This made with three concentric spheres:
* The innermost sphere has a radius of 6000 units and has the land and
ocean texture.
* The middle sphere has a radius of 6009 units, textured with a granite
map that is highly perturbed (lambda = 4). The color map is clear to
.66, fading to full white at .67.
* The outermost sphere has a radius of 6010 units and is transparent
with a scattering media in the interior.
The scattering media and the clouds texture do a fair job of hiding the
lameness of the land texturing.
John
Download 'planet.png' (209 KB)
Preview of image 'planet.png'
Yes, it needs polar ice caps.
John
Am 28.03.2013 05:23, schrieb John VanSickle:
Does it?
> ocean texture.
> Regards,
> John
would you mind posting the code for the planet? I'd like to fiddle with the
landmasses and use it in my jumpgate scene.
A.D.B.
Looking very good indeed. A greenhouse planet obviously; the way we are
going ourselves ;-)
This is looking nice already.
The clouds are the most obvious fakeness as they are distributed
randomly and not according to realistic weather patterns. Unfortunately
this is really hard to do (my clouds looked worse when I tried this).
Also you are probably aware that on a photograph you would not
see stars or detail beyond the terminator. Of course people might
intentionally use multiple exposures for this so all is well ;)
Hope this helps,
John
//--- start of planet03.inc
#ifndef(PlanetTrans)
#local PlanetTrans = transform { }
#local textOcean = texture {
pigment { rgb <0,.01,.04>}
finish { diffuse 1 ambient 0 specular .125 roughness .02 }
#local textLand = texture {
pigment { granite
pigment_map {
[.7 granite translate y*5
color_map {
[.5 rgb <.125,.2,.1> ]
[.5 rgb <.35,.3,.25> ]
[.8 rgb <.125,.1,.075> ]
normal { granite
normal_map {
[.7 granite .01 ]
[.8 granite 1 scale .01]
union {
sphere { 0,1
granite
texture_map {
[.5 textOcean]
[.5 textLand]
scale 3
scale 6e3
sphere { 0,1 hollow
texture { pigment { rgbt <1,1,1,1> } }
interior {
media { scattering { 2, <.2,.6,1>*.01 } }
scale 6010
sphere { 0,1 hollow
pigment { granite turbulence 1 lambda 4
color_map {
[.65 rgbt 1]
[.66 rgb 1]
finish { ambient 0 diffuse 1 }
scale 6009
transform PlanetTrans
//--- end of planet03.inc
> Hope this helps,
> John
Thanks!
A.D.B.
