POV-Ray : Newsgroups : povray.binaries.images : See: povray.beta-test: REquesting user feedback: POV-Ray v3.7 scenes/includes Server Time
28 May 2026 02:14:13 EDT (-0400)
  See: povray.beta-test: REquesting user feedback: POV-Ray v3.7 scenes/includes (Message 21 to 30 of 44)
Subject: Re: See: povray.beta-test: REquesting user feedback: POV-Ray v3.7scenes/includes
Date: 2 Mar 2013 03:06:52
Message: <5131b31c$1@news.povray.org>
On 2-3-2013 2:50, Christian Froeschlin wrote:
> Thomas de Groot wrote:
>>> You have the data for where the buildings are but how do you translate
>>> that into a ground texture pattern?
>> I have no idea presently.
> Depending on how the data looks like
> 1. If you have some sort of geometric data (corners of the boxes
> for the building base or suchlike) you can use it to create somewhat
> larger boxes for use in an object pattern.
In this case the buildings are randomly dispersed within a pre-defined
object. Writing away the geometric data would be possible, without
knowing what the final union of buildings would look like however.
> 2. If you have some sort of floor plan as an image_map or similar,
> you can use 2d image processing methods to produce an image where
> the building locations are expanded by some amount (e.g. using a
> minimum/maximum filter, depending on the software you have you can
> also simlpy apply some smooothing).
The block object defining the contours of the building union can be
drawn according to an image_map of street patterns on the underlying
height_field.
Subject: Re: See: povray.beta-test: REquesting user feedback: POV-Ray v3.7 scenes/includes
Date: 2 Mar 2013 03:39:40
Message: <5131bacc@news.povray.org>
Illustrating my answer to MichaelJF in p.b.s-f (Note 2); here using a
different set of basic building elements (on its way to Gancaloon use).
T
Download 'urbanism2_test.png' (482 KB)
Preview of image 'urbanism2_test.png'
Subject: Re: See: povray.beta-test: [snip] next version
Date: 3 Mar 2013 07:47:54
Message: <5133467a@news.povray.org>
This is an improved version. Note that a next step would be to clean up
the inner spaces of the houses ;-)
Improved code in p.b.s-f
Download 'urbanism2_test.png' (394 KB)
Date: 3 Mar 2013 14:24:52
Message: <5133a384@news.povray.org>
> Thomas
Now, add the possibility to have non-square buildings and some with 5,
6, 7 or even more sides. Appen all the time when the neibouring
buildings are not aligned to some orthographic gird.
Date: 3 Mar 2013 16:16:14
Message: <5133bd9e$1@news.povray.org>
And three sided buildings. Okay maybe, actually four sides but the
fourth side is very small. This sometime happens when they are built at
a Y junction.
Or a hypercube.
Only kidding, Thomas. ;-)
Regards
Date: 4 Mar 2013 03:06:12
Message: <513455f4$1@news.povray.org>
I'll think about it. The buildings themselves are not the problem and
can be added by anybody presently. However, if the code has to be
adapted to their use, that would be a major overhaul and one I am not
yet prepared to do because it would need a different approach. Here, the
locations are chosen randomly but apart from testing for too much
overlap, there is no control towards proper shape intersection.
Date: 4 Mar 2013 03:08:36
Message: <51345684@news.povray.org>
> a Y junction.
I would love to do that but am presently unable to implement something
like that :-)
> Or a hypercube.
Now, this I am taking seriously :-) Hypercubes in a spatial arrangement...
Date: 4 Mar 2013 06:37:43
Message: <51348787@news.povray.org>
>> In real life, you can have cases when you have prety small elevation
>> differences between roofs or floors, especialy when they belong to
>> different buildings.
but I think its rare within a building to have something like 0.5m
height difference between floor corners, leading to all the non-level
baselines. If its a steep slope it may get an additional floor (2-3m?)
but otherwise I'd expect the floor to be roughly levelled. So the
architecture shapes the ground to some extent.
Date: 4 Mar 2013 07:08:58
Message: <51348eda$1@news.povray.org>
You'd be surprised... ;-)
Date: 4 Mar 2013 16:51:24
Message: <5135175c$1@news.povray.org>
Le 04/03/2013 09:08, Thomas de Groot nous fit lire :
>> Or a hypercube.
It would allow to make a lot of money selling the same house more than
one time, with doors on different side opening to each 3D cube of the
hypercube.
I wonder about the associated taxes: based on external 2D projection on
ground, or actual volumes ?
