POV-Ray : Newsgroups : povray.binaries.images : Transition between two medias Server Time
8 Nov 2024 14:28:36 EST (-0500)
  Transition between two medias (Message 1 to 10 of 22)
Subject: Transition between two medias
Date: 24 Apr 2012 03:25:47
Message: <4f96557b@news.povray.org>
I am struggling with the following. Muddy water flowing out of an
estuary towards sea, eventually sinks down/mixes with sea water some
distance from the coast. The easy approach is shown in the image below:
two boxes, sliced by a plane, and filled with two different media each
(one absorption, one scattering).
I would prefer a more diffuse approach using a spherical pattern for
instance, but I am unable to come up with a working code that can do
that properly.
Any idea? Thanks!
Download 'mediatest2.png' (116 KB)
Preview of image 'mediatest2.png'
Subject: Re: Transition between two medias
Date: 24 Apr 2012 05:16:00
Message: <4f966f50$1@news.povray.org>
> that properly.
> Any idea? Thanks!
two words: Offset printing.
(in 3D)
It might be costly. Macro is a must have.
In details, use union/merge of spheres with fixed coordinates but
variables radius.
In the estuary, radius are such that spheres fills the whole space.
In the least yet perturbed sea, the radius become very small.
For sphere placements, use ABC or ABA compact spheres filling of space
(12 spheres around 1: 6 in same plane, 3 above, 3 below), rather than
cartesian grid. Tilt the placements by some rotations.
relative radius of spheres should be computed from the x,y position of
the center (you might also consider z if you like), relative your
gradient/pattern of diffusion between 100% estuary and the 100% sea.
To sum up:
 1. create that object A (limit the spheres to the mixing zone).
 2. create an object B, container of the mix.
 3. B is filled with sea media
 4. intersection of B & A is filled with estuary media.
 5. part before B in estuary is filled with estuary media
 6. part after B in sea is filled with sea media
(there might be a surface between 5/6 and B, so might be A and B must be
extended to one fill further in their direction)
(B is the whole flow, A is a squatter)
alternative with possible coincident surface issue:
difference { B A material{ Sea } }
intersection { B A material { Estuary } }
Tuning with the radius between the spheres coordinates.
Real software engineers work from 9 to 5, because that is
the way the job is described in the formal spec.  Working
late would feel like using an undocumented external procedure.
Date: 24 Apr 2012 06:58:43
Message: <4f968763@news.povray.org>
> that properly.
are you looking for something like this:
#declare f_gradient_x_non_repeating = function
   select(x,0,select(x-1,x-1,1))
   // of course you can also construct something using
   // f_spherical here depending on desired geometry
box
   <-2,-1,0>,<2,1,1> hollow
   pigment  {color rgbt 1}
   interior
     media
       method 3
       absorption 10
       density
         function {f_gradient_x_non_repeating(x,y,z)}
         translate -0.5*x
         scale 2*x
         rotate 45*z
         color_map
           [0.0 color Navy]
           [1.0 color Khaki]
Date: 24 Apr 2012 07:01:05
Message: <4f9687f1$1@news.povray.org>
Christian Froeschlin wrote:
note you will need to media statements, one to increase
the scattering and another to decrease the absorption.
Date: 24 Apr 2012 07:06:11
Message: <4f968923$1@news.povray.org>
and that was actually supposed to be
select(x,0,select(x-1,x,1))
Date: 24 Apr 2012 08:06:06
Message: <4f96972e@news.povray.org>
> box
> interior
> media
> method 3
> absorption 10
> density
> translate -0.5*x
> scale 2*x
> rotate 45*z
> color_map
> [0.0 color Navy]
> [1.0 color Khaki]
Thank you both, Le_Forgeron and Christian. I feel Le_Forgeron's solution
to be rather complicated and I do not yet understand everything yet,
although it might be the best approach in the end.
Christians solution is elegant and promises to be my favourite choice.
Using my own water colours, and tweaking the code in the following way:
#declare Sea_col = srgb <0.51373, 0.70588, 0.70588>;   //clear water
#declare Mud_col = srgb <0.74118, 0.71765, 0.41961>+<0.2, 0.2, 0>;
//muddy water
#declare Dist    = 200;  //determines the depth transparency of the
water column
#local FD = -(Dist/(6*25.4))/ln(0.58);	//fade distance
#declare f_gradient_x_non_repeating = function {select(x,0,select(x-1,x,1))}
box {
   <-3,-1,-1>, <3,1,1>
   hollow
   finish {
     conserve_energy
     diffuse 0.2
     ambient 0
     reflection {0.01, 0.2 fresnel on metallic 0}
   normal {crackle 0.15 scale <0.45,0.25,0.25>*2 turbulence 0.5 }
   interior {
     ior 1.33
     media {
       method 3
       absorption 5
       density {rgb 1/FD}
       //next commented out to follow original fading on line above
       /*density {
         translate 0.25*x
         scale 2*x
         rotate 70*z
         color_map {
           [0.0 color Sea_col]
           [1.0 color Mud_col]
     media {
       method 3
       scattering {3, Sea_col}
       density {
         translate 0.25*x
         scale 1*x
         rotate 60*z
         color_map {
           [0.0 color Mud_col]
           [1.0 color Sea_col]
This is going in the right direction! I have see how to tweak the
colours to obtain approximately my original water aspect.
Download 'mediatest2.png' (33 KB)
Date: 24 Apr 2012 08:15:23
Message: <4f96995b@news.povray.org>
Nice! Adding also some turbulence.
Download 'mediatest2.png' (34 KB)
Subject: Re: Transition between two medias: Final result
Date: 25 Apr 2012 04:22:30
Message: <4f97b446@news.povray.org>
And this is the final result, as seen from a tower on the island
offshore from Gancaloon.
Thanks Christian!
Download 'gancaloon.png' (607 KB)
Preview of image 'gancaloon.png'
Date: 25 Apr 2012 04:38:44
Message: <4f97b814@news.povray.org>
... and a view from the other side.
Download 'gancaloon.png' (993 KB)
Date: 25 Apr 2012 05:11:10
Message: <4f97bfae$1@news.povray.org>
On 25/04/2012 9:38 AM, Thomas de Groot wrote:
> .... and a view from the other side.
> Thomas
> Thomas
> Thomas
Is that the right image? The lower 3/5 is blank.
Regards
