POV-Ray : Newsgroups : povray.binaries.images : Transition between two medias Server Time
28 May 2026 05:54:05 EDT (-0400)
  Transition between two medias (Message 3 to 12 of 22)
<<< Previous 2 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Transition between two medias
Date: 24 Apr 2012 06:58:43
Message: <4f968763@news.povray.org>
Thomas de Groot wrote:
> I would prefer a more diffuse approach using a spherical pattern for
> instance, but I am unable to come up with a working code that can do
> that properly.
are you looking for something like this:
#declare f_gradient_x_non_repeating = function
   select(x,0,select(x-1,x-1,1))
   // of course you can also construct something using
   // f_spherical here depending on desired geometry
box
   <-2,-1,0>,<2,1,1> hollow
   pigment  {color rgbt 1}
   interior
     media
       method 3
       absorption 10
       density
         function {f_gradient_x_non_repeating(x,y,z)}
         translate -0.5*x
         scale 2*x
         rotate 45*z
         color_map
           [0.0 color Navy]
           [1.0 color Khaki]
Date: 24 Apr 2012 07:01:05
Message: <4f9687f1$1@news.povray.org>
Christian Froeschlin wrote:
note you will need to media statements, one to increase
the scattering and another to decrease the absorption.
Date: 24 Apr 2012 07:06:11
Message: <4f968923$1@news.povray.org>
and that was actually supposed to be
select(x,0,select(x-1,x,1))
Date: 24 Apr 2012 08:06:06
Message: <4f96972e@news.povray.org>
> box
> interior
> media
> method 3
> absorption 10
> density
> translate -0.5*x
> scale 2*x
> rotate 45*z
> color_map
> [0.0 color Navy]
> [1.0 color Khaki]
Thank you both, Le_Forgeron and Christian. I feel Le_Forgeron's solution
to be rather complicated and I do not yet understand everything yet,
although it might be the best approach in the end.
Christians solution is elegant and promises to be my favourite choice.
Using my own water colours, and tweaking the code in the following way:
#declare Sea_col = srgb <0.51373, 0.70588, 0.70588>;   //clear water
#declare Mud_col = srgb <0.74118, 0.71765, 0.41961>+<0.2, 0.2, 0>;
//muddy water
#declare Dist    = 200;  //determines the depth transparency of the
water column
#local FD = -(Dist/(6*25.4))/ln(0.58);	//fade distance
#declare f_gradient_x_non_repeating = function {select(x,0,select(x-1,x,1))}
box {
   <-3,-1,-1>, <3,1,1>
   hollow
   finish {
     conserve_energy
     diffuse 0.2
     ambient 0
     reflection {0.01, 0.2 fresnel on metallic 0}
   normal {crackle 0.15 scale <0.45,0.25,0.25>*2 turbulence 0.5 }
   interior {
     ior 1.33
     media {
       method 3
       absorption 5
       density {rgb 1/FD}
       //next commented out to follow original fading on line above
       /*density {
         translate 0.25*x
         scale 2*x
         rotate 70*z
         color_map {
           [0.0 color Sea_col]
           [1.0 color Mud_col]
     media {
       method 3
       scattering {3, Sea_col}
       density {
         translate 0.25*x
         scale 1*x
         rotate 60*z
         color_map {
           [0.0 color Mud_col]
           [1.0 color Sea_col]
This is going in the right direction! I have see how to tweak the
colours to obtain approximately my original water aspect.
Download 'mediatest2.png' (33 KB)
Preview of image 'mediatest2.png'
Date: 24 Apr 2012 08:15:23
Message: <4f96995b@news.povray.org>
Nice! Adding also some turbulence.
Download 'mediatest2.png' (34 KB)
Subject: Re: Transition between two medias: Final result
Date: 25 Apr 2012 04:22:30
Message: <4f97b446@news.povray.org>
And this is the final result, as seen from a tower on the island
offshore from Gancaloon.
Thanks Christian!
Download 'gancaloon.png' (607 KB)
Preview of image 'gancaloon.png'
Date: 25 Apr 2012 04:38:44
Message: <4f97b814@news.povray.org>
... and a view from the other side.
Download 'gancaloon.png' (993 KB)
Date: 25 Apr 2012 05:11:10
Message: <4f97bfae$1@news.povray.org>
On 25/04/2012 9:38 AM, Thomas de Groot wrote:
> .... and a view from the other side.
> Thomas
> Thomas
> Thomas
Is that the right image? The lower 3/5 is blank.
Regards
Date: 25 Apr 2012 06:57:43
Message: <4f97d8a7$1@news.povray.org>
>> Thomas
>> Thomas
>> Thomas
No problem from my side. 1200x675 being the image ratio.
Date: 25 Apr 2012 07:14:47
Message: <4f97dca7@news.povray.org>
> Thomas
It is Thunderbird again.
It gives me three images now, two of them partial the third is a full image.
I like this view it shows the silt to advantage.
The paths remind me of Rune's Grass Tex.
And when are we going to get a view of the white palace or temple?
Regards
