Am 28.08.2012 14:55, schrieb Jaime Vives Piqueres:
> But you proved to have patience, a virtue with which I was not gifted
> at birth...
No surprise there: Patience is always an acquired skill ;-)
On 28/08/12 15:42, clipka wrote:
> To the contrary: It typically shoots fewer of them, four in the ideal
> case. The adaptive parameter isn't a boolean that turns adaptive on,
> but a numeric value governing the minimum number of rays to shoot:
> 0 -> 2x2 1 -> 3x3 2 -> 5x5 3 -> 9x9 4 -> 17x17 ... N -> (2^N +1)x(2^N
> +1)
> As for the 6x6 area light, if you use the "adaptive" keyword you'll
> automatically get a 9x9 area light instead.
It's amazing how I can get to use these things with decent results,
given that I understand so little of how they work... :(
Jaime
>> gifted at birth...
Then it should be that I was not gifted with the ability to acquire
such skill...
Jaime
Am 28.08.2012 15:49, schrieb Jaime Vives Piqueres:
>> +1)
I would make that a ":)" because hey, it indicates that POV-Ray area
lights are pretty easy to use for good result ;-)
Jaime Vives Piqueres <jai### [at] ignorancia org> wrote:
> On 28/08/12 08:56, Thomas de Groot wrote:
> > Very good indeed! Now even better would be to show the wear of the
> > keys and a yellowish ivory tint on the white ones: i. e. an old
> > piano; this one looks too new and too plastic ;-)
> Yeah... but I was taking as reference my Korg Wavestation EX, which is
> still almost new... :)
> Jaime
Alain was quiet right, as ever. For a piano an organ is a bad reference due to
the plastic keys. But I think the differences between a Korg Wavestation and a
Technics SX-GN6 are smaller. But yes, the black keys shows a very smaller SSLT
than the white ones and one really should consider the efforts before modelling
it. And - as I took another road the way back home today, which leads to our
local piano dealer - the black keys on real pianos showed only a very slight
SSLT even. Fortunatelly the shop was closed and I had to look through the
display windows and not to explain a salesman why I only would like to look at
the black keys of his pianos ;-)
Best regards,
Michael
> On 28/08/12 02:37, Alain wrote:
>> A 6x6 area light? Why not a 9x9 or even 17x17 or 33x33 using
>> adaptive 0? In this case, adaptive 0 don't realy risk to cause any
>> visible artefacts, and willbe much faster while giving you smoother
>> penumbras.
> I've used always "jitter adaptive 1" for years... wouldn't "adaptive
> 0" shot more rays, thus being slower?
adaptive 0 start with only 4 samples, taken at the corners, while
adaptive 1 start with 9, in a 3x3 array, taken at the corners and at the
mid point between them.
6x6 don't subdivide effeciently. 5x5, 9x9, 17x17, 33x33, 65x65,... all
subdivide with the maximum effeciency.
>> For Michael, your organ probably have plastic keys. For most classic
>> pianos, the white keys are ivory and the black ones are maogany or
>> black dyed hard wood if it's a cheap one. Whites have SSLT, blacks
>> don't have any, or so little that it can be ignored.
> I just tested, and SSLT with an almost black pigment doesn't get much
> noticeable, almost no difference at all. I guess the light would have to
> be very close to the object to have an appreciable effect.
> Jaime
High!
On 27.08.2012 21:07, MichaelJF wrote:
>I just took a look at my long
> abandoned organ and they seem to have the same SSLT as the white but only
> another colour.
What organ is it? A Hammond?
See you in Khyberspace!
Yadgar
Now playing: Naked Eye (Simple Minds)
High!
Yes, most electronic organs do... but vintage Hammonds from the 1930s to
1960s (at least the B3 model) usually have wooden keys!
Yadgar
Now playing: Citizen (Dance Of Youth) (Simple Minds)
High!
> reference due to the plastic keys. But I think the differences
> between a Korg Wavestation and a Technics SX-GN6 are smaller.
Cool, another Technics player here around! I own an SX-G5, semi-digital
from 1984 (although an SX-U90 or SX-G7 would have been my first
choice... but, beggars can't be choosers, I got it for free!).
Yadgar
Now playing: Factory (Simple Minds)
