POV-Ray : Newsgroups : povray.binaries.images : Transition between two medias Server Time
28 May 2026 04:29:12 EDT (-0400)
  Transition between two medias (Message 13 to 22 of 22)
Subject: Re: Transition between two medias: Final result
Date: 25 Apr 2012 10:35:59
Message: <4f980bcf@news.povray.org>
On 25-4-2012 13:14, Stephen wrote:
> It is Thunderbird again.
> It gives me three images now, two of them partial the third is a full
> image.
I was afraid so. Strange behaviour...
> I like this view it shows the silt to advantage.
Yes, I am rather satisfied with the silt. I shall probably tweak it a
bit more in the future, but for now it shows correctly enough for me.
> The paths remind me of Rune's Grass Tex.
Yes indeed. However it is just textures ;-)
> And when are we going to get a view of the white palace or temple?
You order; we serve.
Here is a view of the Temple Complex with the citadel in the back. I
have started working on the Temple textures. Extremely preliminary as
yet. Also the first stages of the sea harbour to the right where the
former temple of Poseidon challenges the sea.
Note the crude aspect of the "faked"urbanism in close up ;-)
Download 'gancaloon.png' (1144 KB)
Preview of image 'gancaloon.png'
Date: 25 Apr 2012 18:27:17
Message: <4f987a45$1@news.povray.org>
Nice image, although the edge between mud and water
looks rather sharp to me considering all the trouble you
went through to make a smooth media transition ;)
Date: 26 Apr 2012 02:40:07
Message: <4f98edc7$1@news.povray.org>
Correct! I have to look at this closer, but I think it is a matter or
scaling the transition. I have to charter a boat at sea first.
Date: 26 Apr 2012 03:23:29
Message: <4f98f7f1@news.povray.org>
I think this looks more acceptable. I scaled substantially along the
x-axis given the size of the water sphere in the first place.
Download 'gancaloon.png' (284 KB)
Date: 26 Apr 2012 05:55:00
Message: <web.4f991b322aad6c825ae2687f0@news.povray.org>
> Thomas
Looks awesome. :D
Can you do a high res?
Regards
D103
Date: 26 Apr 2012 06:41:52
Message: <4f992670$1@news.povray.org>
I like it but the style is so different from everything else. Those
front towers could be from the Far East. The citadel is almost European.
Understandable. I suppose the trick is to balance resources against what
detail is required. To model a whole city in detail would require more
than a typical home computer.
systems.
Regards
Date: 26 Apr 2012 08:10:40
Message: <4f993b40$1@news.povray.org>
The city being a kind of multicultural hub, architectural and cultural
influences come from different parts of the world. The Temple complex is
typically Indian (Nagara-style sakhara) to something more mixed
Indian/Chinese in front. To the right, the Poseidon temple is typically
Greek; the citadel in the back is based on a Mycenaean ground
plan/elevation (Tiryns) and the old palace will have Cretan elements. It
seems a bit extreme perhaps, but it shows the city as I dream it... ;-)
> systems.
I am working on some alternatives. Maybe as some intermediate technique...
Drainage and water supply are still a big problem...
Date: 26 Apr 2012 08:23:28
Message: <4f993e40@news.povray.org>
On 26-4-2012 11:53, D103 wrote:
> Looks awesome. :D
Thanks!  Here is a larger version
Download 'gancaloon.jpg' (118 KB)
Preview of image 'gancaloon.jpg'
Date: 26 Apr 2012 22:45:00
Message: <web.4f9a06f02aad6c825ae2687f0@news.povray.org>
> Thomas
Well, what about these?
http://www.sakia.org/cms/index.php
http://en.wikipedia.org/wiki/Chain_pump
Both were used in regions similar to yours,
and can be wind or animal powered. :)
> Thomas
Looks great, a very calm day obviously. ;)
The sea is so still...
The river/sea boundary is fairly convincing; but if I may criticise... :)
IMO the river water is a bit _too_ muddy. Maybe use less red, and a lighter
blue?
Also, you'd expect to see some sort of channel around the middle of the river;
the cliffs either side imply that the river is reasonably deep.
There is also a pool on the island the viewer is on. It looks very blue, but
surely couldn't be any deeper than a few feet?
Ok, I've finished nit-picking. ;)
I really like it, it's great. :D
D103
Date: 27 Apr 2012 02:59:26
Message: <4f9a43ce$1@news.povray.org>
On 27-4-2012 4:40, D103 wrote:
>> Thomas
Oh yes, I agree. The "big problem" for the city is that nothing has yet
been constructed ;-) The citizen are starting to riot...
Depending on need for particular scenes, these constructs may come into
existence some day. I do not expect to finish building the city within
my life time but all kind of little things will be added slowly over the
years.
Very calm. More movement and surf zones should be worked on in the
future, at least for suggesting the thing.
If I were to model a realistic sea surface I probably would use an
isosurface but that would slow down my overall render time and that is
not what I need presently.
Of course! All comments are always welcome :-)
> blue?
That is a matter of debate (also with myself). The truth of course is
that this river is an impossibility in the present geographical setting:
in a microtidal environment like the Mediterranean it should build a
delta (Ebro, Rhone, Nile) instead of just flowing out of an estuary.
This means it looses its silt load somewhere else. I have ideas about
that of course... ;-) Fortunately artistic liberty is allowed...
About your comment: it could be less muddy, but lets say that in certain
times of the year there are stronger loads than in others, for instance
after the rainy season.
Not necessarily. The river *is* the channel, without much flats an the
sides.
The sea water is probably too blue.
Uff... [wipes sweat from brow]
Good comments!
Thanks indeed!
