POV-Ray : Newsgroups : povray.binaries.images : Another portrait from Gancaloon Server Time
26 Jun 2026 05:23:03 EDT (-0400)
  Another portrait from Gancaloon (Message 29 to 38 of 38)
Subject: Re: Another portrait from Gancaloon wip2
Date: 17 Dec 2012 19:25:01
Message: <web.50cfb66fe7ecd71485de7b680@news.povray.org>
> On 17-12-2012 12:11, Ive wrote:
> > I see the same effect Christian did mention - to me it looks like some
> > badly done photoshopping where the face is pasted but does not match the
> > lighting condition.
> Additional thought: Why is it that I do not see at all what you and
> Christian seem to see? Not because I am the maker, that is not good
> enough for me. I am truly puzzled.
I, too, see the effect Christian and Ive talk about; it looks exactly like bad
Photoshopping.  (And like Ive, I must stress that photorealism is not the
issue.)  My first instinct was that the contrast on the face isn't deep enough;
but I know /just/ enough about color matters to consider the factors that I
don't know enough about.  I must defer to Ive on these matters.  (If he's good
enough for Jaime, he's good enough for me.)
("He"?  I don't know.  Curse the English language for requiring me to know this
information!  (Yes, formal grammar prescribes the word "he" in this situation.
Oink.))
Date: 17 Dec 2012 22:40:34
Message: <50cfe5b2$1@news.povray.org>
Am 17.12.2012 21:30, schrieb Christian Froeschlin:
> Don't discard the old eyes until you're sure the difference it
> not from the monitor. Actually mine is very old and poorly calibrated
> but I'm sure Ive has gamma correction at hand-counted photon level ;)
Yes, did this when I was young, patient and poor - meanwhile I let do
machines this kind of work for me.
But more seriously, I was always puzzled about the lack of interest in
well calibrated viewing devices that seems so common among people within
these newsgroups.
In my former line of work - among photographers - it was simply out of
the question that a perfectly calibrated high end monitor is a *basic*
requirement for judging any graphics related work.
Well, given that we are all just CGI hobbyists, and a good monitor isn't
cheap - but a gaming graphics card or quad-core machine isn't cheap
either and people seem to have no problem spending money for these. On
the contrary things seem even worse now as in former times every
calibrated mid-class CRT was already better than any contemporary
high-end TFT.
-Ive
Date: 17 Dec 2012 23:51:10
Message: <50cff63e$1@news.povray.org>
Am 18.12.2012 04:39, schrieb Ive:
> these newsgroups.
I guess it's mainly underestimation (due to lack of personal experience)
what a difference a good and well-calibrated display can make.
The half-hearted support for gamma handling in older versions of POV-Ray
might also have contributed in the past.
 > On the contrary things seem even worse now as in former times every
> high-end TFT.
I suspect that's not true - if only because the CRTs of former times
were typically connected to the graphics adapter via some analog
interface and were therefore subject to both static and dynamic signal
distortions; suffered from both static and dynamic geometric
distortions; and came with ergonomic problems due to inherent flickering
and buildup of static electricity.
Of course all these problems were less prominent in mid-class CRTs than
in low-end ones, but I suspect that it would have taken high-end
equipment to reduce them to entirely unproblematic levels.
(BTW, just to avoid any misunderstanding: When I hear "high-end TFT" I
think "graphics enthusiast's dream", not "gamer's dream" or some such.
You know, the stuff that comes with an elaborate individual factory
calibration report included.)
Date: 18 Dec 2012 03:44:25
Message: <50d02ce9@news.povray.org>
On 17-12-2012 18:17, Ive wrote:
> Note that I'm not concerned about photorealism, it is the inconsistence
> that bothers me.
> Given the shadow on the back wall gap and the sharp shadow line in the
> face the scene suggest to be lit by direct sunlight. But in this case
> the dynamic range between the lit/unlit parts of the face is way too
> low. The shadowed face parts are also too bright compared to the
> shadowed wall gap. In other words, the shadows in the face are way too
> bright - or the lit parts way too dark, depending on the exposure
> setting of your camera.
OK, fair enough. I know that this is a simple scene setting for testing
the look of clothing in particular, and /not/ intended for fashion
photography outdoors ;-) So the scene should not be judged in that
light. In the present case, the contrast with the dark cloth is too
revealing apparently.
> The only way to make the face look as soft within direct sunlight would
> be by adding a lot of reflectors as done e.g. for outdoor fashion
> photography, but in this case the veil would also look very different.
> As the clothing is now it looks more like within an old master painting.
> This inconsistence creates this copy'n'paste impression for me.
> I think your setup for testing poser people/clothing is a bit
> unfortunate. Personally I do use two different setups for *quick*
> indoor/outdoor testing and textures are *good* when they pass both tests.
In time, I shall look into a better setup for the testing ground, but I
must say that I am not as demanding as you are on this matter ;-)
Date: 18 Dec 2012 03:48:47
Message: <50d02def$1@news.povray.org>
Ive is the authority indeed and I shall consider some improvements to
the test setup following his comments, but as I answered to his post, I
am not as demanding and am still fairly satisfied with this (test)
image. Later scene building with this figure will show how it reacts to
the real environment. In the mean time, I go on tweaking and experimenting.
Date: 18 Dec 2012 03:56:32
Message: <50d02fc0$1@news.povray.org>
On 17-12-2012 20:49, Stephen wrote:
> Anyone know of a good second hand eye shop? Because it looks good to me.
> Although, maybe a fill in light on his RHS (left as you look at it)
> might help.
I would need one too (an eye shop) although the eyes still function to
satisfaction. ;-)
One day I shall improve the scene setup (low priority) to make it
Ive-proof ;-)
Date: 18 Dec 2012 08:20:01
Message: <web.50d06cdbde8ee865f2eb76540@news.povray.org>
James Holsenback <nom### [at] nonecom> wrote:
> On 12/17/2012 04:12 PM, Stephen wrote:
> > I am not a betting man but I bet you a Mars bar that he has. ;-)
> LOL ... raise ya a Snickers ;-)
Nope! The steaks are too high. I think that I will cash im my chips (fries to
you. ;-) )
Date: 18 Dec 2012 08:35:01
Message: <web.50d07042de8ee865f2eb76540@news.povray.org>
> > might help.
> satisfaction. ;-)
Aye! Mine could focus quicker for my comfort.
> Ive-proof ;-)
Let me know when that happens. ;-)
Seriously, I look beyond the image and see the intent. Maybe because that in
real life you have to interpret what your eyes see to make sense to your brain,
until you no longer look at it. Or maybe it is the result of my misspent youth.
(Ooo! pretty colors)
Date: 18 Dec 2012 10:08:30
Message: <50d086ee$1@news.povray.org>
>>> might help.
>> satisfaction. ;-)
I know what you mean.
>> Ive-proof ;-)
I'll do my best ;-)
Yep, so true! And also in the good old days of B/W photography is my
experience. Oh well, I just learned successfully to turn a pair of boots
I took from Apollo Maximus into conforming ones for Ryan, by using
Poser's Setup Room. I am well pleased. A few little glitches remain but
overall the work was simple. Most work was in Silo where I had to adapt
the geometry to the new hierarchy.
Date: 18 Dec 2012 15:35:10
Message: <50d0d37e$1@news.povray.org>
Am 18.12.2012 05:50, schrieb clipka:
>> these newsgroups.
>> high-end TFT.
By writing *calibrated* mid-class CRT, I was referring to professional
graphics usage and there was a Mac or PC equipped with a Matrox graphics
card (and its superior analog signal quality but lack of 3d
acceleration) de-facto standard.
My own CRT did run at a 1600x1200 resolution with 100Hz frequency. It
had minor divergence problems at the corner pixels but was able to
actually show pitch black pixels (and off course all shades of near
black) where my current TFT shows something my wife would call medium
anthracite.
This is what I really do miss. And - as it is winter again - it's
ability to heat the whole room. Not so fortunate during summer and one
of the reasons I had to dismiss it ;)
-Ive
