POV-Ray : Newsgroups : povray.binaries.images : Doodling Server Time
28 Feb 2025 01:06:36 EST (-0500)
  Doodling (Message 1 to 10 of 13)
Subject: Doodling
Date: 14 Feb 2013 11:13:32
Message: <511d0d2c@news.povray.org>
messing around with a blender torus knot plug-in ... i tried several
other materials (wood, metal, ceramic) but the glass looked best. the
ground plane has waves for now ... facets ain't bad either!
Download 'work.png' (718 KB)
Preview of image 'work.png'
Subject: Re: Doodling
Date: 14 Feb 2013 15:16:06
Message: <511d4606$1@news.povray.org>
I like this. I especially like the red of the torus knot. Although I
wonder if max_trace_level should be a bit higher.
Regards
Date: 14 Feb 2013 18:20:01
Message: <web.511d6fe72c513e0bc2d977c20@news.povray.org>
Complex and sophisticated! Very nice.
I kind of wish it were a little brighter, though; then I could clearly see all
the wonderful details.
Date: 15 Feb 2013 03:19:56
Message: <511defac$1@news.povray.org>
The red of the glass is fascinating and attractive.
Like Stephen suggested, there are some small artefacts still visible.
Date: 15 Feb 2013 06:05:01
Message: <web.511e15e62c513e0bc2d977c20@news.povray.org>
I'm always leery of .png images and how they show up in web browsers (a legacy
of the past, I guess; can't shake that feeling.) As your post looks a bit dark
on my end, I was wondering if I'm seeing what you see. Of course, the look may
be just as you intended; but here's a screenshot (as seen in latest Firefox on
my Windows XP machine) and saved as a .jpeg.
Download 'screenshot.jpg' (97 KB)
Preview of image 'screenshot.jpg'
Date: 15 Feb 2013 07:05:05
Message: <511e2471$1@news.povray.org>
i've got a wee bit of normal on the glass ... maybe that's it
(max_trace_level already at it's upper limit 256)
Date: 15 Feb 2013 07:21:17
Message: <511e283d@news.povray.org>
hmmm ... thanks for the feedback on darkness you guy's. i'm fooling
around with a back-lit approach and obviously it still needs help. one
thing i /did/ change this morning was to bump up the fade_distance on
the glass material. where i'd like to end up with this is glass that has
some zing to it while muting the background ... maybe a fools errand :-)
btw: the screen shot doesn't look overly dark to me
Date: 15 Feb 2013 10:48:56
Message: <511e58e8@news.povray.org>
>> (a legacy
>> bit dark
>> look may
>> Firefox on
here's a much better rendition ... changed hdr background and aligned
the sun in the image with the key light. changing fade_distance on the
glass helped some, but ended up having to add a fill light 180 and much
lower than the key light, it's also (the fill light) the same color as
the glass. i also added photons (excluded the fill light) ... oh and
removed the normal from the glass
Download 'torusknot.png' (1168 KB)
Preview of image 'torusknot.png'
Date: 15 Feb 2013 12:53:59
Message: <511e7637$1@news.povray.org>
>> (a legacy
>> bit dark
>> look may
>> Firefox on
It looks as dark to me than the original. I wonder if it have anything
to do with my CTR monitor compared to the LCD ones... My display gamma
is at about 2.5. If I increase the brightness to correctly see the
image, my text becomes all blury.
Date: 15 Feb 2013 13:38:17
Message: <511e8099@news.povray.org>
>>> (a legacy
>>> bit dark
>>> look may
>>> Firefox on
could be ... it looks the same in preview window, gwenview, gimp, t-bird
(this post) and f-fox (on my blog) ... sometime ago i went through all
the gymnastics of getting my display calibrated (gamma-wise) so i'm at a
loss. since the object is back-lit you'd expect the foreground to be
dark-ish right?
jim
