POV-Ray : Newsgroups : povray.binaries.images : Gancaloon: Old City street problem Server Time
26 Jun 2026 05:23:02 EDT (-0400)
  Gancaloon: Old City street problem (Message 11 to 15 of 15)
Subject: Re: Gancaloon: Old City street problem
Date: 27 Mar 2013 13:30:02
Message: <web.51532c5865932ef94c34011d0@news.povray.org>
> The advantage of the urbanism macro is that even at close up the scenes
> are looking good, like in this image.
> However...
> Thomas
That is a great view, fantastic to have been generated by a macro. You need to
add some dust/dirt to the floors to add more realism, should be easy to do ;-)
Date: 27 Mar 2013 18:25:01
Message: <web.5153703b65932ef9c2d977c20@news.povray.org>
> On 26-3-2013 9:59, Thomas de Groot wrote:
> My solution is to create a street surface related to the highest side of
> the street, extending enough over the other side to enable the trace()
> function to place the houses there at the correct level.
These are really nice views of your city!
I assume that you *do* want sloping streets(?) They look very natural like that,
IMO. So if I understand the problem correctly, the sides of the buildings that
are lower down on the slope are being 'buried', while the sides with the steps
and the door are looking too high (that is, the steps etc. are ending before
they reach the ground.)
Although I don't know the method you are using to trace() the buildings onto the
ground (if indeed that *is* the method you're using), it seems to me that the
trace for each building should be done at all four corners--four traces, in
order to get the *highest* of the four. Then, that elevation would be the one to
place the building at. And along with that idea, the buildings/steps etc. would
need to be built so that they *always* extend farther into -y. Most of the time,
that extra building depth would not be seen--it would be underneath the
ground--but in situations such as in your example scene, it would show up and
look natural. (Yes, there would be *lots* of steps, depending on the ground
slope--but that might look quite nice.) I'm thinking that the 'extra' building
depth (and steps) should be deep enough in -y to compensate for, say, a 45-deg.
ground slope(!) as a maximum. Or maybe 35-40 deg.
Date: 28 Mar 2013 04:09:47
Message: <5153facb$1@news.povray.org>
Thanks Kenneth.
The 'only' problem is the /sidewise/ slope of the street surface, if I
make myself clear. So, in any case, that surface has to be corrected,
otherwise carts will turn over :-)
I only trace the centre point of the buildings, which obviously is too
few a test to use on highly uneven surfaces. Your suggestion is good,
however an extra test would be needed: Depending on which /side/ of the
street the building is to be situated (high or low end) the /lowest/ or
the /highest/ test should be selected. Now, I assume that I can know
this by testing the height of the nearest street boundary to the
building... Hmm. I have to test this to see how that works.
They already do ;-)
> Most of the time,
Indeed. Still, as I said above, the street surface should not slope too
much laterally in order to be useful. There still is the need for a
/built/ street surface...
Date: 28 Mar 2013 04:12:18
Message: <5153fb62$1@news.povray.org>
Yes, it is even looking better than I expected. In addition to dust, I
need also to diversify a bit more the house types. Also easy to do and
only needing a little adaptation of the macro.
Date: 28 Mar 2013 05:35:28
Message: <51540ee0@news.povray.org>
yes indeed. I think it needs an export to some game
engine terrain system that you can walk around in it ;)
