Subject: Re: Early Earth: The Late Heavy Bombardment [latest image]
Date: 6 Jul 2012 08:02:25
Message: <4ff6d3d1@news.povray.org>
Maybe physically not entirely correct, but visually certainly attractive :-)
Download 'earlyearth - lhb_04.png' (781 KB)
Preview of image 'earlyearth - lhb_04.png'
Date: 6 Jul 2012 10:09:26
Message: <4ff6f196$1@news.povray.org>
> Thomas
Wow, the explosion begins to become /great/!
Paolo
Date: 6 Jul 2012 10:31:47
Message: <4ff6f6d3$1@news.povray.org>
Thanks Paolo! I am rather happy with this so far. Again, it does not
need to be scientifically correct all the way but to suggest the impact.
A few more things to do.
Date: 6 Jul 2012 17:42:45
Message: <4ff75bd5$1@news.povray.org>
Hi(gh)!
If the impact is several hundred kilometres afar, its blast should not
obscure the high wispy clouds...
See you in Khyberspace!
Yadgar
Date: 6 Jul 2012 21:55:23
Message: <4ff7970b$1@news.povray.org>
> Thomas
Now you'r talking. Mostly incandecent ejectae. Not unrealistic if you
think a secong about just how much heat is released by that impact...
Then, there is all that heating from the huge supersonic shock wave.
Date: 6 Jul 2012 21:58:47
Message: <4ff797d7$1@news.povray.org>
Le 7/6/2012 5:42 PM, Jörg 'Yadgar' Bleimann a écrit :
> Hi(gh)!
> Yadgar
I agree. The top of the projection is probably climbing well abode those
clouds anyway, right up to the top of the statosphere, with some debrits
escaping back to outer space.
With the light output of those meteors, shouldn't they be creating diffraction
artifacts in your time machine's camera similar to those of the stars?
I have been hesitating about that. The answer should be yes, shouldn't
it? I shall add small ones...
Subject: Re: Early Earth: The Late Heavy Bombardment [final image]
Date: 9 Jul 2012 08:03:53
Message: <4ffac8a9@news.povray.org>
This should be the final development of the scene.
Download 'earlyearth - lhb_05.png' (835 KB)
Preview of image 'earlyearth - lhb_05.png'
Date: 10 Jul 2012 04:06:08
Message: <4ffbe270$1@news.povray.org>
> Thomas
Ooh.
The explosion is less terrifying (due to the daylight), but the sea and
the fog are very convincing.
Paolo
Date: 10 Jul 2012 07:32:34
Message: <4ffc12d2$1@news.povray.org>
>> Thomas
> Ooh.
Thanks Paolo. I am still terrified though ;-)
I am adding a spherical shock wave to complete the impact.
For the fog over the water I used a df3 file made with Gilles Tran's
MakeCloud.
Date: 11 Jul 2012 07:32:20
Message: <4ffd6444@news.povray.org>
This is really the final image. Added a spherical shock wave.
Download 'earlyearth - lhb_final.png' (835 KB)
Preview of image 'earlyearth - lhb_final.png'
Date: 11 Jul 2012 16:30:51
Message: <4ffde27b$1@news.povray.org>
> Thomas
I have some problem with that shock wave: It don't difract light.
A shell with an ior of about 1.1 to 1.17 would be more convincing.
Date: 12 Jul 2012 04:43:33
Message: <4ffe8e35@news.povray.org>
This gets me into problems :-(
For the example I switched off the solid ejecta. I also tuned down the
fog over the water.
For the shock wave I used an ior of 1.01. Obviously, now its media
interacts with the other media inside, especially the dust ejecta
container. Higher ior makes it worse.
Download 'earlyearth - lhb.png' (159 KB)
Preview of image 'earlyearth - lhb.png'
Date: 12 Jul 2012 18:49:11
Message: <4fff5467$1@news.povray.org>
> fog over the water.
> Thomas
It looks like a solid, full, shell. Make the shock wave shell as a
difference of 2 spheres.
To bad we can't have variable ior, as in this case, it should go from 1
(in the air in front of the wave), raise in an S shape to maybe around
1.1, then drop slightly under 1 before returning to 1.
You may also try playing giving the area inside the sinside an ior
slightly less than 1, like 0.98 to 0.995...
Date: 13 Jul 2012 03:45:12
Message: <4fffd208$1@news.povray.org>
I did too but that was not better, rather worse.
Yes, that would be cool.
Yes, I tried too. It corrected somewhat the inner media but did not
change the chock wave appearance.
I shall still make a couple of experiments.
Date: 13 Jul 2012 10:56:22
Message: <50003716@news.povray.org>
The best I can get at this stage (no good) using a differenced sphere
for the shock wave. Diffractions looks ok at the border but I cannot get
the transparency of the sphere right. The cloud layer is also
differenced (a tiny bit larger sphere) to ensure that no clouds are
present inside the shock wave.
Code snippet:
difference {
sphere {0, 1
hollow
texture {pigment {rgbt <1,1,1,1>} }
interior {
ior 1.1
media {
intervals 1
samples 10, 1000
scattering {1, 0.000025
extinction 1
sphere {0, 0.98
hollow
interior {
ior 1.0
scale MediaScale * 1.52
translate <CamLoc.x, CamLoc.y, 5000> + <2800, 0, 0>
Download 'earlyearth - lhb.png' (114 KB)
Subject: Re: Early Earth: The Late Heavy Bombardment [experimental image #2]
Date: 14 Jul 2012 04:01:22
Message: <50012752@news.povray.org>
Trying to get at the problem. I here switched off the sphere
representing the sky and the atmospheric media. Also corrected the shock
wave container as follows:
//start code
difference {
sphere {0, 1.00 hollow}
sphere {0, 0.98 hollow}
material {
interior {
ior 1.1 //shock waved air
media {
intervals 1
samples 10, 1000
scattering {1, 0.0001
extinction 1
//end code
While one can see /inside/ the shock wave, it is not possible to see the
stars through the opposite end of the sphere... why?
Download 'earlyearth - lhb.png' (145 KB)
Subject: Re: Early Earth: The Late Heavy Bombardment [experimental image #3]
Date: 14 Jul 2012 08:13:06
Message: <50016252@news.povray.org>
OK. Got the transparency solved. Just a stupid max_trace_level issue :-(
Next problem is to get rid of this sphere edge seen in cross section...
Download 'earlyearth - lhb_.png' (144 KB)
Preview of image 'earlyearth - lhb_.png'
Date: 14 Jul 2012 08:47:06
Message: <50016a4a$1@news.povray.org>
Am 14.07.2012 10:01, schrieb Thomas de Groot:
max_trace_level maybe?
Date: 14 Jul 2012 08:51:21
Message: <50016b49$1@news.povray.org>
Am 14.07.2012 14:12, schrieb Thomas de Groot:
... and here your real problems begin. You'll need to somehow mimic an
ior gradient.
Date: 14 Jul 2012 20:03:20
Message: <500208c8$1@news.povray.org>
> ior gradient.
Ugly cludge that can simulate an ior gradient:
Use many shells of decreasing thickness each varying in ior by a small
amount in the order of 0.002 or less.
The outer shell have an ior in the order of 1.001 or maybe even less,
then each other have a slightly larger ior.
Each thinner shells must reside inside any previous ones. No merge as
you need all those internal surfaces.
Big increase in rendering time and needs a large max_trace_level.
Date: 15 Jul 2012 03:11:19
Message: <50026d17$1@news.povray.org>
I need to learn to count beyond five fingers... :-)
Date: 15 Jul 2012 03:15:12
Message: <50026e00$1@news.povray.org>
>> ior gradient.
Hmm, yes, that might work. I leave that experiment for later though, as
I want to get on with my raytracing life ;-)
Would this be something for POV-Ray 4.0?
Date: 15 Jul 2012 10:30:36
Message: <5002d40c@news.povray.org>
Am 15.07.2012 09:15, schrieb Thomas de Groot:
>>> ior gradient.
I'm not sure whether a dedicated feature would be able to significantly
reduce that render time.
Date: 15 Jul 2012 18:58:12
Message: <50034b04$1@news.povray.org>
>>>>> section...
>>>> ior gradient.
It would require sampling along the ray path, determine the direction of
the ior gradient as well as it's value and deflect the ray accordingly.
In fact, you'll need to construct a spline that will describe the path
of each tracing ray through the object.
I don't think that it's unfeasible, but will be very computationaly
intencive and thus slow as hell. If the ior can be assumed to only
change relatively slowly, some interpolation and extrapolation may be
possible between rays that may help speeding thing. You'll need to use a
max_gradient just like in an isosurface.
With my cludge, you have the local normal and the ior is quantified into
discreete steps. It can be applyed to an isosurface by changing the
thressold. If applyed to a CSG object, the smaller versions need to have
individual components scalled separately from the whole object. Some
complexe primitives, like a julia_fractal or a some mesh, don't realy
support the needed scalling without self intersecting. A torus need to
have it's minor axis altered, but not it's major axis.
Heavy, potentialy memory hungry, SLOW, error prone, but should work.
With a sampling along the ray, you don't have any normal available to
help you and the ior may change in rather strange ways...
