POV-Ray : Newsgroups : povray.binaries.images : Fruits bowl Server Time
26 Jun 2026 06:39:30 EDT (-0400)
  Fruits bowl (Message 11 to 20 of 20)
Subject: Re: Fruits bowl
Date: 21 Nov 2012 04:38:13
Message: <50aca105@news.povray.org>
Here is another one: the fruits are still the same, but I changed the
bowl material to glass, with dispersion and photons (8h). It doesn't
looks as great as I hopped, but it's nice anyhow.
Jaime
Download 'fruits-bowl-08.jpg' (311 KB)
Preview of image 'fruits-bowl-08.jpg'
Date: 21 Nov 2012 05:00:59
Message: <50aca65b$1@news.povray.org>
Am 21.11.2012 10:37, schrieb Jaime Vives Piqueres:
It does add a lot of believability though.
Date: 21 Nov 2012 06:50:13
Message: <50acbff5@news.povray.org>
yep .. i like the glass better as well
Date: 21 Nov 2012 07:45:51
Message: <50acccff@news.povray.org>
> Jaime
This one is great!
Date: 21 Nov 2012 09:22:18
Message: <50ace39a$1@news.povray.org>
Le 21/11/2012 10:32, Jaime Vives Piqueres a écrit :
>> http://www.econym.demon.co.uk/isotut/real.htm
>   Thanks: I didn't remember that one. Now, if I could get a mesh with
> the same shape for the simulation... :)
Notice: you have the function(s) using (u,v), it is just up to you to
write a small code in C or whatever to explore the uv surface (two
nested for() ), and get for each value a point (x,y,z)
Then connect them in a mesh (in whatever format you need)
In fact, the small C code could as well output your mesh.
Date: 27 Nov 2012 06:47:08
Message: <50b4a83c@news.povray.org>
   Yeah... and rendering time: lots of it! :) This one would have taken
at least 4-5 days for an "all-in-one" render, but I managed to render it
under 8h by saving radiosity and photons beforehand.
   The photons where saved without using radiosity nor area light nor
focal blur, but using the final glass texture with dispersion. It
rendered in some minutes.
   The radiosity (Radiosity_Normal) was saved without using photons, nor
area light nor focal blur, and also making the glass just rgbt 1. Again
this pass rendered in some minutes.
   The final pass loaded the photons and radiosity, and used area lights
and focal blur (35 samples). It took 7h52m.
   Now that I've a setup reasonably fast, I will try to do a better job
with the fruits...
Jaime
Download 'fruits-bowl-09.jpg' (282 KB)
Preview of image 'fruits-bowl-09.jpg'
Date: 3 Dec 2012 00:20:02
Message: <web.50bc35b5c7fa8976c2d977c20@news.povray.org>
Those are absolutely gorgeous images. Something for me to aspire to (in maybe 20
years' time!!)
Date: 3 Dec 2012 03:15:41
Message: <50bc5fad@news.povray.org>
   Thanks!
> Something for me to aspire to (in maybe 20 years' time!!)
   Well, in fact it took me almost 20 years to arrive at that level...
but I'm slow in getting things right, and laziness doesn't helps. I'm
really sure you can get there a bit sooner... ;)
Jaime
Date: 1 Feb 2013 00:05:01
Message: <web.510b4ceac7fa897632076fd10@news.povray.org>
Gorgeous! In the tradition of all those past painter artists...
Why not to go further with POV-Ray, and create new type of fruits?
Date: 1 Feb 2013 05:43:31
Message: <510b9c53$1@news.povray.org>
   Thanks!
   Nice idea, but one that needs a very good imagination at work... not
my case, unfortunately. :(
jaime
