POV-Ray : Newsgroups : povray.binaries.images : smooth mesh outline artifacts fix Server Time
29 Sep 2024 00:16:24 EDT (-0400)
  smooth mesh outline artifacts fix (Message 1 to 5 of 5)
Subject: smooth mesh outline artifacts fix
Date: 8 Jan 2013 18:41:33
Message: <50ecaead@news.povray.org>
One type of artifacts seen with smoothed meshes is dark specks, and/or
the interior_texture poking through, at the mesh's outline; see the
first image for an example.
Those artifacts can be avoided with a patch, as seen in the second
image. (The one remaining red triangle is actually a hole in the mesh,
not an artifact.)
Download 'mesh_artifacts_37.png' (72 KB) Download 'mesh_artifacts_37_patched.png' (70 KB)
Preview of image 'mesh_artifacts_37.png'
Preview of image 'mesh_artifacts_37_patched.png'
Subject: Re: smooth mesh outline artifacts fix
Date: 9 Jan 2013 03:19:34
Message: <50ed2816$1@news.povray.org>
> not an artifact.)
Excellent. I noticed these artefacts indeed lately with the Satrap's
veil: the interior_texture was partly poking through in places and I
initially thought it was a modelling problem.
Date: 9 Jan 2013 03:52:27
Message: <50ed2fcb$1@news.povray.org>
> and/or the interior_texture poking through, at the mesh's outline;
> see the first image for an example.
> mesh, not an artifact.)
   Sweet... I sometimes resorted to insane subdivision levels to try to
avoid these.
   We need you to render regular scenes more often, so you can find
things to fix... ;)
   Thanks,
Jaime
Date: 9 Jan 2013 07:00:01
Message: <web.50ed5b61cb9618f0c2d977c20@news.povray.org>
> Those artifacts can be avoided with a patch...
That's quite amazing.
I had always thought that these kinds of anomalies were 'unfixable'--a natural
consequence of the smooth_triangle normals at the edges of objects. (As in 2.4.8
in the docs, "The shadow line artifact.") The only *partial* solution I've ever
found (which has been noted in the past) is the use of 'double_illuminate.' But
that was always kind of a kludge.
Your patch would be *most* welcome!! Nice work.
Date: 9 Jan 2013 10:22:06
Message: <50ed8b1e$1@news.povray.org>
Am 09.01.2013 12:58, schrieb Kenneth:
Make no mistake - these are only the artifacts at the outline; the
classic shadow line artifacts are a trickier case.
I'm sure it will find its way into POV-Ray proper. Not for 3.7.0 (the
necessary changes go too deep), but I'd expect a 3.7.1 shortly after.
