POV-Ray : Newsgroups : povray.binaries.images : a little subsurface Server Time
22 Apr 2026 01:40:34 EDT (-0400)
  a little subsurface (Message 5 to 14 of 14)
<<< Previous 4 Messages Goto Initial 10 Messages
Subject: Re: a little subsurface
Date: 20 Dec 2011 19:09:19
Message: <4ef123af$1@news.povray.org>
On 20/12/2011 11:41 PM, Jim Holsenback wrote:
>>> LOL ... OK maybe too much spirit. PoseRay ... great tool BTW if it's
>>> not in your work flow it should be!
>> ha I was just going to ask if that was a typo ;)
>> Cool site, thanks for the link. Finding objects
>> seems to be a bit cumbersome, though. Or is there
>> better search capability after registering?
> yeah ... ui lacking. category filter at top of the page was good enough.
> I didn't bother registering ... found several that I downloaded.
Don't install the toolbar. It kept taking me to the site whenever I
opened a new tab.
A good source of meshes though.
Regards
Date: 20 Dec 2011 23:10:44
Message: <4ef15c44$1@news.povray.org>
Am 20.12.2011 23:01, schrieb Jim Holsenback:
> I found some pretty cool models http://www.archibase.net/gdl?category=0
> (mostly 3ds format) so I had to use Poser to get them in mesh2 ... well
> after these great first pass subsurface results I just had to share. Not
> to bad ... eh! This scene is going to be fun. I'm thinking something off
> camera right (lined up with the light source) ... semi transparent so it
> throws some color onto the floor. A plant in a clay pot, background
> left. Since my environment is the same hdr (I've been getting plenty of
> mileage so what the heck, right) I think I'll dial up the reflection
> here and there, ahhhh ... the possibilities.
Looks great! The subsurface parameters (or something else I can't point
my finger at) make it appear quite small though; I'd estimate it at some
20 cm in height. Maybe even 10 cm - just the right size to be the queen
in an exquisite set of chess figures.
Date: 21 Dec 2011 04:20:08
Message: <4ef1a4c8$1@news.povray.org>
Very nice indeed. For a second I mistook the shadow falling on the right
of the figure to be some kind of (crude) movement blurring :-) Maybe
this is due to the subsurface?
Date: 21 Dec 2011 09:10:01
Message: <web.4ef1e785bfb1755f86dc68ef0@news.povray.org>
Very nice, could we get an idea of rendering time?
Enjoy your holidays Jim
Date: 21 Dec 2011 12:25:21
Message: <4ef21681$1@news.povray.org>
yeah ... I've found that mm_per_unit 40 is a fairly good starting point.
you can most generally see if you need to go higher or lower easy
enough. given the scale I'm working with I'd say maybe even triple that
might not be to out of line. I'll probably end up doing a couple of half
step runs between 40 and 120 to see where I end up.
Date: 21 Dec 2011 12:32:01
Message: <4ef21811$1@news.povray.org>
> Thomas
I believe that's from the statue straddling the shadow line ... that was
on purpose as I think the subsurface effect looks cool at those
transitions ... dunno if it's going to work out yet tho ;-)
Date: 21 Dec 2011 12:38:00
Message: <4ef21978@news.povray.org>
hmmm ... haven't been keeping tabs on that
merci ... you as well :-)
Date: 23 Dec 2011 17:10:54
Message: <4ef4fc6e@news.povray.org>
> opened a new tab.
Don't ever install any proposed toolbar, ever.
They only clutter your browser, slow down everything, and may cause all
sort of problems.
Date: 26 Dec 2011 13:18:12
Message: <4ef8ba64@news.povray.org>
a close up of the statue ... most likely the subsurface settings I'll be
using, although I'm not sure what the artifact's are on the eyelids
(didn't show up in the radiosity final pass) ... but the rest of it
(sslt) is killer, wouldn't you agree! Using mm_per_unit 64 and
subsurface { samples 400,40 } in the globals block ... oh yeah and my
compliments to the author of the object, it's top drawer (BTW: ~100MB
subdivided via PoseRay)
Download 'work.png' (640 KB)
Preview of image 'work.png'
Date: 26 Dec 2011 14:30:15
Message: <4ef8cb47$1@news.povray.org>
Yes I would.
A very nice mesh, indeed.
Regards
