On 07/03/2012 11:38 AM, clipka wrote:
> Am 07.03.2012 12:09, schrieb Stephen:
>>> subsurface { translucency <0.5,0.2,0.2> }
>> This is the bit that I don't understand.
>> Why did you pick these values? I don't understand why you made the red
>> value larger than the others.
> As for the general scale of the translucency parameter, I toyed around
> with it until I found a setting that seemed to convey the right sense of
> scale and material to me. It was just a matter of "this looks to solid"
> vs. "this looks too waxy".
> As for the red component, I decided that I wanted thin portions of the
> material to have a somewhat reddish tint, despite of the overall
> greenish appearance. To achieve this, red light needs to travel further
> inside the material than other colors.
Thanks, again.
So it seems that James Holsenback was telling the truth. It is a case of
suck it and see.
Regards
On 03/07/2012 12:16 PM, Stephen wrote:
> It is a case of suck it and see.
LOL ... yes there is a treat in the center if you suck long enough ;-)
Hmm! Sherbet. :-D
I found my problem, well one of them anyway. ;-)
With RC3 I was using a texture map material and each texture had its own
subsurface {}. That does not work well with RC4.
Regards
Am 06.03.2012 20:01, schrieb clipka:
> Yup. I'm already running another render with higher-quality settings
> (and desktop-size resolution).
And here she is. Originally rendered at 3840x2400 pixels. Render time
was less than 7 hours.
Don't expect to get the same quality at the same speed with official 3.7
though: I needed to code a totally new anti-aliasing mode for this, and
it won't make it into the release. It'll make a good base for a
stochastic rendering spin-off of POV-Ray 3.7 though, so stay tuned.
Download 'stanford_lucy 2012-03-07 2235 1920x1200.png' (490 KB)
Preview of image 'stanford_lucy 2012-03-07 2235 1920x1200.png'
Am 07.03.2012 23:23, schrieb clipka:
A close-up of the original. As you can see there is still some pixel
noise, but the noise level is much more uniform across the whole image,
making it far less distracting.
Am 07.03.2012 23:40, schrieb clipka:
... forgot the attachment again.
Download 'stanford_lucy 2012-03-07 2235 detail.png' (1310 KB)
Preview of image 'stanford_lucy 2012-03-07 2235 detail.png'
On 07/03/2012 10:23 PM, clipka wrote:
> And here she is.
The lighting makes it.
Regards
Guess what - I managed to get hold of a tin miniature of her!
Unfortunately, the autofocus doesn't seem to play well with the macro lens.
Download 'stanford_lucy 2012-03-08 0034.png' (1610 KB)
Preview of image 'stanford_lucy 2012-03-08 0034.png'
Le 08/03/2012 00:36, clipka nous fit lire :
Yummy... but you're given away by the 3.7... (hint, no exif, and png has
more to says about what you did at 23:34:30Z on the 7th march)
Am 07.03.2012 23:42, schrieb Stephen:
>> And here she is.
Ain't that right?
I /love/ toying around with light & shadow.
