POV-Ray : Newsgroups : povray.binaries.images : See: povray.beta-test: REquesting user feedback: POV-Ray v3.7 scenes/includes Server Time
28 May 2026 03:36:34 EDT (-0400)
  See: povray.beta-test: REquesting user feedback: POV-Ray v3.7 scenes/includes (Message 15 to 24 of 44)
Subject: Re: See: povray.beta-test: REquesting user feedback: POV-Ray v3.7scenes/includes
Date: 28 Feb 2013 18:20:39
Message: <512fe647$1@news.povray.org>
On 28/02/2013 11:56 PM, Thomas de Groot wrote:
> This shows the latest version.
> Thomas
This is neat!
Its got me thinking about road and ground textures.
Based on the location of the buildings, what would be the easiest way to
texture the ground?  So the ground texture between the buildings have a
different texture to the ground texture at the base of the buildings?
You have the data for where the buildings are but how do you translate
that into a ground texture pattern?
Cheers Dre
Date: 1 Mar 2013 03:04:01
Message: <513060f1$1@news.povray.org>
On 1-3-2013 0:20, Dre wrote:
> This is neat!
The quick and dirty solution is: Don't bother about the ground /under/
the buildings; it is invisible ;-)  So, just one texture is needed.
That being said however...
I have no idea presently.
Subject: Re: See: povray.beta-test: REquesting user feedback: POV-Ray v3.7 scenes/includes
Date: 1 Mar 2013 13:17:11
Message: <qh770a-oak.ln1@meles.unex.es>
> Thomas
You may want to avoid too small differences between floor heights, as in the
bottom left corner of the town
light_source{9+9*x,1}camera{orthographic look_at(1-y)/4angle 30location
9/4-z*4}light_source{-9*z,1}union{box{.9-z.1+x clipped_by{plane{2+y-4*x
0}}}box{z-y-.1.1+z}box{-.1.1+x}box{.1z-.1}pigment{rgb<.8.2,1>}}//Jellby
Date: 1 Mar 2013 15:59:20
Message: <513116a8$1@news.povray.org>
>> Thomas
In real life, you can have cases when you have prety small elevation
differences between roofs or floors, especialy when they belong to
different buildings.
I have seen case with a difference of about 0.5 to 5 cm.
In some cases, it's a mather of the ground under one of the buildings
been slightly less hard or compact. This can appen when the later
building is built a few years later over a former court yard.
The former building had time to settle down, then, the newer building,
built flush with the older one, get to settle down. It can also cause
some serious cracking and bending of the walls and floors...
Date: 1 Mar 2013 20:50:12
Message: <51315ad4$1@news.povray.org>
Depending on how the data looks like
1. If you have some sort of geometric data (corners of the boxes
for the building base or suchlike) you can use it to create somewhat
larger boxes for use in an object pattern.
2. If you have some sort of floor plan as an image_map or similar,
you can use 2d image processing methods to produce an image where
the building locations are expanded by some amount (e.g. using a
minimum/maximum filter, depending on the software you have you can
also simlpy apply some smooothing).
Date: 2 Mar 2013 03:01:04
Message: <5131b1c0$1@news.povray.org>
>> in the
Exactly so.
Date: 2 Mar 2013 03:06:52
Message: <5131b31c$1@news.povray.org>
In this case the buildings are randomly dispersed within a pre-defined
object. Writing away the geometric data would be possible, without
knowing what the final union of buildings would look like however.
The block object defining the contours of the building union can be
drawn according to an image_map of street patterns on the underlying
height_field.
Date: 2 Mar 2013 03:39:40
Message: <5131bacc@news.povray.org>
Illustrating my answer to MichaelJF in p.b.s-f (Note 2); here using a
different set of basic building elements (on its way to Gancaloon use).
T
Download 'urbanism2_test.png' (482 KB)
Preview of image 'urbanism2_test.png'
Subject: Re: See: povray.beta-test: [snip] next version
Date: 3 Mar 2013 07:47:54
Message: <5133467a@news.povray.org>
This is an improved version. Note that a next step would be to clean up
the inner spaces of the houses ;-)
Improved code in p.b.s-f
Download 'urbanism2_test.png' (394 KB)
Date: 3 Mar 2013 14:24:52
Message: <5133a384@news.povray.org>
> Thomas
Now, add the possibility to have non-square buildings and some with 5,
6, 7 or even more sides. Appen all the time when the neibouring
buildings are not aligned to some orthographic gird.
