POV-Ray : Newsgroups : povray.binaries.images : Gancaloon: Old City street new version Server Time
28 May 2026 00:56:26 EDT (-0400)
  Gancaloon: Old City street new version (Message 21 to 30 of 43)
Subject: Re: Gancaloon: Old City street new version
Date: 17 Apr 2013 03:05:01
Message: <516e499d$1@news.povray.org>
On 16-4-2013 19:52, Anthony D. Baye wrote:
> I like the textures, except that the stones in the street look too clean and
> evenly worn for it to be an "Old" city.
Of course. Be aware that this is all in some kind of beta state. The end
product will show a very different street surface texture.
> The things that jar my sensibilities are the 2-1/2 foot drop from the bottom
> step of the second house on the right, the perfectly clean lines of the
> buildings and the grade of the street from one side to the other.
<grin> Most of this has been solved at this moment, except for the clean
lines of the buildings. Some degrading has still to be done on them.
> Just a suggestion, but you might consider making the street more level, if you
> can.  I understand that it's all one height field, but maybe you can find some
> way to deform it - say you were to take a spline of the street and flatten the
> pixels within a certain distance on either side, not necessarily perfectly
> level, but more level than it is.
This has been solved. For the close-up views a separate street surface
is generated, following the height_field but level cross-streetwise.
This is not an automatic process but modelled separately. Not so
difficult to do as I use a high-resolution mesh copy of the local
height_field for modelling purposes.
> I don't know how your macro would handle the adjustment to the terrain.
Simply by making a union of the street surface object and the
height_field before trace()
A new street view is being rendered.
> I really love the concept.
Thank you indeed. I have not finished exploring the possibilities.
Subject: Re: Gancaloon: Old City street new version 2
Date: 17 Apr 2013 03:26:43
Message: <516e4eb3@news.povray.org>
The same street after some improvements.
- a level street surface object is added.
- code influencing the buildings along the street boundaries has been
fine-tuned.
- doors, shutters, and bars have been added (not all visible here though).
Download 'gancaloon_old city street_07.jpg' (133 KB)
Preview of image 'gancaloon_old city street_07.jpg'
Date: 17 Apr 2013 06:40:00
Message: <web.516e7bbe9de2f6494cdc95b60@news.povray.org>
"s.day" <s.d### [at] uelacuk> wrote:
> Wow, thanks Alain, you have just supercharged the radiosity gathering stage of
> my renders. I need to do a comparisson for quality, I usually run a no focal
> blur/AA render to gather the radiosity data then reload this data with pretrace
> set to 1. The radiosity render was running at about 5 hours and with these
> settings is now taking about 7 minutes!
> Will run the final high quality trace now to see if it looks as good as my 5
> hour trace. Oh the hours I have wasted ;-)
> Sean
Ahh.. thought that was too good to be true, the quality was not so good, still
with a few tweaks I now have almost identical quality with a 2 hour radiosity
gathering stage so still a big improvement.
Thanks
Sean
Date: 17 Apr 2013 07:15:01
Message: <web.516e830869ef595a4cdc95b60@news.povray.org>
> fine-tuned.
> Thomas
Hi Thomas,
Looking better, I think adding some open shutters and mabe the odd door at a
random angle would be good.
Sean
Date: 17 Apr 2013 09:51:52
Message: <516ea8f8@news.povray.org>
Yes, I could indeed open some shutters. At this moment one of the two
available doors is ajar, but unfortunately it is not one of the doors
shown here :-) I could probably automate opening and shutting the doors
randomly. On my ToDo list.
Subject: Re: Gancaloon: Old City street new version 2b
Date: 17 Apr 2013 09:53:40
Message: <516ea964@news.povray.org>
An update of the Old City overview. State-of-the-art.
Download 'gancaloon_old city overview_03.jpg' (222 KB)
Preview of image 'gancaloon_old city overview_03.jpg'
Date: 17 Apr 2013 10:06:21
Message: <516eac5d$1@news.povray.org>
From the number of houses (single and double floored) I guestimate that
the population lies between 25000 and 30000 in this part of the city. :-)
Date: 17 Apr 2013 11:12:06
Message: <516ebbc6$1@news.povray.org>
Am 15.04.2013 23:46, schrieb Alain:
> The double nearest_count can affect the quality and the speed. The first
> value set the maximum bound to be used in areas where the samples have
> more variation. The second value is the minimal value to be used in
> areas where everything is prety uniform, like a large, plain wall.
No, not exactly.
Normally, during pretrace the whole image is scanned over and over again
with ever increasing resolution, as specified by the pretrace_start and
pretrace_end parameters. In each pass, for each individual location
probed it is checked whether the nearest_count condition is satisfied,
and if not, another sample is added there.
This is rather inefficient, as in regions where the individual locations
probed already did satisfy the nearest_count location, it is unlikely to
find individual locations that don't satisfy that condition yet.
If you specify a second parameter to nearest_count, regions where the
/average/ sample density satisfies this second condition in one pass are
skipped in any further pretrace passes.
Thus, the second parameter to nearest_count can be considered an average
sample density to aim for, while the first parameter can be considered a
local maximum sample density.
Date: 18 Apr 2013 07:46:23
Message: <516fdd0f$1@news.povray.org>
> Thomas
Both the last views of Gancaloon are magnificent!
Paolo
Date: 15 May 2013 14:40:00
Message: <web.5193d5539de2f6494aef9a7a0@news.povray.org>
> One step further. Some code clean-up and improvements, and, as shown, an
> added random texturing of the buildings.
> This version of the macros is gradually diverging from the one in
> p.b.s-f. I shall see how I can include the new features in the 'public'
> version ;-)
> Thomas
I can't be the first one to ask if you've seen "Marwencol." Just in case, I'd
strongly suggest watching it if you haven't.
 -Shay
