ior is a must for both fresnel reflection and SSLT.
Normaly, subsurface only interact with regular light_source, and only
the regular finish is used to compute radiosity effects from the objects.
If you use HDR with radiosity to illuminate your scene, or any kind of
emissive object, you need to add this in the global_settings:
subsurface{radiosity on}
This allow radiosity illumination to affect the subsurface component.
Optionaly, you can also add in the radiosity block: subsurface on
This allow the subsurface to affect nearby object through radiosity.
Both options will increase the rendering time.
Most plastics have iors in the 1.3 to 2 range. Very few have higher ior
than that. Acrylic have the same ior as typical vegetal oil.
Date: 3 Jun 2013 16:30:00
Message: <web.51acfc305cd1e997826ce7c10@news.povray.org>
> Hi Sam,
POV's SSLT implementation does indeed work with radiosity, and by extension, HDR
lighting.
Maybe somebody more experienced with SSLT can help you. I've only been running
Lego tests in Blender + Cycles, and SSS comes cheap compared to POV-Ray.
Check out these two renderings:
http://i447.photobucket.com/albums/qq199/stbenge/misc%20renders/LegoSet18m_48s.jpg
http://i447.photobucket.com/albums/qq199/stbenge/misc%20renders/LegoSet8m_42s.jpg
Both were rendered in Cycles using beveling, SSS, radiosity, glossy (blurry)
reflections, and focal blur. (The render times were added to the file names.) As
you can see the SSS is barely noticeable, so maybe Trevor is right when he says
it may not be needed.
So perhaps the more important features you could be using are beveling, and
fresnel + glossy reflections.
Sam
