POV-Ray : Newsgroups : povray.binaries.images : Domenator II, the sequel Server Time
28 May 2026 04:29:12 EDT (-0400)
  Domenator II, the sequel (Message 11 to 19 of 19)
Subject: Re: Domenator II, the sequel
Date: 27 Apr 2012 04:28:07
Message: <4f9a5897$1@news.povray.org>
On 23-4-2012 17:53, Philippe Gibone wrote:
> Hi Thomas,
> Very good news.
Sorry for answering late. I was involved with other matters.
>> (1) Not sure what Translation Z does. Now it shears the dome, allowing  an
>> inside view. Is that correct?
> It is a scaling along the z-axis (in OpenGL and Moray, which happens to be
> the y-axis in POV-Ray) this scaling is done before the struts and spheres
> are created (it has no particular effect on the "faces").
> I enclosed an image of a Dome with no scaling (on the left), with pov-ray
> z-scaling (in the middle) and with the Dome z-scaling (on the right)
OK. Understood.
>> (2) Materials: How are they invoked?
> I choose materials rather than textures because when you want to use a
> texture, you just have to write :
> #declare Mat1 = {texture {myFavoriteTexture}}
> And you have turn your favorite texture into a material.
I understand that; however, one has to invoke an .inc file I suppose, or
should the material just be sitting in the Domenator directory?
>> (3) Mesh2{} would be great eventually, including the csg objects.
> If you're not the only one to be interested in I will (if you're the only
> one, it will take a little bit more of time ;-)).
Fair enough.
Date: 27 Apr 2012 11:00:15
Message: <4f9ab47f@news.povray.org>
Hi Thomas,
Don't worry about any delay, I saw you are working on Gancaloon ;-))
About the material, the answer is : they must be defined in an INC file.
I thought of some sort of a texture list file, but I'm not sure it would be
really useful. If you have any new feature request on this topic or any
other one : just tell.
Best regards
Philippe
Philippe
4f9a5897$1@news.povray.org...
>> Hi Thomas,
>> Very good news.
>>> an
>> be
> OK. Understood.
> Fair enough.
> Thomas
Date: 28 Apr 2012 03:08:31
Message: <4f9b976f$1@news.povray.org>
On 27-4-2012 17:00, Philippe Gibone wrote:
> Hi Thomas,
How do you know?!;-)
An INC file is perfect. Something you could add however is a way to
include the INC file in the dome.inc file. For instance in the Files
Menu, have a box where the name of the INC file can be given, and have
that file included in the dome.inc after the comments list like this:
// fNoiseProgressiveR     = 0.000000
// fNoiseProgressiveZ     = 0.000000
#include "MyTextures.inc"
// MaxI = 121 ; MaxJ = 39
#declare MyDome = union {
sphere   { < 0.000000, 1.000000, 0.000000 >, 0.030000 }
cone { < 0.041325, 0.999146, 0.000000 >, 0.030000, < 0.000000, 1.000000,
Date: 28 Apr 2012 03:20:39
Message: <4f9b9a47@news.povray.org>
Hi Thomas
> include the INC file in the dome.inc file. For instance in the Files Menu,
> have a box where the name of the INC file can be given, and have that file
Very good Idea, I will think of it.
It would also authorize Domenator to extract the names of the
materials/textures in that inc file and to propose them in list-boxes ...
To be continued ;-))
Philippe
Date: 10 May 2012 08:33:13
Message: <4fabb589$1@news.povray.org>
I have been looking into the possibilities of exporting the dome
triangles, using Poseray. This works well and gives the possibility to
export then to an OBJ file, which I can load into Silo2.
Something that I noticed then is that the triangle pairs forming the
quads have opposing normal orientation, caused - I suppose - by the way
the triangles are built. This poses a problem for further working on the
object.
Is is possible to build the dome with a uniform orientation of all the
triangle normals? That would help a lot.
Thanks!
Date: 12 May 2012 07:29:33
Message: <4fae499d$1@news.povray.org>
It would not be too difficult. As I just wrote a little mesh-building
macro, I see that all triangle vertexes should wind clockwise in order
to get all the normals consistently pointing up/out of the mesh. I
suppose the same applies to smoothed triangles.
Date: 13 May 2012 02:20:05
Message: <4faf5295$1@news.povray.org>
Hello Thomas,
Sorry for the delay, but no problem, I will do that (it's a mistake anyway)
Regards
Philippe
Philippe
4fabb589$1@news.povray.org...
> Something that I noticed then is that the triangle pairs forming the quads
> have opposing normal orientation, caused - I suppose - by the way the
> object.
> Thanks!
> Thomas
Date: 8 Aug 2018 01:35:00
Message: <web.5b6a80787c081d931eeb75bf0@news.povray.org>
"Philippe Gibone" <ph.### [at] wanadoofr> wrote:
> Hi Thomas,
> Very good news.
> Regards
> Philippe
> Philippe
> 4f95013e$1@news.povray.org...
> > On 22-4-2012 19:32, Philippe Gibone wrote:
> >> Hi Thomas,
> >> I'm really sorry for that, OpenGL seems to be a real mess, this is my
> >> first
> >> programm using it, it may be the last.
> >> The DLL on my computer are :
> >> glu32.dll  22/08/2001  21:00           116 736
> >> glut32.dll 27/03/2005  12:10           483 460
> >> Hope that helps
> > It does, Philippe, thanks. I just copied my youngest glut32.ddl from
> > Silo2 to the Domenator directory. It works now. Going to play ;-)
> > ...later: Works well and hugely enjoyable. A couple of questions:
> > an inside view. Is that correct?
> > Thomas
Can you sent me a link to the domenator plugin? phy### [at] gmailcom, Thank you.
Date: 8 Aug 2018 02:38:36
Message: <5b6a8fec$1@news.povray.org>
This should be the one:
http://news.povray.org/povray.binaries.utilities/thread/%3Cweb.5ab27e6cee2e1936a1e60c470%40news.povray.org%3E/
