On 23/09/2012 7:20 PM, James Holsenback wrote:
> Not too bad ... raytracing and patience definitely belong in the same
> sentence.
As does frustration. ;-)
Regards
On 23/09/2012 7:12 PM, Christian Froeschlin wrote:
> My first subsurface test. The fact that it does not resemble
> a strawberry at all only shows how easily I get sidetracked ;)
You are right it does not resemble a strawberry, for a start
strawberries are red or strawberry coloured. :-P
It does have a certain charm in a "I don't want to be in the same room
as it" way.
Is it an isosurface, blob or what?
It's worth continuing with, I think.
Regards
I really should read the subject. :-(
Regards
> sentence.
It wouldn't be so bad if I could get some work done while rendering.
But then I'm constantly peeking to the povray output, checking progress,
admiring the newest pixel block ...
Well I actually DO have a strawberry WIP that is red, see attachment ;)
But it's mostly an elaborate texture on a plain blob and nothing much
remains of the strawberriness when normals are removed as happended when
adding subsurface so I ended up with the other test scene. Not sure I
want to render a bowl full of isosurface strawberries, though ...
> as it" way.
Yes Iit could be called repulsive sphere over checkered plane ;)
As you found out by now, it is an isosurface (sphere - leopard).
Well let's see if I make it back to the strawberry first ;)
Download 'strawberry-verywip.jpg' (76 KB)
Preview of image 'strawberry-verywip.jpg'
I like that. :-)
Well if you have nothing else to do. :-)
>> as it" way.
I like that. :-D
Regards
Am 23.09.2012 20:51, schrieb Christian Froeschlin:
>> sentence.
Been there, done that! :-)
A bowl full of isosurface strawberies... It won't be THAT long to render
as only a few will be fully visible, some only partialy visible and
replacable with a simple blob, and many totaly, or almost totaly hiden
that could be totaly removed or relaced with simple primitives.
>>> sentence.
Me thinking I was alone... ;-)
>>>> sentence.
> Thomas
not hardly ... we're all a bunch of pov junkies ;-)
