POV-Ray : Newsgroups : povray.binaries.images : Every ship needs a parrot Server Time
28 May 2026 05:54:10 EDT (-0400)
  Every ship needs a parrot (Message 14 to 23 of 23)
Subject: Re: Every ship needs a parrot
Date: 12 Dec 2011 21:01:53
Message: <4ee6b211$1@news.povray.org>
"Ive" <ive### [at] lilysoftorg> wrote in message news:4ee68d12$1@news.povray.org...
> Am 12.12.2011 22:37, schrieb Dre:
>> Awesome!
> Thanks.
>>How did you get that real nice blue light to work??
> Well, the construction of the ceiling, the dome and the whole lighting is
> so simple that I'm almost ashamed of it ;)
> It is really just a clipped_by sphere and a torus (both with a radial
> texture and emission) and one spotlight.
> The spotlight simulates two things at once:
> - the "daylight lamp" that would simulate the sun within the arboretum and
> is currently close to zenith.
> - the "light tubes" surrounding the dome.
> The radius of the spotlight matches exactly the dome radius and the
> falloff is adjusted to match the top of the port and starboard window
> walls. It is yellow/red to compensate for the blue dome color and the blue
> tint produced by radiosity. So we get an average white daylight condition
> under the dome and a slightly bluish tint at the outside due the falloff
> of the spotlight.
>   light_source { <0,10,0>  rgb <0.90, 0.85, 0.75>*5
>     spotlight point_at <0,0,0> radius 48 falloff 66
>     area_light x*0.67 z*0.67 5,5 adaptive 2 circular orient
>     fade_power 2 fade_distance FD*2
>     projected_through {Ceiling}
> This together with moderate radiosity settings
>   radiosity {
>     pretrace_start 0.08
>     pretrace_end   2/max(image_width,image_height)
>     count 250
>     nearest_count 10
>     error_bound 0.45
>     recursion_limit 1
>     low_error_factor 0.5
>     gray_threshold 0
>     minimum_reuse 0.015
>     brightness 1.0
>     adc_bailout 0.01/2
>     always_sample off
>     normal off
> produced the original image at 1920x1080 pixel within 24 hours - and I
> consider this also as quite moderate given the incredible amount of grass
> blades, leaves and petals ;)
> -Ive
Great stuff, sometimes the simple things are the best way to do things!
Thanks for the description, I'll sure have a play with that and see what I
can come up with :)
Cheers Dre
Date: 13 Dec 2011 03:57:05
Message: <4ee71361$1@news.povray.org>
On 13-12-2011 1:31, Ive wrote:
> But I really do not have any rank in Starfleet ;)
Arboretum First Officer, I would say  ;-)
Date: 14 Dec 2011 23:41:33
Message: <4ee97a7d$1@news.povray.org>
> -Ive
Here, adaptive have no effect.
adaptive 1 start at 3 by 3
adaptive 2 start at 5 by 5
adaptive 3 start at 9 by 9
area_light x*0.67 z*0.67 9,9 adaptive 2 circular orient only have a
marginal advantage.
adaptive 2 start to have a notable speed advantage at 17 by 17 and more.
Date: 17 Dec 2011 19:45:00
Message: <web.4eed368e9aa312d97f98f9e70@news.povray.org>
Ive <ive### [at] lilysoftorg> wrote:
> Inside the arboretum...
Wow, Ive, that's an awesome render. I especially like the ground cover; it
really gives me some ideas :)
~Sam
Date: 19 Dec 2011 16:52:36
Message: <4eefb224@news.povray.org>
Am 18.12.2011 01:40, schrieb Samuel Benge:
Great. To me your images have always been a source of inspiration ;) and
I really like your ongoing experimenting and your incredible good eye
for details.
-Ive
Date: 19 Dec 2011 17:27:41
Message: <4eefba5d@news.povray.org>
Am 15.12.2011 05:41, schrieb Alain:
> marginal advantage.
Hmm, I'm not sure if I understand you correct. You mean using adaptive 2
makes only sense when using *more* than 5 by 5, right?
Actually I never did a serious speed/quality trade-off compare regarding
area_lights parameters and used more a "I guess this might work" and
alternatively a "better more than less" approach. Probably not a good
idea, so thanks for the head up.
-Ive
Date: 20 Dec 2011 14:50:00
Message: <web.4ef0e6159aa312d985de7b680@news.povray.org>
Yes.  These are from my notes:
  Array Size   Maximum Useful Value   Break-Even Value
    2 x 2              none                  0
    3 x 3               0                    1
    5 x 5               1                    2
    9 x 9               2                    3
   17 x 17              3                    4
   33 x 33              4                    5
Accordingly, adaptive 2 has no effect on 5 by 5.
I've done such comparisons, based on Alain's advice.  My general findings are:
  - Adaptive 0 tends to produce unrealistic effects, especially if
    an object (e.g., the lamp fixture!) is close to the light source.
  - Adaptive 1 is sufficient; I haven't had the need to go higher.
  - IIRC, 9 by 9 adaptive 0 was faster than 5 by 5 adaptive 1.  (I
    don't know if that test can be generalized.)  However, the poor
    quality of the adaptive 0 usually isn't worth the speed advantage.
  - Jitter helps.
  - 9 by 9 adaptive 1 is usually a good setting.
However, I haven't tested 9 by 9 adaptive 1 against 5 by 5 adaptive 2.
Date: 20 Dec 2011 16:54:18
Message: <4ef1040a$1@news.povray.org>
BTW, what is the default value? I didn't find that in the docs.
Date: 20 Dec 2011 17:15:14
Message: <4ef108f2$1@news.povray.org>
yikes ... you are correct! If someone knows what the default is I'll
make sure it get added in the appropriate place.
Date: 20 Dec 2011 18:40:00
Message: <web.4ef11b9d9aa312d985de7b680@news.povray.org>
There is no default value.  According to the syntax diagram (and a quick test
corroborates this), the adaptive keyword requires a value.  Without the adaptive
keyword, there is no adaptive sampling.
