POV-Ray : Newsgroups : povray.binaries.images : Attempt at realistic skin textures Server Time
21 Apr 2026 23:56:50 EDT (-0400)
  Attempt at realistic skin textures (Message 11 to 20 of 21)
<<< Previous 10 Messages Goto Latest 10 Messages Next 1 Messages >>>
Subject: Re: Attempt at realistic skin textures
Date: 16 Feb 2012 03:39:01
Message: <4f3cc0a5$1@news.povray.org>
On 15-2-2012 17:51, andrel wrote:
> I agree. When the skin is so wet, you would expect small 'puddles' in
> places where they can collect and droplets at overhangs like the chin.
Indeed. I did the test on myself :-)
> If it is intended as oil, most of us seldom seen females fully oiled (I
> am told it happens at the sort of parties that we never attend). Hence
> it is unfamiliar and therefore unconvincing.
Eerr... I do not want to give the impression that I... well, I mean... ;-)
To be serious: I fully agree and I indeed wanted to test the
(exagerated) image on unsuspecting viewers because I was not entirely
sure how to proceed in this case.
Thanks all for the comments! In time, I shall investigate the wet skin
further (a longer term goal) but if anybody comes up with something
before please show and teach us.
Date: 16 Feb 2012 09:46:49
Message: <4f3d16d9$1@news.povray.org>
Am 14.02.2012 08:53, schrieb Thomas de Groot:
>> Don't worry about it: You can't get it right anyway, due to a known
>> problem with POV-Ray's implementation of UV-mapped image-based bump
>> maps. Unfortunately, fixing it isn't exactly trivial.
> Ah? Interesting to hear this. I hope (I know!) you will find a solution.
My last attempt to fix it came at the cost of scrambling all
non-UV-mapped bump maps instead, for reasons I didn't quite understand :-P
But be sure I'll try again; it's one of the things that currently bug me
most about POV-Ray.
Date: 11 Mar 2012 22:40:49
Message: <4f5d6231$1@news.povray.org>
> On 14-2-2012 1:13, clipka wrote:
>> Am 13.02.2012 13:25, schrieb Thomas de Groot:
>>> I am still not sure about whether the bump sizes should be positive or
>>> negative. I find positive values looking better in general but that
>>> might be a wrong approach.
I'm currently looking into this once again. Seems like there are
actually two more-or-less independent design flaws contributing to this,
one of which affects even non-UV-mapped bump maps.
And then tnere's another one, that has gone unnoticed so far: Did you
know that if you use a low-resolution bump map for testing, you'll get
stronger bumps than in the final render?
This also means that if I sort out all the problems, I'm guaranteed to
break each and every existing scene that uses bump maps. Yuck!
Date: 12 Mar 2012 04:20:51
Message: <4f5db1e3$1@news.povray.org>
Excellent! I mean, you looking into the matter ;-)
Well, I may have noticed but not consciously really.
Who cares? :-) I am quite willing to redo everything as long as
henceforward everything works better.
Subject: Bump Mapping
Date: 15 Mar 2012 15:54:00
Message: <4f6248d8@news.povray.org>
Am 16.02.2012 15:46, schrieb clipka:
> most about POV-Ray.
Okay, here's a quiz to all of you: Please describe the surface structure
of this thing. Are those dimples or pimples? (Hint: The light comes
almost straight from the camera position.)
(Rendered with POV-Ray 3.7.RC5 using a  plain old non-uv-mapped
bump_map; POV-Ray 3.6 gives the same results.)
Download 'bump_map_types.png' (470 KB)
Preview of image 'bump_map_types.png'
Subject: Re: Bump Mapping
Date: 15 Mar 2012 15:55:57
Message: <4f62494d@news.povray.org>
Am 15.03.2012 20:53, schrieb clipka:
>> :-P
>> most about POV-Ray.
> (Rendered with POV-Ray 3.7.RC5 using a plain old non-uv-mapped bump_map;
... and now with some patch.
Download 'bump_map_types.png' (440 KB)
Date: 15 Mar 2012 17:44:55
Message: <4f6262d7$1@news.povray.org>
Le 15/03/2012 20:55, clipka nous fit lire :
Hey, stop that (not)! How are we going to emulate the classical picture
of Escher with holes/spheres on a path ?
I guess that fix that issue, right ?
Date: 15 Mar 2012 18:23:41
Message: <4f626bed@news.povray.org>
Am 15.03.2012 22:44, schrieb Le_Forgeron:
Unfortunately this is only half of the job: With this fix, bump maps
will behave like all other perturbed normals - which means that they're
still acting similarly weird when UV-mapped. That'll be the next to tackle.
Date: 15 Mar 2012 18:38:26
Message: <4f626f62$1@news.povray.org>
Am 15.03.2012 23:23, schrieb clipka:
... oh, and warps mess up perturbed normals, too.
Date: 16 Mar 2012 04:01:53
Message: <4f62f371$1@news.povray.org>
LOL! Both! Obviously showing the problem you were refering to.
