POV-Ray : Newsgroups : povray.binaries.images : Image_map with alpha channel: strange effect Server Time
22 Dec 2025 12:44:47 EST (-0500)
  Image_map with alpha channel: strange effect (Message 1 to 5 of 5)
Subject: Image_map with alpha channel: strange effect
Date: 13 May 2012 11:51:23
Message: <4fafd87b@news.povray.org>
Hi(gh)!
As I mentioned in my posting before, with my Earth model I now use a
separate sphere for the cloud-only texture. The original cloud-only
testure bitmap was black to white; to get the cloud-free portions
transparent, I used the GIMP's Layer/Transparency/Colour to Transparency
feature.
But obviously, the eastern hemisphere of that bitmap seems to be
somewhat lighter than the western one; however, when I render a view of
the North Pole (see below), the clouds-only texture covering the eastern
hemisphere is not entirely transparent even in its cloud-free parts.
And, very strangely, this effect does not disappear when I darken the
eastern portion of the original map!
Here is the code:
union
   sphere // Earth, surface
     0, 1
     texture
       pigment
         image_map
           png "solarsys/ev5826_land_ocean_ice_lights_8192.png"
           map_type 1
           interpolate 2
       finish
	ambient 1
	diffuse 0
     texture
       pigment
         image_map
           png "solarsys/ev11612_land_ocean_ice_8192_POV.png"
           map_type 1
           interpolate 2
       finish { F_Standard_Planetary_Surface }
   sphere // Earth, clouds
     0, 1.000783928 // clouds 5 kms above surface
     texture
       pigment
	image_map
	  png "solarsys/cloud_combined_8192a_alpha.png"
	  map_type 1
	  interpolate 2
   rotate -y*clock
   SetAxis(bodies[3][10], bodies[3][11])
   scale <bodies[3][1], bodies[3][2], bodies[3][3]>/sc
   translate Pos_Earth/sc
What went wrong?
See you in Khyberspace!
Yadgar
Download '2012-05-13 earth, take 46 - north pole from 12,000 kms.png' (594 KB)
Preview of image '2012-05-13 earth, take 46 - north pole from 12,000 kms.png'
Subject: Re: Image_map with alpha channel: strange effect
Date: 13 May 2012 21:30:25
Message: <4fb06031$1@news.povray.org>
The first thing I'd do is to find the offending layer. Do you
really need all three? Does each texture individually look fine?
What about the cloud layer over a simple one-pigment sphere?
 > radius 1.000783928
This may be fishing for floating point inaccuracies if you
have astronomical numbers in the bodies array. Did you try
with two simple spheres of radius 1 and 1.1?
Date: 14 May 2012 05:16:57
Message: <4fb0cd89@news.povray.org>
Hi(gh)!
Yes, that's it... I scaled both spheres separately and set the global
scaling factor to 1000 (rather than 13347 before), and the effect
disappeared (see below)!
Yadgar
Download '2012-05-14 earth, take 47 - north pole from 12,000 kms.png' (629 KB)
Preview of image '2012-05-14 earth, take 47 - north pole from 12,000 kms.png'
Date: 17 May 2012 01:00:17
Message: <4fb485e1@news.povray.org>
> Hi(gh)!
> feature.
> Here is the code:
> union
> 0, 1
> texture
> pigment
> image_map
> map_type 1
> interpolate 2
> finish
> ambient 1
> diffuse 0
> texture
> pigment
> image_map
> map_type 1
> interpolate 2
> texture
> pigment
> image_map
> map_type 1
> interpolate 2
> rotate -y*clock
> What went wrong?
> Yadgar
Hi, that looks really good, where did you get the high res image maps from??
Cheers Dre
Date: 17 May 2012 03:36:27
Message: <4fb4aa7b@news.povray.org>
Am 17.05.2012 07:00, schrieb Dre:
> from??
NASA has stuff like that; search for "blue marble".
