POV-Ray : Newsgroups : povray.binaries.images : Yellow Magic Server Time
21 Apr 2026 23:57:46 EDT (-0400)
  Yellow Magic (Message 7 to 16 of 26)
<<< Previous 6 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Yellow Magic
Date: 29 Aug 2012 06:11:11
Message: <503deabf@news.povray.org>
Am 29.08.2012 07:42, schrieb Ive:
> But what I will try some day is using POV-Ray as spectral renderer :)
> This could be done within an animation loop of e.g. 31 steps in 10nm
> from 400nm to 700nm (I got inspired by Bruce Lindbloom who did exactly
> this with his own self-made renderer).
11 steps will do if you make use of three color channels per frame :)
Date: 29 Aug 2012 06:55:39
Message: <503df52b$1@news.povray.org>
> And what /I/ will do some day is make a spectral rendering patch for
> POV-Ray :-)
> From a mathematical point of view, the classic three-component RGB
> approach is a pretty poor one, no matter what color space you're using.
> From all the brain-wrecking I did about the topic, I suspect that a
> straightforward N-channel spectral approach is the best solution.
> But first there's some cleaning-up to do on the color handling code of
> official POV-Ray.
Assuming a ray's color is a 1D vector spectrum, please make the
pigment's color a 2D matrix. Most matrix would be resumed to a diagonal,
but using a matrix would allow to model shift on the spectrum.
Date: 29 Aug 2012 07:05:29
Message: <503df779@news.povray.org>
Am 29.08.2012 12:11, schrieb clipka:
Of course [heading my forehead with my fist] thats brilliant. With only
11 animation frames a range from lets say 380nm to 700nm can be covered.
BTW I'm aware that POV-Ray internally assumes sRGB primaries for
iridescence and color->grayscale conversion. Is there anything else
internally hard-coded that expects sRGB?
-Ive
Date: 29 Aug 2012 07:13:19
Message: <503df94f@news.povray.org>
Am 29.08.2012 12:08, schrieb clipka:
> POV-Ray :-)
Do you really think this is worth the effort? To really benefit from a
spectral render engine one needs spectral data for diffuse and specular
reflectance for A LOT of materials. But somehow I suspect not that many
POV-Ray users have a spectrophotometer at home.
> official POV-Ray.
Like what? Just curious.
-Ive
Date: 29 Aug 2012 07:16:49
Message: <503dfa21$1@news.povray.org>
Am 29.08.2012 09:13, schrieb Jaime Vives Piqueres:
> Darn... I was expecting a yellow Dogde Challenger! :)
As usual I'm just hopping from one unfinished project to the next!
My virtue of patience is not as strong as you might think ;)
And this actually reminds me of some beauty line named in your honor
that needs my attention... *
-Ive
* sorry: in-joke
Date: 29 Aug 2012 07:18:31
Message: <503dfa87@news.povray.org>
In case anyone is interested, I have made a 1920x1200 16bit/channel PNG
version and also the "raw" rendered data in linear Adobe-RGB as a TIFF
available from my side at
http://www.lilysoft.org/CGI/YMO/yellowmagic.htm
But be warned, those are big files.
-Ive
Date: 29 Aug 2012 07:34:25
Message: <503dfe41$1@news.povray.org>
Am 29.08.2012 10:08, schrieb Thomas de Groot:
> This going a bit beyond my mental capacities, but I find it fascinating
> nonetheless. ;-)
Well, I'm not good in explaining, but all this is just about that within
the sRGB color space "only" 35% of the colors an average can "see" and
distinguish are represented. Within Adobe RGB this is already about 50%
and lets say a high quality art print covers up to 90%.
In practice the 35% of sRGB are not as bad as it sounds as mainly
high-saturated colors are effected and as long as nobody opens a
New-Wave nightclub in Gancaloon it shouldn't be much of a problem ;)
-Ive
Date: 29 Aug 2012 07:42:11
Message: <503e0013$1@news.povray.org>
Am 29.08.2012 13:33, schrieb Ive:
err, make this "an average human can "see" and" ...
-Ive
Date: 29 Aug 2012 08:19:05
Message: <503e08b9@news.povray.org>
Am 29.08.2012 13:12, schrieb Ive:
>> POV-Ray :-)
I won't know until I try :-)
While that's certainly true, I guess even with rgb-specified colors it
will already do some good to scenes with colored transparent objects, so
that e.g. two orange filters in sequence won't necessarily exhibit a hue
shift towards red, but could retain the orange hue while just gaining in
saturation.
Date: 29 Aug 2012 08:26:51
Message: <503e0a8b$1@news.povray.org>
>> official POV-Ray.
Using the same color data type throughout, for instance. As it is now,
some parts of the code use old C-style structures, while others already
use C++-style objects. Obviously, a consistent use of C++-style objects
would be easier to base a spectral rendering patch on.
Another thing is the internal handling of F and T components, which I
intend to replace with a full RGB transparency model. Again, this will
simplify implementing a sane spectral rendering patch.
