POV-Ray : Newsgroups : povray.binaries.images : Every ship needs a parrot Server Time
28 May 2026 05:54:11 EDT (-0400)
  Every ship needs a parrot (Message 11 to 20 of 23)
<<< Previous 10 Messages Goto Latest 10 Messages Next 3 Messages >>>
Subject: Re: Every ship needs a parrot
Date: 12 Dec 2011 18:24:02
Message: <4ee68d12$1@news.povray.org>
Am 12.12.2011 22:37, schrieb Dre:
> Awesome!
Thanks.
>How did you get that real nice blue light to work??
Well, the construction of the ceiling, the dome and the whole lighting
is so simple that I'm almost ashamed of it ;)
It is really just a clipped_by sphere and a torus (both with a radial
texture and emission) and one spotlight.
The spotlight simulates two things at once:
- the "daylight lamp" that would simulate the sun within the arboretum
and is currently close to zenith.
- the "light tubes" surrounding the dome.
The radius of the spotlight matches exactly the dome radius and the
falloff is adjusted to match the top of the port and starboard window
walls. It is yellow/red to compensate for the blue dome color and the
blue tint produced by radiosity. So we get an average white daylight
condition under the dome and a slightly bluish tint at the outside due
the falloff of the spotlight.
   light_source { <0,10,0>  rgb <0.90, 0.85, 0.75>*5
     spotlight point_at <0,0,0> radius 48 falloff 66
     area_light x*0.67 z*0.67 5,5 adaptive 2 circular orient
     fade_power 2 fade_distance FD*2
     projected_through {Ceiling}
This together with moderate radiosity settings
   radiosity {
     pretrace_start 0.08
     pretrace_end   2/max(image_width,image_height)
     count 250
     nearest_count 10
     error_bound 0.45
     recursion_limit 1
     low_error_factor 0.5
     gray_threshold 0
     minimum_reuse 0.015
     brightness 1.0
     adc_bailout 0.01/2
     always_sample off
     normal off
produced the original image at 1920x1080 pixel within 24 hours - and I
consider this also as quite moderate given the incredible amount of
grass blades, leaves and petals ;)
-Ive
Date: 12 Dec 2011 18:45:00
Message: <web.4ee691059aa312d994d713cc0@news.povray.org>
Ive <ive### [at] lilysoftorg> wrote:
> Inside the arboretum...
This is wonderful! Beautifully done sir, as always :)
www.McGregorFineArt.com
Date: 12 Dec 2011 19:32:57
Message: <4ee69d39$1@news.povray.org>
Am 13.12.2011 00:40, schrieb Robert McGregor:
As you were!
But I really do not have any rank in Starfleet ;)
-Ive
Date: 12 Dec 2011 21:01:53
Message: <4ee6b211$1@news.povray.org>
"Ive" <ive### [at] lilysoftorg> wrote in message news:4ee68d12$1@news.povray.org...
>> Awesome!
> Thanks.
> Well, the construction of the ceiling, the dome and the whole lighting is
> - the "daylight lamp" that would simulate the sun within the arboretum and
> walls. It is yellow/red to compensate for the blue dome color and the blue
> tint produced by radiosity. So we get an average white daylight condition
> under the dome and a slightly bluish tint at the outside due the falloff
> of the spotlight.
>   radiosity {
>     pretrace_start 0.08
>     count 250
>     nearest_count 10
>     error_bound 0.45
>     recursion_limit 1
>     gray_threshold 0
>     minimum_reuse 0.015
>     brightness 1.0
>     adc_bailout 0.01/2
>     always_sample off
>     normal off
> consider this also as quite moderate given the incredible amount of grass
> -Ive
Great stuff, sometimes the simple things are the best way to do things!
Thanks for the description, I'll sure have a play with that and see what I
can come up with :)
Cheers Dre
Date: 13 Dec 2011 03:57:05
Message: <4ee71361$1@news.povray.org>
Arboretum First Officer, I would say  ;-)
Date: 14 Dec 2011 23:41:33
Message: <4ee97a7d$1@news.povray.org>
> -Ive
Here, adaptive have no effect.
adaptive 1 start at 3 by 3
adaptive 2 start at 5 by 5
adaptive 3 start at 9 by 9
area_light x*0.67 z*0.67 9,9 adaptive 2 circular orient only have a
marginal advantage.
adaptive 2 start to have a notable speed advantage at 17 by 17 and more.
Date: 17 Dec 2011 19:45:00
Message: <web.4eed368e9aa312d97f98f9e70@news.povray.org>
Wow, Ive, that's an awesome render. I especially like the ground cover; it
really gives me some ideas :)
~Sam
Date: 19 Dec 2011 16:52:36
Message: <4eefb224@news.povray.org>
Am 18.12.2011 01:40, schrieb Samuel Benge:
Great. To me your images have always been a source of inspiration ;) and
I really like your ongoing experimenting and your incredible good eye
for details.
-Ive
Date: 19 Dec 2011 17:27:41
Message: <4eefba5d@news.povray.org>
Am 15.12.2011 05:41, schrieb Alain:
> marginal advantage.
Hmm, I'm not sure if I understand you correct. You mean using adaptive 2
makes only sense when using *more* than 5 by 5, right?
Actually I never did a serious speed/quality trade-off compare regarding
area_lights parameters and used more a "I guess this might work" and
alternatively a "better more than less" approach. Probably not a good
idea, so thanks for the head up.
-Ive
Date: 20 Dec 2011 14:50:00
Message: <web.4ef0e6159aa312d985de7b680@news.povray.org>
Yes.  These are from my notes:
  Array Size   Maximum Useful Value   Break-Even Value
    2 x 2              none                  0
    3 x 3               0                    1
    5 x 5               1                    2
    9 x 9               2                    3
   17 x 17              3                    4
   33 x 33              4                    5
Accordingly, adaptive 2 has no effect on 5 by 5.
I've done such comparisons, based on Alain's advice.  My general findings are:
  - Adaptive 0 tends to produce unrealistic effects, especially if
    an object (e.g., the lamp fixture!) is close to the light source.
  - Adaptive 1 is sufficient; I haven't had the need to go higher.
  - IIRC, 9 by 9 adaptive 0 was faster than 5 by 5 adaptive 1.  (I
    don't know if that test can be generalized.)  However, the poor
    quality of the adaptive 0 usually isn't worth the speed advantage.
  - Jitter helps.
  - 9 by 9 adaptive 1 is usually a good setting.
However, I haven't tested 9 by 9 adaptive 1 against 5 by 5 adaptive 2.
