POV-Ray : Newsgroups : povray.binaries.images : To Encore, Making part of an object tranparent Server Time
28 May 2026 02:14:41 EDT (-0400)
  To Encore, Making part of an object tranparent (Message 29 to 38 of 38)
Subject: Re: To Encore, Making part of an object tranparent
Date: 6 Dec 2012 12:34:00
Message: <50c0d708$1@news.povray.org>
Le_Forgeron wrote:
> Le 06/12/2012 16:33, Encore nous fit lire :
>>> I have it figured out, by not using the orthographic camera, but pulling
>>> the camera way back from the object and then zooming in. It didn't work
>>> the first time because I had a mix-up in my math.
>>> Camera distance increased by 1000
>>> Ger
>> So basically you change the Cam0Location to something like
>> #declare Cam0Location =  < 0 , 1 ,-1000>;
>> which puts it to -1000 on the z-axis. How would you zoom in then after
>> that?
> I guess: a small angle.
No, what I did was increase direction
#declare CamFactor = frame_number/100;
//#declare CamFactor = 1000;
#declare CamAngle = frame_number;
#declare Cam0Location =  < 0 , (1+CamFactor) ,0>;
#declare Cam0Location = vrotate(Cam0Location, <0, 0, CamAngle>);
#declare Cam0Location = vrotate(Cam0Location, <0, CamAngle, 0>) + (<-3, 3,
-3>*(1+CamFactor));
#declare Cam1Location =  <8.0 , 1.5 ,5>;
  Declare the illusion camera pointing along the z-axis
#declare UseIllusionCamera = 1;
#if (UseIllusionCamera)
        location Cam0Location
        look_at   <0.0 , 0.0 , 0.0>
        direction z * CamFactor
        right image_width / image_height * x
Doing it this way gives me a perfect view on what the difference is
Ger
Date: 6 Dec 2012 12:39:49
Message: <50c0d865$1@news.povray.org>
>> > that?
> Yeah I was about to post  another reply about that.
> I changed the angle to about 0.380
> and the #declare Cam0Location =  < 0 , 1000 ,-1000>;
> After that, I needed to translate the camera along the x-axis like this:
> #declare Cam0Location = vrotate(Cam0Location, <0, CamAngle/1, 0>) + <450,
> #30,
> -3>;
> It still needs some configurations but the problem is that the wedges do
> not extend until the object anymore, so the result looks something like
> what you can see in the screenshot:
I had a mix-up in my code which wasn't apparent at short distances. I have
tried it with direction z * 1e8 and it still works now.
Ger
Date: 6 Dec 2012 13:50:00
Message: <web.50c0e7d6f594feb25155d83e0@news.povray.org>
> Ger
Ah so that was the problem with direction. I tried z*1000 but it wouldn't work.
Thanks a lot, I'll animate this and upload my results soon!
Date: 6 Dec 2012 14:25:01
Message: <web.50c0f0def594feb25155d83e0@news.povray.org>
> > Ger
I have a question:
Why is the CamFactor first set to frame_number/100 and then instantly changed to
1000?
What is the use of that?
Date: 6 Dec 2012 14:33:35
Message: <50c0f30f$1@news.povray.org>
>> > have tried it with direction z * 1e8 and it still works now.
>> > Ger
>> work. Thanks a lot, I'll animate this and upload my results soon!
> I have a question:
> changed to 1000?
I used the first one to create an animation that showed me the progress when
increasing the camera distance. So, if you remark the second one out you'll
get an animation where the camera starts close to the cube and gradually
moves back.
Ger
Date: 6 Dec 2012 14:45:03
Message: <web.50c0f5a3f594feb25155d83e0@news.povray.org>
> Ger
Great. I would also like to report a bug. During the animation rendering, I
noticed several frame where the back pipe is glitchy, when it come in front of
the front left horizontal pipe. I'll post one of those frames to show you what I
mean.
It definitely not a shadow problem, I tried this with both shadows and without
and I get the same problem.
Alex
Download 'transpattempt4256.bmp.dat' (2305 KB)
Date: 6 Dec 2012 14:57:41
Message: <50c0f8b5$1@news.povray.org>
Encore wrote:
>> Ger
> I noticed several frame where the back pipe is glitchy, when it come in
> front of the front left horizontal pipe. I'll post one of those frames to
> show you what I mean.
> without and I get the same problem.
> Alex
Yes, I noticed that too, but so far I have not found what the problem is.
Ger
Date: 6 Dec 2012 15:01:37
Message: <50c0f9a1@news.povray.org>
Ger wrote:
> Encore wrote:
>>> Ger
>> Alex
Oh, and as an aside, please don't post .bmp files. Use either .png when
quality is important or .jpeg. Not everyone here has Mb internet access.
Ger
Date: 6 Dec 2012 15:15:00
Message: <web.50c0fc13f594feb25155d83e0@news.povray.org>
> Ger
Yeah thanks for letting me know, it was my intention to post this file. Do you
know how I can remove a post?
Date: 6 Dec 2012 15:25:27
Message: <50c0ff37$1@news.povray.org>
Encore wrote:
>> Ger
> you know how I can remove a post?
You can simply cancel it.
Ger
