POV-Ray : Newsgroups : povray.binaries.images : tiling type 5 + repeat warps = wallpapering non-stop Server Time
28 May 2026 05:54:05 EDT (-0400)
  tiling type 5 + repeat warps = wallpapering non-stop (Message 3 to 12 of 12)
<<< Previous 2 Messages Goto Initial 10 Messages
Subject: Re: tiling type 5 + repeat warps = wallpapering non-stop
Date: 3 Jan 2012 23:01:44
Message: <4f03cf28$1@news.povray.org>
On 01/03/2012 04:44 PM, Jaime Vives Piqueres wrote:
> I finally found a simple way to create an endless stream of wallpapers
> for my virtual rooms, using the new tiling pattern type 5 (thanks,
> clipka!), combined with repeat warps in a texture_map.
BTW:
tiling pattern 1-24 = LeForgeron
tiling pattern 25-27 = clipka
Date: 4 Jan 2012 04:33:22
Message: <4f041ce2@news.povray.org>
Thank you indeed, Jaime. Very nice and useful little job.
Is there a particular reason why the rendered tile is rectangular? Would
it not make (more) sense if the tile was square?
Download 'jvp_tiling.png' (897 KB)
Preview of image 'jvp_tiling.png'
Date: 4 Jan 2012 05:14:43
Message: <4f042693@news.povray.org>
On 04/01/12 02:45, Christian Froeschlin wrote:
> Very neat!
   Thanks!
> Tried some simple procedural base textures (gradient + spiral2).
   Yeah... crackle is also a good base.
> I'm still not quite sure what properties a good base texture should
> have, some are quite impossible to line up (your *_03 sample also has
> some odd edges).
   Well, already repeating patterns are the best, of course. Also, you
can get ride of the random rotation, and use instead a fixed amount, to
line up the image patterns with the tiling pattern: it should give you
more chances to get a result without obvious seams.
   Another way I've just found, is to apply successive repeat warps
combined with 120 degree rotations, "a la stbenge":
#declare t_base=
texture{
     pigment{
       image_map{jpeg imagemap interpolate 2}
       rotate 90*x
       translate rand(r_pattern)*x
       translate rand(r_pattern)*z
       rotate 360*rand(r_pattern)*y
       scale im_scale
       #local nCount = 0;
       #while ( nCount < 360/120 )
         rotate 120*y
         warp { repeat .5*x flip x}
         warp { repeat sqrt(.75)*z flip z}
         #local nCount = nCount + 1;
     finish{emission 1}
   This limits a bit the variety of the results, but you get ride of the
visible seams.
Jaime
Date: 4 Jan 2012 05:17:00
Message: <4f04271c@news.povray.org>
   Oops! Many thanks to LeForgeron then... sorry for the confusion. :(
Jaime
Date: 4 Jan 2012 05:28:32
Message: <4f0429d0$1@news.povray.org>
> Would it not make (more) sense if the tile was square?
   As trial&error is my most usual approach to geometry, I first tried
square repeats, but it did not work. Then I noticed the tiling type five
is not square, so I then applied good & old Pythagoras to get the
correct ratio. I really don't know if it can be made square, or if it
makes more sense... I just assumed it should be that way for this
specific symmetry. And for my wallpapering usage, if it tiles
seamlessly, that's enough. But I guess you're already thinking on the
Gancaloon ceramic tiles... ;)
Jaime
Date: 4 Jan 2012 07:10:49
Message: <4f0441c9$1@news.povray.org>
That makes sense indeed. If the tiling type is not square, the image
should not be either :-)  I missed that part indeed.
This macro makes a nice addition to your azulejos macro which I used
(and shall use again) in Gancaloon. The possibilities are endless.
Date: 12 Jan 2012 11:03:57
Message: <4f0f046d@news.povray.org>
> If you enjoy repetition, try the following code at your own risk... ;)
> Jaime
Jamie,
Thanks for the #macro (sent my latest project in a different direction!)
... easy to use, just scaling and orientation for my situation.
Jim
Download 'work.png' (1221 KB)
Preview of image 'work.png'
Date: 12 Jan 2012 13:19:04
Message: <4f0f2418$1@news.povray.org>
   Very nice! ... but now it's asking for some wall lamps. :)
Jaime
Date: 13 Jan 2012 03:14:32
Message: <4f0fe7e8$1@news.povray.org>
Yes, and preferably gaslight too ;-)
Date: 15 Jan 2012 15:36:06
Message: <4f1338b6$1@news.povray.org>
Am 03.01.2012 22:44, schrieb Jaime Vives Piqueres:
> Hi all:
You're "blaming" the wrong person this time: I'm not responsible for
/some/ of the new features :-) All the tiling patterns available in
3.7.RC3 were added by Le_Forgeron instead. I merely added three more to
the set, to be included in RC4.
