|  |  | Hi(gh)!
I started designing an isosurface planet for my "Port Whatmough" city
project... the land-sea ratio is quite what I aimed at, also the
planet-wide elevation range (deepest point of the ocean ~-7500 m,
highest mountain on land ~7200 m), but I wanted broader low plains
(green in the cylindrical map generated from the isosurface) and
mountain areas (orange to brown) mostly as ranges rather than massive
plateaus.
Is it a matter of careful mixing pigment functions, e. g. using average?
Which additional functions would you recommend?
Here is the isosurface code:
#declare S =                        // basic spherical shape
function { x*x + y*y + z*z -1 }
#declare Terrain_Part1_Function=
function
   pattern
     crackle form <0, 0.3, 0>
     scale 10
     translate <2, 0, 0>
     turbulence 0.5
     octaves 8
     omega 0.6
     lambda 2.07
     poly_wave 0.53
#declare Terrain_Function=
function { S(x, y, z) + Terrain_Part1_Function (x*5,y*5,z*5)*0.02  }
#declare Whatmough=
isosurface
   function { Terrain_Function(x, y, z) }
   contained_by
       sphere { 0, 2 }
   max_gradient 10
   // accuracy pow(10, -clock/25)
   double_illuminate
   texture { T_Whatmough }
   scale 5794
The ocean is an additional sphere with a radius of 5773.1.
See you in Khyberspace!
Yadgar
Now playing: The Hurt (Cat Stevens)
 Download '2012-07-04 whatmough, take 11.jpg' (20 KB)
Download '2012-07-04 whatmough, take 12.jpg' (17 KB)
Download '2012-07-07 whatmough, simple cylindrical map, no legend, take 1.png' (38 KB)
 Preview of image '2012-07-04 whatmough, take 11.jpg'
  Preview of image '2012-07-04 whatmough, take 12.jpg'
  Preview of image '2012-07-07 whatmough, simple cylindrical map, no legend, take 1.png'
|  |  | There are at least two functions which are useful for building mountain
ranges: f_hetero_mf() and especially f_ridged_mf(). You can /add/ those
to your Terrain_Function.
> Hi(gh)!
> plateaus.
