POV-Ray : Newsgroups : povray.binaries.images : Iso-sub-surface goo Server Time
1 Nov 2024 18:16:14 EDT (-0400)
  Iso-sub-surface goo (Message 1 to 10 of 12)
Subject: Iso-sub-surface goo
Date: 23 Sep 2012 14:12:15
Message: <505f50ff@news.povray.org>
My first subsurface test. The fact that it does not resemble
a strawberry at all only shows how easily I get sidetracked ;)
I couldn't quite get rid of the graininess even when increasing
subsurface samples to 500, and AA also didn't seem to help. In the
end I opted for 100 and used weak focal blur to smoothen it a bit.
Rendered in 25 minutes using 12 threads (and no I wasn't patient
enough to try this with radiosity enabled).
Download 'goo.jpg' (95 KB)
Preview of image 'goo.jpg'
Subject: Re: Iso-sub-surface goo
Date: 23 Sep 2012 14:20:35
Message: <505f52f3@news.povray.org>
LOL ... can relate to that! Hey but sometimes getting sidetracked
produces some interesting results ... I like it!
Not too bad ... raytracing and patience definitely belong in the same
sentence.
Date: 23 Sep 2012 14:40:36
Message: <505f57a4@news.povray.org>
> sentence.
As does frustration. ;-)
Regards
Date: 23 Sep 2012 14:47:17
Message: <505f5935@news.povray.org>
You are right it does not resemble a strawberry, for a start
strawberries are red or strawberry coloured. :-P
It does have a certain charm in a "I don't want to be in the same room
as it" way.
Is it an isosurface, blob or what?
It's worth continuing with, I think.
Regards
Date: 23 Sep 2012 14:48:31
Message: <505f597f$1@news.povray.org>
I really should read the subject. :-(
Regards
Date: 23 Sep 2012 14:51:39
Message: <505f5a3b@news.povray.org>
> sentence.
It wouldn't be so bad if I could get some work done while rendering.
But then I'm constantly peeking to the povray output, checking progress,
admiring the newest pixel block ...
Date: 23 Sep 2012 15:11:05
Message: <505f5ec9@news.povray.org>
Well I actually DO have a strawberry WIP that is red, see attachment ;)
But it's mostly an elaborate texture on a plain blob and nothing much
remains of the strawberriness when normals are removed as happended when
adding subsurface so I ended up with the other test scene. Not sure I
want to render a bowl full of isosurface strawberries, though ...
> as it" way.
Yes Iit could be called repulsive sphere over checkered plane ;)
As you found out by now, it is an isosurface (sphere - leopard).
Well let's see if I make it back to the strawberry first ;)
Download 'strawberry-verywip.jpg' (76 KB)
Preview of image 'strawberry-verywip.jpg'
Date: 23 Sep 2012 16:11:57
Message: <505f6d0d$1@news.povray.org>
I like that. :-)
Well if you have nothing else to do. :-)
>> as it" way.
I like that. :-D
Regards
Date: 23 Sep 2012 16:47:24
Message: <505f755c$1@news.povray.org>
Am 23.09.2012 20:51, schrieb Christian Froeschlin:
>> sentence.
Been there, done that! :-)
Date: 23 Sep 2012 23:51:34
Message: <505fd8c6$1@news.povray.org>
A bowl full of isosurface strawberies... It won't be THAT long to render
as only a few will be fully visible, some only partialy visible and
replacable with a simple blob, and many totaly, or almost totaly hiden
that could be totaly removed or relaced with simple primitives.
