POV-Ray : Newsgroups : povray.binaries.images : Lego Superman - Man of Steel Server Time
28 May 2026 02:14:41 EDT (-0400)
  Lego Superman - Man of Steel (Message 11 to 20 of 24)
<<< Previous 10 Messages Goto Latest 10 Messages Next 4 Messages >>>
Subject: Re: Lego Superman - Man of Steel
Date: 4 Nov 2012 20:04:29
Message: <5097109d$1@news.povray.org>
Am 04.11.2012 20:46, schrieb MichaelJF:
> Yes, your proposal is much more detailed than mine. In fact I only mentioned the
> general idea that simply averaging pictures of a flight will not yield a motion
> blurred picture and proper weights are needed.
As a matter of fact, for /realistic/ motion blur simple averaging of the
images /is/ the proper method. Whike the "opaque object with transparent
trail" look is a common staple - probably invented to give the
impression of motion while at the same time preserving object detail -
it is outright wrong.
Date: 5 Nov 2012 03:19:17
Message: <50977685$1@news.povray.org>
On 4-11-2012 20:02, MichaelJF wrote:
>> Ah! A little trick I might need. The animation ng is not regularly open
>> on my system, but I should give it a look once in a while :-)
>> Thomas
> Ah! That is why I get no comment from you to my first (very technically) entry
> there. And I value your comments very much ;-)
<blush> I shall have to experiment with this then... ;-)
Date: 5 Nov 2012 12:55:01
Message: <web.5097fd6bd7842808c1b0476d0@news.povray.org>
Thanks, clipka... I knew I wasn't going crazy :) Maybe MJF is confusing motion
blur with tracers?
Date: 5 Nov 2012 13:13:51
Message: <509801df$1@news.povray.org>
>> mentioned the
>> a motion
e
t
	The "opaque object with transparent trail" is also what you get
with a flash light synced on the rear curtain and a long(ish)
exposure time (if you don't sync on the rear curtain, the "trail"
will be in front of the object, or sometimes on both sides).
	For example:
http://www.apnphotographyschool.com/wp-content/uploads/2010/12/358x500xni
		Jerome
mailto:jeb### [at] freefr
http://jeberger.free.fr
Jabber: jeb### [at] jabberfr
Download 'us-ascii' (1 KB)
Date: 5 Nov 2012 13:30:00
Message: <web.50980575d784280848146bbd0@news.povray.org>
"MichaelJF" <mi-### [at] t-onlinede> wrote:
> But you are still limited to 256 entries.
Actually, you're not. While it's true that any given _map is limited to 256
entries, you can nest maps to exceed that limitation. You're pretty much
averaging averaged pigments at that point :)
Date: 5 Nov 2012 14:15:01
Message: <web.50980f06d7842808f6fcbc350@news.povray.org>
> blur with tracers?
Sorry, I don't know what I mixed up, may be impressions from ads, I took for
photographies or something like Jerome presented. Tracers certainly not, because
I first had to look up the wikipedia what this could be... But is superman very
far away from them?
Yes, as ever clipka is right, as is clear, if one thinks a bit more before
posting...
Best regards,
Michael
Message: <web.50980fc1d7842808f6fcbc350@news.povray.org>
> Thomas
No need to blush;-) I only thought that my cheap trick could interest you
regarding your former profession.
Best regards,
Michael
Date: 6 Nov 2012 03:07:55
Message: <5098c55b@news.povray.org>
Oh, absolutely. In fact I have been thinking about the contour line
possibilities for a long time without getting very far. So, I see great
possibilities in your technique.
But with regard of the motion blur proper, I have been thinking about
how to use the averaging method (to replace the Megapov application)
without loosing to much (render) time. One thing your comment above made
me think of was (1) to isolate the moving object from the scene proper,
(2) animate it to get motion blur on a transparent background and
average the frames, and finally (3) average the blurred object image
with the scene image.
While more work than with Megapov, I suppose that it might work, and it
probably is the technique used originally by Megapov, but then embedded
into the code.
Date: 6 Nov 2012 14:45:01
Message: <web.50996810d78428089a22e2a60@news.povray.org>
Thanks, I just investigate if exr-pictures can achieve an improvement after
having reached a certain approximation of the landscape with png.
> into the code.
> Thomas
Sounds great, I think, this is the way to go.
Best regards,
Michael
Date: 6 Nov 2012 15:20:00
Message: <web.5099703ed78428089a22e2a60@news.povray.org>
Second thought: average the images with the transparent background and layer the
result over the original scene only. Otherwise the original scene (background)
has a chance to come into the object in motion. Ok, may be only to a small,
hardly visible amount...
Best regards,
Michael
