POV-Ray : Newsgroups : povray.binaries.images : Transition between two medias Server Time
28 May 2026 05:54:11 EDT (-0400)
  Transition between two medias (Message 21 to 22 of 22)
Subject: Re: Transition between two medias: Final result
Date: 26 Apr 2012 22:45:00
Message: <web.4f9a06f02aad6c825ae2687f0@news.povray.org>
> Drainage and water supply are still a big problem...
> Thomas
Well, what about these?
http://www.sakia.org/cms/index.php
http://en.wikipedia.org/wiki/Chain_pump
Both were used in regions similar to yours,
and can be wind or animal powered. :)
> Thanks!  Here is a larger version
> Thomas
Looks great, a very calm day obviously. ;)
The sea is so still...
The river/sea boundary is fairly convincing; but if I may criticise... :)
IMO the river water is a bit _too_ muddy. Maybe use less red, and a lighter
blue?
Also, you'd expect to see some sort of channel around the middle of the river;
the cliffs either side imply that the river is reasonably deep.
There is also a pool on the island the viewer is on. It looks very blue, but
surely couldn't be any deeper than a few feet?
Ok, I've finished nit-picking. ;)
I really like it, it's great. :D
D103
Date: 27 Apr 2012 02:59:26
Message: <4f9a43ce$1@news.povray.org>
On 27-4-2012 4:40, D103 wrote:
>> Thomas
Oh yes, I agree. The "big problem" for the city is that nothing has yet
been constructed ;-) The citizen are starting to riot...
Depending on need for particular scenes, these constructs may come into
existence some day. I do not expect to finish building the city within
my life time but all kind of little things will be added slowly over the
years.
Very calm. More movement and surf zones should be worked on in the
future, at least for suggesting the thing.
If I were to model a realistic sea surface I probably would use an
isosurface but that would slow down my overall render time and that is
not what I need presently.
Of course! All comments are always welcome :-)
> blue?
That is a matter of debate (also with myself). The truth of course is
that this river is an impossibility in the present geographical setting:
in a microtidal environment like the Mediterranean it should build a
delta (Ebro, Rhone, Nile) instead of just flowing out of an estuary.
This means it looses its silt load somewhere else. I have ideas about
that of course... ;-) Fortunately artistic liberty is allowed...
About your comment: it could be less muddy, but lets say that in certain
times of the year there are stronger loads than in others, for instance
after the rainy season.
Not necessarily. The river *is* the channel, without much flats an the
sides.
The sea water is probably too blue.
Uff... [wipes sweat from brow]
Good comments!
Thanks indeed!
