POV-Ray : Newsgroups : povray.binaries.images : Another Photon Bug? Server Time
28 May 2026 00:30:51 EDT (-0400)
  Another Photon Bug? (Message 1 to 10 of 19)
Subject: Another Photon Bug?
Date: 23 Sep 2012 08:45:57
Message: <505f0485@news.povray.org>
After /still/ having problems my amethyst ring I decided to isolate just
the stone and I think I've uncovered another bug. It appears that
filtered transparency isn't working with photons.
In the first image you can see the photons when I have srgbt <0.4980,
0.2902, 0.4235,1> in the material definition, and the second image the
photons aren't showing up when I have srgbf <0.4980, 0.2902, 0.4235,1>
in the material definition: that is the ONLY difference is srgbt then srgbf
The scene file is posted in p.b.scene-files
Download 'p_test1.png' (67 KB) Download 'p_test2.png' (44 KB)
Preview of image 'p_test1.png'
Preview of image 'p_test2.png'
Subject: Re: Another Photon Bug?
Date: 23 Sep 2012 09:34:33
Message: <505f0fe9@news.povray.org>
Am 23.09.2012 14:45, schrieb James Holsenback:
That's a negative. Here's an enhanced version of your image, showing
that photons /are/ at work.
Try using solely fade interior for the color; it's more realistic anyway.
Download 'p_test2_enhanced.png' (36 KB)
Preview of image 'p_test2_enhanced.png'
Date: 23 Sep 2012 09:54:55
Message: <505f14af$1@news.povray.org>
>> srgbf
so yer sayin' srgbf <0.4980, 0.2902, 0.4235,1> as the pigment is a no-no?
Date: 23 Sep 2012 10:50:38
Message: <505f21be@news.povray.org>
>> srgbf
OK ... so been playing around with fade_color/distance/power in interior
and not even close to looking like an amethyst!
Mind posting the material definition you used?
Date: 23 Sep 2012 13:18:32
Message: <505f4468@news.povray.org>
>>> srgbf
LOL ... never mind I found a way to do it (still some tweaking left) . I
made the pigment in the material srgbf 0.85 and put some colored
emission media in the interior ... not exactly intuitive (to me anyways)
Download 'work.png' (55 KB)
Preview of image 'work.png'
Date: 23 Sep 2012 13:34:02
Message: <505f480a$1@news.povray.org>
>>> srgbf
When using fading interiors, the key is fade_distance. If you want
deeper colour, use a smaller value.
Use fade_power 1. Aletrnatively, you may want to use fade_power 1001.
For gemms, I tend to use a fade_distance value between 1/2 and 1/10 the
dimention of the gemm. Larger values are used for make the stone look
smaller.
Date: 23 Sep 2012 19:00:48
Message: <505f94a0@news.povray.org>
Am 23.09.2012 19:18, schrieb James Holsenback:
This is not a good idea. A gemstone does absorb light and not emit it.
I've found this page with some spectral data for gemstones:
http://www.octonus.com/oct/projects/adsorbtion_spectra.phtml
and used this data to play a bit around with your stone. And after
getting some strange effects I noticed that you have a coincident
surface problem within the merge.
This is exactly your gem shape but without coincident surface and it
renders even a bit faster.
#declare Gem = intersection {
   #local ndx = 0;
   #while ( ndx < 360 )
     plane {-x, 0 rotate z*-55 translate x*-2.75 rotate y*ndx }
     plane {-x, 0 rotate z*35  translate x*-2.75 rotate y*ndx }
     #local ndx = ndx + 45;
   plane {y, 0 translate y*1}
And I would use something like this for gems:
#macro M_Gem (Color, IOR, FadeDist)
   material {
       pigment {rgb Color filter 1}
       finish {
         ambient 0  emission 0  diffuse 0
         reflection {0 1 fresnel on} conserve_energy
     interior {
       ior IOR
       fade_power 1001
       fade_distance FadeDist
       fade_power rgb < pow(Color.red,3),
                        pow(Color.green,3)
                        pow(Color.blue,3) >
Note that I do usually use 1cm = 1 POV-Unit and in this case
fade_distance 1 works pretty well. You have scaled your gem much
bigger so you have to adjust fade_distance to fit your scale.
Attached is a quick lo-quality (90 seconds) preview render - not a
spectral one - featuring your stone: from left to right emerald,
sapphire and amethyst.
-Ive
Download 'gems.jpg' (87 KB)
Preview of image 'gems.jpg'
Date: 23 Sep 2012 20:24:02
Message: <505fa822$1@news.povray.org>
Yes this was a fail ... and after I thought about it for a bit I thought
the same thing.
Yes it left a visible line shadow on the ground plane ... thought merge
would have gotten rid of coincident surface ( where the two cones met
before difference ) but obviously not ... hmmm
>    #local ndx = 0;
>    #end
way more elegant ... thanks
>    material {
>      texture {
>        finish {
>      interior {
>        ior IOR
>        fade_power 1001
>                         pow(Color.green,3)
>                         pow(Color.blue,3) >
> #end
> -Ive
Wow ... thanks for the macro and all the advise. I really appreciate it!
Date: 24 Sep 2012 00:21:28
Message: <505fdfc8@news.povray.org>
Am 24.09.2012 02:24, schrieb James Holsenback:
Well, merge gets rid of *internal* surfaces but in this case, depending
on viewing angle and floating point inaccuracy, it is not clear if a ray
has left one surface and then enters the other or if the objects
actually get merged.
>>    material {
>>      texture {
>>        finish {
>>      interior {
>>        ior IOR
>>        fade_power 1001
>>                         pow(Color.green,3)
>>                         pow(Color.blue,3) >
>> #end
Err, sorry, this was out of my head and has the usual bugs. It should be
like this:
    material {
        pigment {Color filter 1}
        finish {
      interior {
        ior IOR
        fade_power 1001
        fade_color rgb < pow(Color.red,3),
                         pow(Color.green,3)
                         pow(Color.blue,3) >
Hopefully this time I've got it right ;)
And BTW the rgb (not srgb !!! because the power of 3 would give wrong
results) values I did use for the picture are
Emerald:  rgb < 0.7276, 0.9320, 0.8543>
Sapphire: rgb <-0.0044, 0.3702, 0.7609>
Amethyst: rgb < 0.8981, 0.8441, 0.8972>
and are calculated from the absorption spectral data. And yes, the red
components for the Sapphire is negative, it is an out-of-gamut value.
Glad to be of help and again, sorry for the errors in the macro.
-Ive
Date: 24 Sep 2012 05:27:32
Message: <50602784$1@news.povray.org>
Am 24.09.2012 00:59, schrieb Ive:
Looking forward to see a spectral render... you're gonna do one, right?
